Author Topic: Template and opinions needed for 7 button layout  (Read 15785 times)
Ed ONeill
  • Last login:April 12, 2012, 10:00:16 am
    • http://home.comcast.net/~coin-opcollector/
« on: June 07, 2004, 09:44:27 pm »
Hi all,
I originally was going to use 6 buttons until I heard that it is bettter to set it up as a 7 button layout for use with the neo-geo games.
so what I am looking for is a template for a 7 button layout .
Also is it better to curve/fan  the buttons or keep them in a straight row 3 on top 4 on botton or vice versa.
Ed
Always buying Gumball/candy machines and parts email - coin-opcollector@comcast.net
Want list - Diner Pinball, hit the ice cab, tmnt controls and panel
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 07:53:36 am
Re:Template and opinions needed for 7 button layout
« Reply #1 on: June 07, 2004, 10:10:21 pm »
mine is
   x  x  x
   x  x  x
x
Free VGA Breakout Cable
Apollo
    • Eight Bells
« Reply #2 on: June 07, 2004, 10:18:49 pm »
Get 7 buttons and a joystick, mount them on cardboard, keep doing this till you get a set up that is comfortable for you, use that.
RecycledPast
  • Last login:October 09, 2011, 09:14:47 pm
    • My 2 scratch built arcade machines
« Reply #3 on: June 07, 2004, 10:23:44 pm »
Here's a 6 button template for the classic street figher setup;
http://www.arcadecontrols.com/files/Uploads/Template_Capcom_2P-6B.gif
Use that then figure out where the 7th button fits best for your thumb.
JAZ
  • Last login:August 03, 2013, 12:16:52 pm
« Reply #4 on: June 08, 2004, 01:50:17 am »
Why have a seventh button?
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #5 on: June 08, 2004, 07:47:35 am »
I think it's because NeoGeo games use a layout with the four buttons pretty much side by side like this:
http://images.webmagic.com/klov.com/images/N/nNeo_Geo_MVS.jpg
To keep that layout, but add enough buttons to play StreetFighter you'd add 3 more buttons under or above buttons 2, 3 and 4. That way you'd have your buttons in the same configuration as both NeoGeo and 6 button fighters.
I think. ?
« Last Edit: June 08, 2004, 08:24:25 am by JoyMonkey »
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: June 08, 2004, 08:09:13 am »
NOTE:  This is all personal preference and comes down to what feels right for YOU.
The best advice is probably what Apollo said about testing til you get the right feel.
Option A:
    x   x    x
    x   x    x
x
I have also seen:
   x   x   x   x
   x   x   x
Whether to curve/fan the buttons or not probably depends on how die-hard of a SF fan you are.  I never got into it a lot, and prefer the curved button layout.
Also whether the top or bottom row is button 1 (for most games) depends on preference as well.
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« Reply #7 on: June 08, 2004, 10:16:22 am »
So here's a silly question...
I went ahead and did the 7-button setup as described (but curved), ie
  X X X
  X X X
X
...and then ran into a problem.  I don't know how to wire that thumb button.  With neo-geo games that would be what, button #4?
   1 2 3
   4 5 6
 4
...but that of course duplicates buttons.  Or would it really be button 7?
   1 2 3
   4 5 6
 7
...but then the mapping would be off for any games that used it...
Basically, I'm just confused about the use of that button.  How do most people have it wired?
-->VPutz
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: June 08, 2004, 10:26:21 am »
For Neo-Geo Games - it's supposed to be
   2  3  4
1
If you don't have seven encoder inputs, you can re-use either 4, 5, 6 or 1, 2, 3, (depending on which row you plan to use with Neo-Geo) for the thumb button.  Either way, you will need to customize your inputs (ctrl.ini files) for the Neo-Geo games.
Ed ONeill
« Reply #9 on: June 08, 2004, 01:48:13 pm »
Ok so I know neo geo is :
 2 3 4
1
but when using SF it is :
1 2 3
4 5 6
Could I do this
1 2 3 4
4 5 6
That way Sf fans wouldn't have a problem and neo geo fans would have to suffer a little with having th 4 buttons in a staight row
Personally I play mostly classics but when friends/family comeover that might be a diffrent story.
