Author Topic: Can someone recommend a good CPU temperature program?  (Read 1184 times)
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« on: August 18, 2006, 05:43:18 pm »
I'm getting concerned that my PC is running hot.  Does anyone know of or use a freeware program that gauges a PC's temperature?  Recommendations appreciated!
MikeDeuce
  • Last login:September 15, 2013, 04:38:38 pm
  • It does a body good.
Re: Can someone recommend a good CPU temperature program?
« Reply #1 on: August 18, 2006, 06:04:50 pm »
Give speedfan a whirl:
http://www.download.com/SpeedFan/3000-2094_4-10540297.html?tag=lst-0-1
It's free with no limitations. It is a little wonky with my work's dell where it doesn't work correctly right out of the box. If you have a big mass produced type computer with a lot of funky proprietary hardware it might not be ideal.
You can try everest, but they stopped developing the home version. I think their commercial versions offer 30 days:
http://www.lavalys.com/news.php?article=31&selcat=PR&lang=en
It will report lots of important statistics like gpu/chipset/cpu temps.
Hope that helps!
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #2 on: August 18, 2006, 06:34:34 pm »
If you have an Asus motherboard, I can give you the one that came with my mobo.
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
pointdablame
« Reply #3 on: August 18, 2006, 06:49:04 pm »
Motherboard Monitor.
That's not the "official" page, just one of the first google links.  Google it for more info.  It's a great little program that will let you set up failsafes if your temps get too high.  Its compatible with most mobos.
first off your and idiot
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #4 on: August 19, 2006, 06:25:23 pm »
I have Intel's program for my Intel mobo...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #5 on: August 21, 2006, 11:33:04 am »
Aida32
Not only does it give temp, but a crap load of other info about your system that you normally wouldn't be able to see.
But if your system is shutting down and you suspect it's the temp, then I use Asus Probe. It runs in the background and you can have it record a log of the temperature. So then when you get a shut-down, you reboot, check the log and if the cause of the shutdown was the temperature, you'll see a spike in the log graph ...
« Last Edit: August 21, 2006, 11:40:23 am by RayB »
NO MORE!!
