Author Topic: How would you solder this board? (usb hack)  (Read 1523 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: June 30, 2010, 08:45:36 am »
Hello
I got a pc usb stick torn apart, and looking to hack it. There is two pieces, the main board (brown) has 8 buttons and attaches to the joystick then there is addon board with other buttons.  I think I get the larger board, I am only assuming i am right.  The larger solder spots are for each button, I am guessing that all I would have to do is solder two wires to the back of each button?
The smaller board I am not sure.. what to solder too.. (my first try at this usb hack)
If anyone could take a few mins too explain simple hacking and maybe show me on my pics where/what to solder I would appreciate it.  I should let you know that I have successfully hacked my first stick yesterday!! Hacked a flight stick, however after I got it all done there just is not enough buttons (5+joystick).  So I am going to try this.  I guess I could make a simple 3 button panel with the joystick......
I attached photos too... hopefully someone can help me out...
thanks in advance and as always much appreciated!
Jim
Thenasty
  • Trade Count: (+17)
  • Last login:June 18, 2026, 10:57:35 pm
Re: How would you solder this board? (usb hack)
« Reply #1 on: June 30, 2010, 09:09:29 am »
On the back of the Brown Board PCB with 8 buttons.
Free VGA Breakout Cable
Demon-Seed
« Reply #2 on: June 30, 2010, 09:12:20 am »
Hey
The Nasty.. thanks that is what I thought for that board.. but the other one?? not so sure.
thanks
Jim
Thenasty
« Reply #3 on: June 30, 2010, 09:13:13 am »
For the Adsaptor for extra buttons, you have FIVE wires
One of each if for a Button and the ONE COMMON WIRE will be Ground.
Use a Multimeter and see which is which.
Demon-Seed
« Reply #4 on: June 30, 2010, 09:17:15 am »
Hey
HEHE I was thinking that too but was not sure if I should detach the wires from the board..... Umm I am new to this but with the last one when I tested for ground I had two points... what two points would I use>>>>?? obviously the wire.. but the other?
thx
Jim
« Last Edit: June 30, 2010, 09:21:03 am by Demon-Seed »
Thenasty
« Reply #5 on: June 30, 2010, 09:32:53 am »
GROUND is GROUND. On PCB, there are usually many GROUND points. You could use any one.
I suggest you use a Multimeter to make sure what you see is what it is.
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #6 on: July 01, 2010, 05:43:05 am »
Which ever wire goes to more then one connection is the ground wire.  All the others are one for a button.  Follow the traces on the board.
