Author Topic: CRT Emudriver - Non emulated compatible games  (Read 783656 times)
0 Members and 10 Guests are viewing this topic.
Recapnation
  • Last login:May 03, 2026, 05:29:57 am
    • Eiusdemmodi
Re: CRT Emudriver - Non emulated compatible games
« Reply #360 on: April 26, 2026, 12:36:39 pm »
So what am I missing here, how do I create a "4:3 from 16:9" modeline correctly? Thanks in advance!
Honestly man, some of the language used in this thread is a bit nonsensical.
854x480 is a 16:9 resolution, assuming square pixels
The problem is that Blasphemous' design resolution is 640 * 360 despite the information in this thread, which I'm seeing still persists to this day in the idea that out-of-spec graphics should be scaled to *fit* into 15 kHz progressive no matter what.
tisurame
  • Last login:July 08, 2026, 08:44:22 pm
« Reply #361 on: April 29, 2026, 09:26:27 am »
854x480 is a 16:9 resolution, assuming square pixels (which you should always assume square pixels unless you know the game doesn't use square pixels, as is the case with NES,SNES,Genesis, etc).
So the only way to make it display 16:9 is to physically squeeze your CRT's raster. This can be done in 2 ways: if you're lucky, your TV has a "16:9" or "widescreen" mode that does this. Or, if you're unlucky, you just have to learn how to get in and out of your service menu quickly to reduce V-size.
In this world of playing modern pixel art games on CRT, you have to be cognizant of two things: the game's native pixel resolution, and the aspect ratio.
An easy example: Celeste. It's 320x180 16:9. Well that just so happens to be exactly the 16:9 area of a 4:3 320x240 image. So you simply have your desktop at 320x240 when you launch the game.
a bit more complex example: Blazing Chrome is 427x240 16:9. To play that, you have to have your desktop at 427x240 and then trigger your CRT's 16:9 mode.
This is really the only way to have games look like they're supposed to.
In your example of Blasphemous, that game is really too-high resolution for a CRT TV. It's 640x360p 16:9. You can technically play it just by running 640x480i, and you will essentially have an integer scaled 360i in the middle of that. But that's going to look odd, because A) no scanlines and B) because of interlacing you're only seeing half of the pixels in any given frame. So that game is best played on a PC CRT monitor, which can support 480p. Some HD CRT TV's could theoretically display it well too
The truth is that PC CRT monitors are the best for reproducing all these games. In games that run only at 60Hz, you can take any low resolution, scale it to twice the original resolution, and insert black scanlines. The loss of contrast caused by the scanlines can be compensated by using an external amplifier or simply increasing the monitor’s color gain.
If the game supports frequencies above 60Hz, you can display the original resolution at a higher frequency and get natural scanlines.
PC monitors also store geometry settings based on frequency. Whenever I switch resolutions to accommodate a widescreen game, my monitor automatically reduces the vertical size of the image as well.
CRTFTW
  • Last login:October 08, 2026, 06:37:46 pm
« Reply #362 on: April 29, 2026, 07:10:36 pm »
Yep, essentially this is how it breaks down for me:
640x360p games: play letterboxed in 640x480 on my PC monitor.
270p games: if the framerate is unlocked, play at 55hz on my 15kHz CRT. But if they're 60fps locked, they usually stutter at 55hz, so I'll have to play them on my PC CRT at some mulitiple of 270 with a Reshade scanline overlay
240p and 180p: play on the 15kHz CRT
Rion
  • Last login:September 27, 2026, 07:43:14 am
  • 240p, 480i
« Reply #363 on: May 01, 2026, 08:56:42 am »
I think there are a few different things being mixed together here, so I want to clarify my intention with the thread and with the entries I have added.
First, I do understand the technical points being made here.
Yes, a game’s native/design resolution matters.
Yes, aspect ratio matters.
Yes, 640x360, 427x240, 320x180, 270p, 240p, etc. all need to be treated differently if the goal is strict pixel accuracy.
And yes, in many cases a PC CRT monitor is technically the better display for modern pixel-art games that target resolutions above what a 15 kHz CRT TV can properly show in progressive scan.
