Author Topic: Simpsons Bowling and MAME 0.110  (Read 13157 times)
jcroach
  • Last login:March 31, 2026, 12:26:11 pm
« on: November 16, 2006, 10:09:19 am »
Hello,
I'm sorry if this has been asked and answered, but I'm having issues with Simpsons Bowling.  I recently upgraded from Mame 0.095 to 0.110.  It was working in 0.095, but is not now in 0.110.
Yes, I know about the resetting technique with Simpsons Bowling from the Mame.net FAQ. "A: To re-initialize the EEPROM, hold down the test switch (F2) and tap reset (F3) once. Do not let go of F2 until you see a message that says "Initializing EEPROM"."
When I do this, I get a messege that that reads "Flash-ROM write error."
MAWS says that Simpsons Bowling was last changed in version 0.109 but I can't find what the change was.  Just as a precaution, I deleated the simpbowl.nv file and aquired a new ROM and CHD image and I still have the same error.
Anyone else having this error?  Any solutions I'm missing?
jcroach
Re: Simpsons Bowling and MAME 0.110
« Reply #1 on: November 20, 2006, 08:46:10 am »
****** bump ******
Can't anyone help me with this? I'm I the only one having this issue or is the game just not working anymore?
jcroach
« Reply #2 on: November 22, 2006, 08:26:37 am »
 :banghead: Last night I tried deleting all created files again, like .cfg and .nv and I created a new mame.ini
Still no luck!  This is my last bump.  Can anyone give me some advice?
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« Reply #3 on: November 22, 2006, 09:41:40 am »
maybe try a new rom and chd set for the game
« Last Edit: November 22, 2006, 09:43:14 am by MAME TIME »
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Thenasty
  • Trade Count: (+17)
  • Last login:April 18, 2026, 07:53:36 am
« Reply #4 on: November 22, 2006, 09:52:53 am »
its probably this
999a01.7e  524288  ad498d2d  konamigv
this was the only changed I belive that I see in 109+
you probably have an old one (BIOS)
Free VGA Breakout Cable
jcroach
« Reply #5 on: November 22, 2006, 10:19:13 am »
its probably this
Thank you!  I hope this works.  If it did, the solution was staring me right in the face!
As Homer would say "Ooohhh, Bios file?! Doh!"
Fluffy the Bear
  • Last login:October 19, 2007, 11:17:06 am
« Reply #6 on: January 18, 2007, 03:24:42 pm »
I've never tried the Simpsons Bowling until last week
No Dice !
The trick with the F2 and the F3 wouldn't work as is couldn't write the file it wanted to under .111 mame
Many hours, redownloads, 3 computers later----------I found someone with .087 mame, downloaded it and the file wrote the first time and the game booted right up - same roms and chd
One of the upgrades inadvertantly changed mame so it can never write this file and thusly starting with an unwritten eeprom file and the new mame you will not be playing the Simpsons Bowling until you figure this out or read this right now
 :soapbox:
jcroach
« Reply #7 on: January 18, 2007, 04:29:18 pm »
No Dice !
 :soapbox:
This is a known bug that is apparently now fixed in Mame 0.111u4
http://mamedev.org/updates/whatsnew_0111u4.txt
MAMETesters Bugs Fixed
simpbowl0110u2yel [R. Belmont]
arcadiac0111u3yel [Ernesto Corvi]
mcatadv0111u3gre [David Haywood]
photoy2k0111u3yel [Aaron Giles]
Fluffy the Bear
« Reply #8 on: February 10, 2007, 04:12:33 pm »
Well,
Scooby-Dooby-Doo!
It does work now
These guys are goooo-ooood!
 :dizzy:
sewerrat
  • Last login:February 12, 2009, 11:53:11 am
« Reply #9 on: February 11, 2007, 01:05:43 pm »
If I'm running .111 mame and the associated Roms, can I just but .111u4 on to fix the problem, or do I need to do something with the Roms as well?
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« Reply #10 on: February 12, 2007, 11:50:32 am »
If this game run ok before this bug, you only need 0.111u4 or above.
sewerrat
« Reply #11 on: February 12, 2007, 02:01:50 pm »
Upraded and all is well.