Thanks in advance
ED
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: June 08, 2004, 01:51:10 pm »
Could I do this
1 2 3 4
4 5 6
Yes, I've seen that done before.  That's one of the things I was getting at.
Ed ONeill
« Reply #11 on: June 08, 2004, 02:20:05 pm »
Thanks Tiger-Heli
I haven't got my minipac yet they tried to deliver it to my house yestarday... I can't beleive the guy didn't see me in the driveway cutting wood.
I decided to make a mame machine out of a laptopbefore getting ivolved with a full cab mame machine. Sort of like a trial thing.
Anyways, I will be posting pictures in the project anouncements as soon as I get the buttons installed .
I am thinking of the names
"MAME on The MOVE" or
"Briefcase MAME"
I may take you suggestion apollo,
 However , I am curious as to who let the cat out of the bag.
How did you know my wife works for 2 major sneaker companies Converse/Nike?
I actually happen to wear size 9 which is the sample size...can you say FREEBIES.......so you can imagine how many shoe boxes are hanging around./..LOL
Signed
Ed
Apollo
    • Eight Bells
« Reply #12 on: June 08, 2004, 05:02:44 pm »
He he that's weird I was going to suggest shoe boxes, they are perfect for what I suggested.
Ed ONeill
« Reply #13 on: June 09, 2004, 02:41:08 pm »
apollo..... My  project is actually called MAME on the MOVE. It's a a portable MAME machine made out of a wine box and a laptop. So the control panel isn't much bigger than a shoebox...LOL
Ok so I used the 6 player(SF)  layout that recycled past posted and I am not sure but it seems that ths buttons are two far apart they are a 1/4 of an inch apart . I am a classics gamer, very rarely play the6 button  fighting games  so I am not  too sure.
Can anyone tell me what the measurement between their buttons is?
BTW I ended up using the template and adding the exta button on the top in a straight row .
Example
 x x x x
 x x x
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: June 09, 2004, 03:07:45 pm »
Short answer is 1.5 inches center to center.
From my old FAQ page:
Happ lists their buttons as having a 1.3-inch wide face.
Witchboard
« Reply #15 on: June 09, 2004, 03:22:08 pm »
I put mine as close as I could together.  The nuts on the back are actually touching.  What can I say, my wife has small hands. 8)
Apollo
    • Eight Bells
« Reply #16 on: June 09, 2004, 05:36:22 pm »
My button centres are exactly 1.5748" apart. That is 40mm, lol.
Ed ONeill
« Reply #17 on: June 14, 2004, 10:45:49 am »
So I went to the arcade this weekend and found a street fighter game. I wanted to measure them but all I had was a pocket full of quarters so that is how I measured. and I
Well the buttons are three quarters (thickness) between them...LOL
So I am not sure what the exact measurement is.
 thanks everyone for posting there measurements I will look closely at all my options.
Apollo....man talking about being precise, what are you using a digital tapemeasure...LOL
Signed
ED
Tiger-Heli
    • Tiger-Heli
« Reply #18 on: June 14, 2004, 11:08:16 am »
>Apollo....man talking about being precise, what are you using a >digital tapemeasure...LOL
Apollo's from one of the "land down under"'s .  I'm pretty sure he just converted from mm to inches as a convenience to us.
SoundDoc
  • Last login:January 18, 2012, 07:24:30 pm
  • I'm a Enigma!
    • DaCab!! (a work in progress)
« Reply #19 on: June 14, 2004, 11:29:34 am »
Just to throw my button layout into the mix:
http://dacab.datplace.com/images/Button%20Layout-Model.jpg
Its based on somone elses, so I can't take 100% credit.
SD
DaCab, a work in progress searching for a better name.....
http://Http://DaCab.DatPlace.com
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #20 on: June 14, 2004, 11:42:43 am »
Hi,
Here's mine ...
Hope this confuses you a little more ... helps ... I meant helps ...  ;D
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #21 on: June 14, 2004, 01:04:07 pm »
Just another 2 cents. I'm planning on:
   1 2 3
   4 5 6
1
Just edit the neogeo config for buttons 1,4,5,6 instead of 1,2,3,4
(Side note, will that WORK? don't wanna thread hijack, but while I'm on topic.....)