I do not disagree with that.
But I also think it is important to remember what this thread was originally about.
Sergi / psakhis did not frame this only as a strict “native resolution or nothing” archive. He described it as a place to centralize PC games that can work well at 15 kHz, including cases where people may prefer practical 240p/progressive compromises over 480i, or where cropping/scaling can still produce a very nice result on a real CRT TV.
That is the spirit I have been trying to continue.
When I add a game here, I am not saying:
“This is the only correct way to play this game.”
I am saying:
“This is a game that can work and look good on a 15 kHz CRT setup, with these settings, for people who enjoy this kind of presentation.”
There is a difference between those two things.
For example, I fully understand that taking a higher-resolution game and fitting it into 15 kHz progressive can involve compromise. Sometimes that means losing some vertical information, sometimes it means scaling, sometimes it means accepting that it is not pixel-perfect. But for many of us using consumer CRT TVs, the goal is not always perfect preservation of the game’s internal design resolution. Sometimes the goal is simply to find games that still look good, feel good, and are enjoyable on 15 kHz hardware.
That was also why Sergi’s earlier reply to Recapnation was important to me. He clearly understood the technical trade-offs, but he still welcomed these kinds of contributions and personal preferences. He specifically appreciated people adding new titles and keeping the information alive.
So when parts of the thread are described as “nonsensical” or as if the whole approach is misinformation, I think that misses the point of what this thread was meant to be.
Technical corrections are always welcome. If a game’s true native/design resolution is wrong, then yes, absolutely, correct it. If a better modeline exists, post it. If a game is better suited for a PC CRT monitor than a 15 kHz TV, that is useful information too.
But I do not think practical 15 kHz experiments should be dismissed just because they are not the most technically perfect presentation possible.
A more useful way to document these games might be something like:
- Native/design resolution
- Intended aspect ratio
- Best “accurate” display option
- Possible 15 kHz progressive option
- Compromises involved
- Whether it is recommended for CRT TV, PC CRT monitor, or both
That way the information stays technically correct, but the thread also remains useful for people who are specifically looking for 15 kHz CRT TV options.
I have continued posting here because I wanted to keep Sergi’s work alive. That is also why I end my posts with:
“In loving memory of Sergi Clara (psakhis)”
This thread meant something to him, and it means something to me too.
So again, I am not against technical criticism.
I just hope we can keep the tone respectful and keep the purpose of the thread broad enough to include both strict accuracy and practical 15 kHz CRT experimentation.
Recapnation
    • Eiusdemmodi
« Reply #364 on: May 02, 2026, 04:49:09 pm »
You forget one:
Original refresh should not be altered.
Moreover, they're all essential.
The thing is, this:
...is going against what CRT Tools are or missing why they were born. They exist precisely to preserve the graphics' integrity and refresh rate in every case, even if that implies dealing with stupidly ugly, heavy, and prone to break display devices in 2026. These apologetic 'sometimes losing this or that' lines and the way the subject's been presented in this thread since the beginning is just hiding the fact that you just justify an artistic breakage with a lack of will or means, no matter who's the author.
Which is fine if that works for yourself as I've already said, but please, keep away any possible notch of proselytism.
This thread here in this subforum (against say, Reddit or whatever), before contemplating non-solutions as scaling, cropping, or downspeeding should, first and foremost, make clear for every concerning case what's the proper solution and even encourage the people to get themselves a 25/31-kHz CRT while they're still there. And then, eventually, as a just-for-fun? take in a far corner of the post, maybe mentioning the 15-kHz aberration as such. Obviously, most regulars here don't need any lecture on which is an aberrant technique, but what you seem to obviate is the need of making a thread like this in a place like this actually newbie-friendly so that these don't get miseducated by believing aberrant techniques are not such a thing when finding out how this thread (which, other than that, is neat and cool) promotes them or euphemistically calls them "experiments".
In other words, a more technical approach instead of a personal convenience one was never an option.
Rion
  • 240p, 480i
« Reply #365 on: May 02, 2026, 07:42:48 pm »
You forget one:
The thing is, this:
I am going to be very direct here, because I think the tone in some of these replies is becoming unfair to what this thread actually was.
