Author Topic: Hantarex MTC-900 "Bluescreen"  (Read 21622 times)
0 Members and 83 Guests are viewing this topic.
gavin.prior
  • Last login:October 19, 2026, 05:11:20 pm
« on: September 26, 2026, 07:20:20 am »
Hi guys,
I'm a long time member - been on and off for about 20 years or so now  :o - I've acquired a couple more cabinets since my last visit and one of them has a Hantarex MTC 900 monitor which has been fine for a while then started to have minor issues like the picture being a bit "jittery" and grey lines across the screen and now has gone completely blue. :(
Ideally I'd like to keep the monitor if it's a relatively easy/cheap fix but obviously there's a cut off point where it's just not financially feasible to do so. It's in a MAME cabinet and not in an original pacman cabinet or anything so could go TFT but like I said, I would like to salvage it if at all (financially) possible.
Gavin.
gavin.prior
Re: Hantarex MTC-900 "Bluescreen"
« Reply #1 on: October 09, 2026, 09:41:47 am »
Any monitor experts remaining? I just need to know if it's salvageable or if I should bin it.
Gavin.
grantspain
  • Last login:Today at 02:58:36 am
« Reply #2 on: October 10, 2026, 06:57:12 am »
900 suffer badly from leaky transistors and corroded diodes in colour circuit
first thing to do is desolder the blue gun pin on the crt socket or lift one side of resistor on that pin, if blue screen is resolved then check/replace all diodes and transistor on blue circuit
is this a 900 or 900e or 900usa ?
gavin.prior
« Reply #3 on: October 10, 2026, 02:29:31 pm »
Hi and thanks for the reply :)
Not too sure on the model but looking from the back of the monitor, the left hand side PCB is PE06, the right hand side is DF04 and the neck board is NE04.
Does that help?
As you can probably tell, it's not my area of expertise but I did manage to discharge it without killing myself!  ;D
Gavin.
« Last Edit: October 10, 2026, 03:19:40 pm by gavin.prior »
grantspain
« Reply #4 on: October 13, 2026, 03:17:05 pm »
a photo of the chassis would be helpful
gavin.prior
« Reply #5 on: October 19, 2026, 04:59:16 pm »
OK finally got round to getting some pics. Hope they are OK?
grantspain
« Reply #6 on: October 19, 2026, 05:01:25 pm »
its a 900e, probably means you are in the uk or ireland
gavin.prior
« Reply #7 on: October 19, 2026, 05:06:53 pm »
Yep UK :)
gavin.prior
« Reply #8 on: October 19, 2026, 05:08:36 pm »
Another
gavin.prior
« Reply #9 on: October 19, 2026, 05:09:17 pm »
Back
gavin.prior
« Reply #10 on: October 19, 2026, 05:10:19 pm »
Neck
grantspain
« Reply #11 on: Yesterday at 03:36:52 am »
i do fix these and i am in the uk
if you want to have a go yourself then the following need replacing/checking but first lift one side of R143 to check the function of the other colours
RV4, RV5
D10, D18
TR27, TR28, TR26
All of these are on the neck card, the diodes and pots often corrode and the transistors go leaky
There are components on the main chassis that also fail but in general its the neck card where the problem lies