BYOAC users get 5% off with coupon code byoac5
Ed ONeill
« Reply #22 on: June 14, 2004, 01:27:22 pm »
 Sylentwulf ,
From what everyone has said......
The easiest way  without reconfiguring mame ,would be
1234
456
or basically like PedroSilva cp
  234
1
  56
4
But I am sure  there must be  other ways to do it.
Signed
Ed
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #23 on: June 14, 2004, 02:19:56 pm »
Sylentwulf,
Yes
http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=20534
With modification of what I said there lets say your buttons are mapped to these keypressed
  ASD
AZXC
Your default.ini file would look like
P1_BUTTON1              "KEYCODE_A"
P1_BUTTON2              "KEYCODE_S"
P1_BUTTON3              "KEYCODE_D"
P1_BUTTON4              "KEYCODE_Z"
P1_BUTTON5              "KEYCODE_X"
P1_BUTTON6              "KEYCODE_C"
your neogeo.ini file would look like
P1_BUTTON2              "KEYCODE_Z"
P1_BUTTON3              "KEYCODE_X"
P1_BUTTON4              "KEYCODE_C"
Sylentwulf
« Reply #24 on: June 14, 2004, 06:59:53 pm »
Exactly what I was thinking of, thanx poonga :)
crashwg
« Reply #25 on: June 15, 2004, 02:30:03 am »
The way I'm planning on setting it up is:
   567
 1234
But with a curve to it.  That way, all games that use 4 or less buttons will be easy to use as they're the first buttons your fingers will reach.  <-(made sense to me)  And for any games that use lets say a street fighter layout, that's easily configurable in mame.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Ed ONeill
« Reply #26 on: June 17, 2004, 07:36:52 am »
Ok so I did a couple of layouts
1234
456
Note button 4 on top row is for neo geo games
when I made the first panel the buttons were to far apart I have now done a second one which is set up the same way but closer and for some reason button 4 on the bottom row is slightly below the other so I am going to make yet another panel/layout but before I do........
 I was thinking of droping the 4 button in the top row slightly for the pinky finger , this of course would be the oposite of the original neo geo layout.
here is what I am thinking, the star represent the approximate placement of neo geo 4 th button
123
456 *
I have very limited space so To see wht my current layout/situation is .... looksat the "mame on the move" project anouncement.
I also have a dumb question :
How many neo geo games are there in mame anyways?
Ed
dvdapex
  • Last login:August 21, 2006, 05:16:42 pm
« Reply #27 on: June 17, 2004, 07:47:21 am »
What about:
Neo Geo
  234
1XX
Capcom
  123
 456
So the buttons would be:
 XXX
XXX
It would be sort of a comprimise between the Neo Geo setup and the Capcom setup.  You would only need 6 buttons.
Would the configuration drive an "average" SF player mad?
JoyMonkey
    • JoyMonkey.com
« Reply #28 on: June 17, 2004, 07:52:46 am »
In the current official Mame build (version 0.83) there are 135 NeoGeo games. Most of them don't even use all four buttons anyway; usually the fighter games make use of all four.
Tiger-Heli
    • Tiger-Heli
« Reply #29 on: June 17, 2004, 08:29:28 am »
You might not realize it, but the original Neo-Geo layout is designed for thumb, pointer, index, ring - not pointer, index, ring, pinky - so for a purist, this might not be ideal.  Of course, if you never played the actual game in the arcade, you can use whatever button you want, I just thought this might be of interest.
Ed ONeill
« Reply #30 on: June 17, 2004, 08:47:29 am »
Ok I realize that what I propose is not exactly perfect but I am trying to come up with a solution to best fit my situation.
The situation is this.......I am making a laptop (portable) mame machine and the control panel  is very small approximately 5"x15". The control panel will only be able to fit a joystick and buttons, so I want to be able to accomidate as many games/people as possible . I personally don't play fighter games, but my 6yr old son loves them,he thinks he is doing/playing more , he actually thinks playing pacman is harder than say teenage mutant ninja turtles.
I would also like to mention that I don't really know how to reconfigure the buttons in mame and the laptop will be used for other purposes than just mame so I will be simply using mame 32.79, so I am not sure i will use arcade os ,or a front end.
Anyways ...like I said there are pictures in the thread
"MAME on the MOVE" under project announcements. Please take a look and see if you can help me out.
Ed