Nobody here is denying that native/design resolution matters.
Nobody here is denying that aspect ratio matters.
Nobody here is denying that a PC CRT monitor can often be the more technically accurate option for modern pixel-art PC games.
That is not the disagreement.
The disagreement is that some replies are treating practical 15 kHz CRT TV setups as if they are automatically “nonsense” or “misinformation” just because they involve compromise.
That is not fair, and it is not how Sergi / psakhis framed this thread.
Sergi clearly understood the technical trade-offs.
He talked about people preferring 240p/progressive over 480i, about cropping some games to stay at 60 Hz, and about personal preference when using 15 kHz hardware.
He also welcomed new game contributions.
So when this thread is now treated as if it should only contain perfect native-resolution reproduction, that is rewriting the purpose of the thread.
I am not posting these games as “the objectively correct way” to play them.
I am posting them as practical 15 kHz options that can look good and be enjoyable on a real CRT TV.
There is a big difference.
But dismissing the whole idea of fitting some modern games into 15 kHz progressive as “nonsense” or “misinformation” is not useful.
It just shuts down the kind of experimentation this thread was built around.
But please do not confuse technical correction with dismissing the whole purpose of the thread.
Digitech
  • Last login:September 10, 2026, 03:21:15 pm
« Reply #366 on: May 03, 2026, 01:41:30 am »
[/quote]
Thanks a lot for the time and effort to help us enhance and improve ways of enjoying new "old" games brother, any person that do the things he loves with passion are always very welcome
Recapnation
    • Eiusdemmodi
« Reply #367 on: May 03, 2026, 05:23:19 am »
Agreed. But it's even more unfair what you're doing with the games' art. Or even with the subforum's intent, for that matter. Think about it -- on the uppermost floor here, it's always about the games, not about the members.
« Last Edit: May 03, 2026, 05:26:00 am by Recapnation »
CRTFTW
« Reply #368 on: May 04, 2026, 07:32:44 pm »
Yeah I'm fine with whatever just as long as there is some sort of disclaimer like "not pixel perfect".
Just because I think objectively those experiences are not on the same level as the games where you can get pixel perfect presentation, where it legit looks like you have a 16-bit console or arcade machine connected.
And it also serves an educational purpose, I think. Newcomers might not understand exactly why pixel perfection is important, because they have seen good examples and counterexamples in real life.
darknezz19
  • Last login:August 14, 2026, 12:33:48 am
« Reply #369 on: July 05, 2026, 03:23:05 am »
Can anyone give me some advice on how to find the resolution for Final Fantasy Vi Pixel Remaster? I tried with special K, but the injection causes the game to crash in the first 5 seconds.
CRTFTW
« Reply #370 on: July 05, 2026, 12:09:20 pm »
I would try a injection delay, like 5 second, if you're doing automatic injection.
But failing that, what I did in the past was take a screenshot, paste in Paint, it would show the resolution, but then I'd have to manually count the pixels on the border to subtract that.
Instead, the move is probably to find a screenshot tool that doesn't also capture the border, then when you paste into Paint you'll see the exact resolution (assuming you're in x1 mode)
darknezz19
« Reply #371 on: July 05, 2026, 01:04:39 pm »
That's one of the problems. When you select windowed display mode in the game, it just populates whats available to the OS through EDID in the resolution selection.
Edit: I ripped assets from the data bundle file with https://github.com/Perfare/AssetStudio
One fight background sprite that stood out to me was displaying 472x232 lines, so we tried that. It's not perfect, but better than all the other resolutions so far. Out of ideas on how to find the native resolution.
« Last Edit: July 05, 2026, 03:25:51 pm by darknezz19 »
solange
  • Last login:August 11, 2026, 04:39:13 pm
« Reply #372 on: July 05, 2026, 07:59:41 pm »
Going by the screenshot from the steam page FF6 remaster seems to be 216p. For the backgrounds and characters at least.
You can just count the pixels, or open a screenshot in paint and trace one pixel with the square selection tool. It's 5x5 pixels in a 1080p screenshot.
