Author Topic: 2 coin mechs for 4 player setup  (Read 2783 times)
Hooch
  • Last login:July 25, 2004, 06:58:13 pm
« on: June 03, 2004, 04:51:50 pm »
Here is my small dillema and a few possible solutions.  Let me know what you think.  I'm building a 4 player cabinet, but I'm only going to put in a 2 player coin mechanism.  Obviously this could cause problems with players 3 and 4 (unless ofcourse I just add a button for credits, but I'm going for as much of an authentic feel as possible)  I don't plan on charging people, but I do plan on having a jar of quarters that people will have to use to play.  Here are the possible solutions
First solution is to throw both player 1&4 to coin mech 1 and 2&3 to coin mech 2.  Ofcourse then you have problems with games that will automatically throw players in the game who have credits even if they don't press start (like X-MEN).  Now that I think this through as I write it down I find more problems here than solutions.
Second solution.  Add a shift button to the control panel and hold it in while inserting quarters for player 3 or player 4.  This is the only solution that seems like it will work to me.
Am I such a newbie that I'm really missing something here, or is this a legit problem?
DaveMMR
Re:2 coin mechs for 4 player setup
« Reply #1 on: June 03, 2004, 04:55:38 pm »
I dunno - I'd just pick up a four entry coin door.
rsoandrew
  • Last login:February 24, 2018, 09:02:10 am
  • Worldwide travelling Mame Machine
    • Andrew's Arcade
« Reply #2 on: June 03, 2004, 05:57:12 pm »
I think the shift key or 4 coin door is your best bet.
If you really wanted to you could use a toggle switch to change the coin slot from player 1 to player 3 but that isn't any more authentic than the shift key.
I would just hide some buttons discretely to add credits. On my cab I used full size arcade buttons mounted to the underside CP. You still feel like you
NoOne=NBA=
« Reply #3 on: June 03, 2004, 06:16:57 pm »
The problem you would run into with the "shift key" solution is that your encoder will read ALL keypresses as shifted during the time that the shift key is down.
Unless you map ALL the other buttons to the same function shifted, as unshifted, you are going to have people that can't move while you're coining up, or people inputting function codes, etc... while you are coining up.
I think your best bet to remain at least reasonably authentic would be to wire the reject buttons on the 2-P coin door to function as Coin3 and Coin4.
Hooch
« Reply #4 on: June 03, 2004, 11:15:48 pm »
I hadn't thought about that.  I'm glad you mentioned this before I wired up.  This would definitely be a problem.
I've thought about this also.  This will probably be the way I go.  I doubt players 3 and 4 will get much use anyway, except for times when I have a group of people over at once.
My problem was that I purchased a 2 coin over/under before I realized the dilemma it would cause.
DaveMMR
« Reply #5 on: June 03, 2004, 11:20:54 pm »
Oh sorry, didn't know you already purchased the coin door.  I reread the posts and it seemed like I was being sarcastic (though I wasn't).
Of course you could pick up a second 2 coin over/under door (though I'm not sure of your measurements so I don't know if it'll fit).  But as a secondary measure, wiring up the rejects is a pretty good solution as well.
Hooch
« Reply #6 on: June 04, 2004, 12:18:35 am »
I didn't take offense.  You didn't sound rude.  At this point in the process I'm starting to become more budget conscious or else I would just purchase another coin mech.  There are a few unnecessary things I will probably put off until after the cab is finished and I have saved up some more cash, this being one of them.
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #7 on: June 04, 2004, 01:12:28 am »
You have 3 options.
1). 4 player coin mech. Although it adds to the arcade feel, I think you and your guests might find the novelty wares off quick
2). Shift button coin instert. Advantage - No need for a credit button, disadvanatage, screws up players when shift is pressed.
3). Dedicated coin Button. Advantage - no need for 4 person coin door or any door, Disadvanatage - Need a button for it.
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 07:53:36 am
« Reply #8 on: June 04, 2004, 01:28:53 pm »
This is my take on this.
If you have separate 4 players start buttons, then this should work.
Setup MAME in THOSE GAME (4-players) coin1 coin2 coin3 coin4 to be
Coin1=5 and 7    (P1 and P3)
Coin2=6 and 8    (p2 and P4)
So now when a coin is drop in player1 slot, it gives Player 1 and 3 credits and so for droping coin in slot 2, P2 and P4 gets credits.
Now If P1 is not using his credits and p3 keeps inserting coins, p1 credits just keep adding up until he uses it.
Hope you see the picture.
Free VGA Breakout Cable
SoundDoc
  • Last login:January 18, 2012, 07:24:30 pm
  • I'm a Enigma!
    • DaCab!! (a work in progress)
« Reply #9 on: June 04, 2004, 02:58:06 pm »
So your building a 4 player Control panel with only a two player coin door, Correct?
Heres an idea I've been bashing around, just to get around the need to always insert a coin in the cab I'm building:
Mount a small microswitch, or leaf switch in the coin mech, that is closed when the Coin Release is pressed.
I'm going to do that, but have it tied to the coin switch, so either a coin, or pressing the Coin Return button in cause a credit to count.
No reason you couldn't have coin return 1 count for player 3, and coin return 2 count for player 4.
Just an idea....
SoundDoc
DaCab, a work in progress searching for a better name.....
http://Http://DaCab.DatPlace.com
NoOne=NBA=
« Reply #10 on: June 04, 2004, 03:12:53 pm »
The problem with this solution, as mentioned in the initial post, is that there are certain games that will insert the player into the game automatically on coinup.
Using this method, when P-1 coins up, P-3 will also enter the game--with nobody there to control it.
Thenasty
« Reply #11 on: June 04, 2004, 03:24:27 pm »
Since he will have 4 player starts, try this way
I see, so maybe just set MAME this way
START1 = 5 and 1
START2 = 6 and 2
START3 = 7 and 3
START4 = 8 and 4
So it automatically inserts coins and start the designated player.
unclet
« Reply #12 on: June 04, 2004, 03:24:39 pm »
I got a 4-slotted coin door for my 4-player cab.    I dont charge people to play either so this is just for looks (although it would work if you drop quarters in).   I added 4 coin insert buttons (one for each player) since I did not want to make my friends have to constantly bend down to add quarters all the time.   Yeah it would be fun to add quarters during the first hour but after that I would imagine it would become an annoyance ..... my 2cents.
