Author Topic: WG K7000 - Remote board replacement?  (Read 2520 times)
OverRide
  • Last login:January 11, 2026, 04:25:09 pm
« on: July 16, 2010, 11:43:26 am »
Hello,
I need to either replace the whole board or the pots. I have tried cleaning the pots but it makes no difference. The black level no longer works, and the slightest bump to the board and the monitor go screwy. Just wondering where one would find a replacement board or what are the pot specs to order replacements?
If I do replace the pots, should I replace any other components on the board while I am at it?
There is a photo of the board below.
Thanks for your help!
lilshawn
  • Last login:April 27, 2026, 05:41:40 pm
Re: WG K7000 - Remote board replacement?
« Reply #1 on: July 16, 2010, 04:20:02 pm »
i'd run a soldering iron over that board first, make sure there is no broken joints first.
then do a continuity test on the cable going to the main chassis, make sure no broken wires.
if need be, you could replace the pots, but start with a re-solder first. it's cheap and easy and my fix your issue.
OverRide
« Reply #2 on: July 18, 2010, 10:38:24 pm »
Thanks for the advice.  I went through the steps with no luck.
I did take the pots off and ran them through a multimeter. I am not sure what it all means. I started at the lowest resistance and worked my way up until I got a reading then documented it below.
Thanks for your help.
Vert Pos = R8846 40x0646-004 - 22.4 @200k
Vert Size = R8851 40x0646-005 - .530 @ 2K
Black Level = R8851 40x0646-006 - 1.989 @ 2k
Horiz Pos = R8851 40x0646-005 - .592 @ 2K
