Author Topic: I'm officially a Dreamcast Dummy.....  (Read 5790 times)
bsoder52
  • Last login:August 24, 2026, 11:03:47 pm
« on: February 19, 2007, 05:53:06 pm »
Bought Street Fighter 2 X for my DC and now findout I can't even play the game cause it's NTSCJ and my DC is NTSC.
So anyone know, do I need to buy a NTSCJ DC or is that any other way to play this game?
Thanks,
Bsoder52
versapak
  • Last login:June 25, 2026, 08:02:25 am
  • I am t3h GAY!!!
Re: I'm officially a Dreamcast Dummy.....
« Reply #1 on: February 19, 2007, 06:31:52 pm »
All you need is a boot disc.
Do a little googling, and you should come across one fairly easy. ;-)
« Reply #2 on: February 19, 2007, 07:15:27 pm »
ahh... the dreamcast is like UTOPIA...  *hint hint*
Sorry I didn't get back to you sooner, things got kinda hectic after the car accident.
bsoder52
« Reply #3 on: February 19, 2007, 10:03:40 pm »
Sorry to hear you were in a car accident, are you ok?>?
So got a boot disk and DJuggled it to CD.
I'm getting a prompt that says:
"The game doesn't support the AV cable that is currently connected to the main counsel."
I think this means that the boot disk isn't VGA compatible?
Correct?
versapak
  • I am t3h GAY!!!
« Reply #4 on: February 19, 2007, 10:42:30 pm »
Correct?
Yep
I'm pretty sure there are some out there that are vga compatible. You might even be able to just do a quick hex edit to the image you already downloaded (I know such is the case with some games).
bsoder52
« Reply #5 on: February 19, 2007, 10:58:44 pm »
I found this one that's VGA compatible.
http://www.megagames.com/dc/dc_utils_bootcd.shtml
I installed, used DJ, and it allowed me to bring up the main menu screeen of my game, but I can't seem to select a character and get going.
Any suggestions?
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #6 on: February 19, 2007, 11:12:53 pm »
Are you trying the D-pad and the analog stick. I know you probably have, but sometimes it's the easy stuff.
Quote from: saint
saint is all powerful.
Apparently he is.
bsoder52
« Reply #7 on: February 20, 2007, 08:38:00 pm »
I'm using a hacked controller with arcade controls, there is no anology (spinner control), only the LRUD inputs.
horseboy
« Reply #8 on: February 20, 2007, 09:42:26 pm »
Well analog isn't a spinner.  :dunno
Anyhow you might try a regular controller to see if you have to use the analog stick to select a character. I am begining to think that this IS your problem here.
Quote from: saint
Apparently he is.
« Reply #9 on: February 21, 2007, 05:45:24 am »
The analog control can be hacked.  However, what you get is "full on" or "full off".  Nothing in between.  Also, are you sure that your hack is working properly?
If its not a Haruman Quality Hack (Tm), you could have problems...   :P
« Reply #10 on: February 21, 2007, 08:40:38 am »
You're converting it to a digtal control if that is the case.
« Reply #11 on: February 21, 2007, 10:12:21 am »
Yes.  This would allow you to play games that require use of the analog control, such as Beserk.
« Reply #12 on: February 21, 2007, 10:44:08 am »
But not in the way that they were meant to be played.  Does that often cause issues with in game abilities?
« Reply #13 on: February 21, 2007, 01:09:18 pm »
It could.  To be honest, the only game I've played on the DC that requires use of the analog stick is Beserk.
horseboy
« Reply #14 on: February 21, 2007, 01:54:13 pm »
Required, maybe... useful is a different story.
Take Gauntlet Legends for example. You can have a perfectly fun game using just the d-pad, but it is much much better with the analog stick. Running full speed all the time can screw you big time, like if you have to walk right up to a ledge/enemy/etc. If you are going full-on, you can overshoot it.
Virtual Tennis is the same way. Running full-on can make you overshoot the ball. Not enough to miss the ball all the time, but enough to where you can't have precision placement over where you hit the ball. (Someone on here a while back said VT didn't utilize the analog controls, but this is just not true.)
There are many more games with these same kinds of problems.
Quote from: saint
Apparently he is.
Grasshopper
  • Last login:September 23, 2026, 03:46:37 pm
« Reply #15 on: February 21, 2007, 02:05:43 pm »
Are you sure about that? Virtua Tennis is an arcade port and the arcade version definitely uses a digital joystick.
