Author Topic: Bartop Mame Build, what do i need  (Read 2708 times)
tsomo2000
  • Last login:November 28, 2012, 11:30:10 am
« on: November 11, 2012, 03:11:54 pm »
Hi All
Thinking of building myself a bartop, 2 player mame cabinet and just wondered if anyone could lend me a bit of helpful advice.
From doing a bit of research it looks like a i need the following bits:
A PC
A TFT monitor (19" should do it)
Plywood and various fixings/screws
2x joysticks and buttons
I would be looking to play mostly oldskool games, TMNT, Final Fight, MK etc, so nothing too processor hungry.
I have had a look on ebay for various bits it looks like i can get a set of joysticks, and numerous buttons, the biggest question i have is how do i wire these buttons and joysticks up to the PC?
What sort of front end would be best to use, I remember using MAME32 ages ago, and Mala recently, i would like it to boot as soon as the PC is turned on?
Can the PC be configured so it is turned on/off with the press of a 'power button' on the mame cab?
Can you set up the joystick buttons to enable you to alter game modes/menus - for difficulty levels in games?
Thinking the classic 6 button configuration would be good enough for me, it would allow me to play the majority of fighters out there.
Thanks v much from a newbie.
dextercf
  • [thisispersonal]
« Reply #1 on: November 11, 2012, 03:46:50 pm »
To answer your topic; patiance, persurverance and the search button.
Godspeed!
  • Last login:Today at 07:23:14 am
Re: Bartop Mame Build, what do i need
« Reply #2 on: November 11, 2012, 06:00:32 pm »
Welcome aboard, Tsomo2000.
Before you get your heart set on eBay for parts, you may want to look at Ultimarc, Groovy Game Gear, and Paradise Arcade Shop a.k.a. the "Big Three" suppliers.  All of them are great and the business owners are active here on the forums.
For how to connect to the PC, check out wiring and encoders in the wiki then go here.
Yes, here's one example.
Umm, what game do you have in mind?  Some had dip switches that set the difficulty.
Slagcoin is your friend.
Godspeed!
 :laugh2:  Quite true, Dex.  Read the stickies and recent topics and you'll be able to ask questions that are more sniper than shotgun and less likely to produce :angry:.
ark_ader
  • I glow in the dark.
« Reply #3 on: November 11, 2012, 06:30:00 pm »
The ability to be able to finish what you started.   :o
paigeoliver
  • Awesome face!
« Reply #4 on: November 11, 2012, 09:45:41 pm »
Bartops are not the absolute best for 2 player fighters or two player games in general, as they can be very cramped.
BobA
  • What Me Worry?
« Reply #5 on: November 11, 2012, 10:05:57 pm »
To have a playable 2 player bartop your control panel should be wider then the actual bartop body or you can innovate and have a separate CP for the second player or 2 bartops with only a single computer. (It has been done before and it was great)
« Reply #6 on: November 11, 2012, 10:10:56 pm »
One other thing to consider is the layout of the buttons. MK uses a layout with 5 buttons while MK3 uses a layout with 6 buttons in a unique configuration.
I built a 2 player bartop with a 24" control panel. In the end, I think a full size makes more sense for a 2 player bartop. You can check out the Widowmaker bartop in my sig and look at the pic of it on the 36" round table.
rCadeGaming
  • Just call me Rob!
« Reply #7 on: November 11, 2012, 11:29:35 pm »
+1
+1
Be careful of the input lag with the flat screen.  If it's bad it will hamper the feel of the games.
http://shoryuken.com/forum/index.php?threads/sub-1-frame-hdtv-monitor-input-lag-database.145141/
Edit:  That link seems to have stopped working, here's a new one
http://forums.shoryuken.com/discussion/145141/sub-1-frame-hdtvmonitor-input-lag-database/p1
When shopping, be aware that response time is not the same as input lag.
« Last Edit: February 19, 2013, 07:01:23 pm by rCadeGaming »
tsomo2000
« Reply #8 on: November 12, 2012, 11:21:59 am »
Thanks for all the replys guys. It will give me some good reading for the night ahead.
Thanks again.
dextercf
  • [thisispersonal]
« Reply #9 on: November 12, 2012, 04:49:17 pm »
Also, have you ordered the book yet?
darthpaul
  • Last login:Yesterday at 08:22:27 am
  • Join, It's your duty
« Reply #10 on: November 17, 2012, 11:55:41 pm »
Or in other words, finish one project before starting another. :D
Sith Pedestal
Automated Cabinet
Nintendo Pi
PiCubed
