Author Topic: MAME Ms. Pac Man Issue  (Read 2794 times)
FrizzleFried
    • Idaho Garagecade
« on: December 27, 2006, 12:41:59 pm »
OK...I have been playing Ms. Pac Man for  years and this never happened once,  so it has GOT to be a MAME thing.
...I go through ghosts.  Thats right...3 times now I have been able to simply glide through a ghost.  It seems it happens when being chased and pulling a 180 degree reverse right through the sucker.
This has happened only on my MAME .108 vertical cabinet...I have yet to experience the same issue on my horizontal cabinet (but I don't play Ms. Pac on it any longer).
Anyone know of a documented issue with Ms. Pac with Mame .108?   I REALLY don't want to change versions...and lose all my hiscores....again.
Hoopz
  • Last login:April 14, 2026, 11:47:32 pm
  • Intellivision Rocks!
Re: MAME Ms. Pac Man Issue
« Reply #1 on: December 27, 2006, 12:48:08 pm »
I think it does NOT have to be a MAME thing.  I know that in playing both Pac Man and Ms. Pac Man, that going through ghosts is something that does happen on original boards.
Dav
  • Last login:March 29, 2016, 05:39:35 am
« Reply #2 on: December 27, 2006, 01:46:51 pm »
This is correct behavior.  The collision detection works by keeping track of what 8x8 pixel square all the objects are on.   So if you step off of your square onto a ghosts square and he steps off his square and on to yours simultaneously you didn't ever occupy the same square.
Dave
Donkey_Kong
    • CNC Machines
« Reply #3 on: December 27, 2006, 01:57:05 pm »
Frizzle- Happens frequently back then (80's) and now on MAME. I like Davs technical explanation myself & I just thought I would chime in to reinforce that the behavior is normal.  ;D
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: December 27, 2006, 02:32:39 pm »
That is bloomin' strange....I must have pumped a couple hundred dollars in to Ms. Pac Man over the years and never once experienced that bug...
...and I can appreciate the technical explaination...and that would work if we were taking about an 8 pixel max opject....but I don't think that is the case here...anything larger than the size of the space being reported (in this case 8 pixels) would not 100% swap spaces and would therefore cause a collision detection...right?
That said,  it is obviously normal behavior,  but perhaps not exactly for the reason Dev stated.
Dav
« Reply #5 on: December 27, 2006, 03:40:19 pm »
Regardless of the size of the sprite it has an exact pixel point coordinate location.  It doesn't check all points on the sprite; only the origin point of the sprite is converted to the grid squares.
That's also the reason why sometimes you barely touch a ghost and die and other times you can be partially engulfed and still survive.
The reason most people don't see it is they don't usually charge head first into a ghost.
« Last Edit: December 27, 2006, 03:57:57 pm by Dav »
Hoopz
« Reply #6 on: December 27, 2006, 05:34:03 pm »
Hence why I see it all the time!   ;D
ppilot
  • Last login:January 06, 2020, 01:33:27 pm
« Reply #7 on: December 28, 2006, 12:05:01 pm »
This is known as a 'booey', and there are even patterns that take advantage of it (I know a 9-key pacman pattern that has 4 booeys in it, it's great fun.)  More info here:
http://www.twingalaxies.com/forums/viewtopic.php?t=5727&view=next&sid=97bf758352a15ca0250daf2188d1196e
FrizzleFried
    • Idaho Garagecade
« Reply #8 on: December 28, 2006, 12:32:17 pm »
I dunno...I played a game this morning where it happened twice in a single game...and once when my Ms. Pac traveled a good inch toward the ghost first (not a direct switch of directions).
Being I don't think I had ever saw it before ... and now it is happening multiple times in a single game...something's GOTTA be up.
Hoopz
« Reply #9 on: December 28, 2006, 12:38:16 pm »
Why not post this over at the Mameworld forums???  >:D   :laugh2:
Seriously, why do you think it HAS to be a problem with Mame? Did you read the posting on the link at Twin Galaxies?
FrizzleFried
    • Idaho Garagecade
« Reply #10 on: December 28, 2006, 01:07:30 pm »
Mameworld forums is a touchy subject with me...
...and I did read the Twin Galaxies link...interesting stuff for sure.  I just find it to be quite out of the ordinary that for countless years I had not experienced this bug,  now I have seen it 5 times in a week,  twice in one game.
I guess it is my lucky week or something...because I had played Ms. Pac on my cabinet at least a hundred times prior without it happening.
Maybe I should go buy a lotto ticket today...
Thenasty
  • Trade Count: (+17)
  • Last login:April 18, 2026, 07:53:36 am
« Reply #11 on: December 29, 2006, 08:12:10 pm »
You're catching up now......
Good luck.... Don't forget us BYOAC users :)
Free VGA Breakout Cable
