Author Topic: Daphne joystick mapping help  (Read 11947 times)
mytymaus007
« on: April 18, 2010, 11:48:45 am »
Does anyone know how to map joystick and buttons to GP-Wiz40 MAX USB. IM in the Daphne loader and when i press change to configure the joystick and buttons i get nothing. Everything is connected because Mame is working perfect. Any ideas!
mytymaus007
Re: Daphne joystick mapping help
« Reply #1 on: April 18, 2010, 03:33:33 pm »
anyone :banghead:
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: April 18, 2010, 03:47:44 pm »
anyone :banghead:
You expect an answer in less than 4 hours... on a sunday morning?
NO MORE!!
mytymaus007
« Reply #3 on: April 18, 2010, 04:44:41 pm »
anyone :banghead:
didnt know there was an estimate time frame on Sundays ill mark that down for next Sunday
Havok
  • Trade Count: (+17)
« Reply #4 on: April 19, 2010, 02:01:32 am »
Daphne's joystick support sucks. That's one reason why I'm happy to see Mame start supporting all the LD games. If it doesn't register, then you're SOL. Switch to a keyboard encoder and you'll be golden.
mytymaus007
« Reply #5 on: April 19, 2010, 08:37:57 am »
what LD games is mame supporting i didnt realize that
Havok
« Reply #6 on: April 19, 2010, 09:00:00 am »
So far the games are:
Cliff Hanger
Cobra Command
Cube Quest
Firefox
Mach 3
Us vs. Them
If you watch the what's new Mame updates, you'll see the groundwork is being laid for quite a few more.
The only drawback to using Mame is that they decided on a more accurate save of the laser disk. So, instead of an mpeg1 looking file like Daphne has, the Mame ones are CHD, and much larger; the average Mame laser video size is about 13GB.
crashwg
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Havok
« Reply #8 on: April 19, 2010, 11:37:47 am »
http://www.electracode.com/4/joy2key/JoyToKey%20English%20Version.htm
Good suggestion, but doesn't always work 100% That's your best option, short of changing out the encoder...
bkenobi
« Reply #9 on: April 19, 2010, 11:43:23 am »
XPadder is a nice option too.  I personally like it better than Joy2Key.
http://www.xpadder.com/
isucamper
    • my project arcade blog
« Reply #10 on: April 19, 2010, 12:14:21 pm »
I should have come in here sooner.  This isn't true.
How many joysticks are on your system?  Go into Gamepads and see how many are registered.  Daphne will want to use the first one in the list.  However, you can make it use any one you want.
This is from memory... but try it out.  Go into your gamepad list in the control panel.  Highlight the GPWiz and click the "Advanced" button.  Set the preferred device to your GPWiz.
Bam.  Daphne should see it.
The only thing Daphne can't do is use more than one gamepad device at once.  So if you have GPWiz and a flightstick, you can't have Daphne see them both.  Or, like on my system, I have my preferred device set as my U360, but then I don't get the admin buttons that are on my GPWiz.  I've got to use joy2key for those.
THE SYSTEM          Popeye
Havok
« Reply #11 on: April 19, 2010, 01:45:20 pm »
I should qualify my original statement; it depends in your setup and button requirements. I am speaking from experience, using a GPWiz.  My original setup with a GPWiz (and no other gamepad or joystick, just a keyboard encoder) would work great with the directionals, however would not map the buttons properly. It just wouldn't see some of the buttons.
isucamper
« Reply #12 on: April 19, 2010, 03:31:58 pm »
Hmm... that could be.  Maybe it only recognizes buttons 1-16 or something. MAME actually has a little hiccup with buttons 14-16.
THE SYSTEM          Popeye
mytymaus007
« Reply #13 on: April 19, 2010, 06:01:21 pm »
Yes it only recognizes the button when i configure up and down i get nothing. Anyone else try this. Might have to get an ipac
Zebidee
  • Trade Count: (+9)
  • Last login:April 18, 2026, 05:10:15 am
« Reply #14 on: April 20, 2010, 09:55:49 pm »
Check out this thread for setting up Daphneloader to work:
http://forum.arcadecontrols.com/index.php?topic=66957.0
It should work with default Mame keysettings - no need for joy2key etc. Only caveat is that I did this three years ago. I still use it today, but have not updated Daphneloader to the latest either.
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #15 on: May 01, 2010, 04:31:07 pm »
In windows 7 where do you find the gamepad setting i cannot find in the control panel
thanks
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Havok
« Reply #16 on: May 01, 2010, 04:34:06 pm »
thanks
Start, Devices and Printers...
divemaster127
« Reply #17 on: May 07, 2010, 10:59:14 am »
ok, went to gamepads in windows 7 there is no advanced nor can you adjust the gamepad settings.  Any ideas, i wish i had known this beforehand I would have used a ipac
northerngames
  • Trade Count: (+18)
« Reply #18 on: May 07, 2010, 11:47:42 am »
the ipac's are the only encoder I will ever use I have never had any problems or flaw's with them hooking them up or using them with any software.
the mini-pac was another story and I wont use them anymore but the ipac's are the way to go.
Havok
« Reply #19 on: May 07, 2010, 02:23:27 pm »
Like I said earlier, a keyboard encoder is the only way to go for full support in Daphne. I would use an IPAC or KeyWiz instead.
mytymaus007
« Reply #20 on: May 07, 2010, 05:19:24 pm »
No doubt anyone want to trade a  ipac for an GPWIz
Zebidee
  • Trade Count: (+9)
« Reply #21 on: May 07, 2010, 06:26:23 pm »
Get an ipac, then visit this thread
Download the files/follow the instructions.
