Author Topic: Video Rolling in XBMC with J-Pac  (Read 1152 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: January 27, 2010, 04:30:39 pm »
...finally found a minute today to try out my J-Pac (only had it for getting on a year! ::)) Anyway... finally 'kind of' got it set up... however, I'm using a modded Xbox and XBMC is the only thing that is causing me problems... the video rolls on it... everything else is okay... splash screen is fine... anything else I run is fine (i.e. emulators), it's just XBMC that isn't fine. So I'm guessing it's not syncing. I've tried setting the original dash to Pal-60 - nothing changed... I've tried changing XBMC's resolution to Pal 4:3 - nothing changed - I can't figure out what else to try... any suggestions!?
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
Re: Video Rolling in XBMC with J-Pac
« Reply #1 on: January 27, 2010, 04:33:01 pm »
The spash screen on the Xbox is always 480i, as are a lot of games by default unless the MS Dash is set to a non 480i resolution.  However XBMC can internally be set to go to 480p, 720p or 1080i.  Maybe that's been set?
slapaham
« Reply #2 on: January 27, 2010, 07:09:45 pm »
Figured out - set the system to NTSC using Enigmah Video Selector... as soon as I did that, it worked beautifully! ;D
