Author Topic: How do I stop my control panel from rotating  (Read 12284 times)
unclet
« on: July 24, 2003, 12:58:26 pm »
I built a rotating control panel which has six sides (each having a different game control assembly) which sits upon a lazy-susan so the player can rotate it to select which control to use.  I need some way of "locking" the rotating control panel into place so it does not turn while playing a game.
I was going to use a simple door bolt which I could slide up/down.  When I slide it UP, it would go into a hole I drilled on the underside of the rotating control panel, thus making it impossible to rotate anymore.  Problem is, the door bolt extends only about 1-1/2 inches which is too small.
I was thinking maybe a plunger/spring mechanism would be best, but I can not find where these are sold.  Basically, you would simply pull down on the plunger, rotate the control panel, then let go of the plunger and the spring would force it back up into the hole I drilled out under the control panel.    Any ideas where I can find something like this (keep in mind it has to be mountable....)
How would you stop it from rotating?
« Last Edit: July 24, 2003, 01:16:57 pm by unclet »
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
Re:How do I stop my control panel from rotating
« Reply #1 on: July 24, 2003, 01:04:07 pm »
How 'bout mounting a Pinball Plunger? Pull back the plunger, rotate the panel, and release.  ;D
Mucal invader, is there no end to your oozing?!
unclet
« Reply #2 on: July 24, 2003, 01:08:21 pm »
Where do I get something like this and would it come with  a way to mount it up/down to some MDF?
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #3 on: July 24, 2003, 01:10:40 pm »
You can attach a pic to each post in a thread - it's at the bottom  of the little reply window.
unclet
« Reply #4 on: July 24, 2003, 01:18:02 pm »
yeah, that was easy.....guess I was simply looking somewhere else.   Anyway, I added a pic up in the original post....
Hoagie_one
  • Um....whats a cabinet
« Reply #5 on: July 24, 2003, 01:18:50 pm »
no answer for your problem but I totally dig the cab you are building.  Very cool
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #6 on: July 24, 2003, 01:34:29 pm »
You can get plungers at wico I believe.  The other thing you could do is get a solenoid, like electronic door locks.  You press a button it will release then you rotate the panel.
Do you have a site with progress?
« Last Edit: July 24, 2003, 01:58:12 pm by SirPoonga »
Frostillicus
  • Arcade Artist
« Reply #7 on: July 24, 2003, 01:39:12 pm »
I have no idea if this is feasible, but what about some type of electromagnet you can switch on and off that locks a corner of one of the panels to the base?
SirPoonga
  • Puck'em Up
« Reply #8 on: July 24, 2003, 01:45:22 pm »
that's basically what a solenoid is.  It is an electromagnet that moves a pin.  I forgot the technical names, if any, but there are solenoids that push the pin out or pull the pin in.  Depending on how it is mounted is what he'd use.  I'd mount it on the bottom so the pin goes up upon current.  Then have a NC button that will break the circuit.  The pin will fall, the panel will be able to rotate.  Let go of the button while rotating and then the pin will be forced into a pin hole as you rotate the panel.
The q*bert knocker is just a pinball solenoid that does just that.  On current it pushes the pin out.  You know that knock you get on extra balls....
A pinball solonoid is probably overkill, especially as it is 27V so getting that power to it would be tough.
« Last Edit: July 24, 2003, 01:57:58 pm by SirPoonga »
TheTick
  • I.P. Daley
« Reply #9 on: July 24, 2003, 01:45:52 pm »
That is sweeeet!
as for the hole idea.... drill one hole from the bottom and use one of those plastic hand screws like on the back of a chair. Just screw it in to apply pressure and keep from spinning.
the electromagnet lock sounds cooler though. Maybe just hook up some really strong earth magnets. If you pull at it, it will give. Otherwise it'll stay where its at.
hyiu
    • www
« Reply #10 on: July 24, 2003, 01:48:31 pm »
not much help here... sorry....
but very nice design....
I do have 1 question....
the rotating CP.... is like in the middle of that enclosure of your cab....
how big is the gap between the roatating piece and the top ?? also, the roataing piece and the bottom ??...
from what I see.... the top has a bigger gap.... the bottom is closer... right ??....
I don't have any solid solutions yet.... but if you can give us a better look on the panel part..... and probably some measurements.... maybe we could help...
SirPoonga
  • Puck'em Up
« Reply #11 on: July 24, 2003, 01:55:20 pm »
Ahh, push and pull solenoids, that's the terminology they use.
Something like this.
http://www.jameco.com/cgi-bin/ncommerce3/ProductDisplay?prmenbr=91&prrfnbr=4827&cgrfnbr=501&ctgys=
SirPoonga
  • Puck'em Up
« Reply #12 on: July 24, 2003, 01:59:59 pm »
Yeah, you can see that fromt he pic.  That square on top I assume will sit the monitor.  It is a sit down cab too, you see a part of the seat.
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #13 on: July 24, 2003, 02:02:14 pm »
that's basically what a solenoid is.  It is an electromagnet that moves a pin.  I forgot the technical anmes, if any, but there are solenoids that push the pin out or pull the pin in.  Depending on how it is mounted is what he'd use.  I'd mount it on the bottom so the pin goes up upon current.  Then have a NC button that will break the circuit.  The pin will fall, the panel will be able to rotate.  let go of the button while rotating and then the pin will be forced into a pin hole as you rotate the panel.
I've researched solenoids and I think you would want a pull solenoid that goes down when current is applied.  Otherwise, you would always have a current applied.  Since the panel is only rotated once in a while, use a NO button and apply the current while you are rotation the panel.  I am a beginner solenoid person, so is there anything I am overlooking?
What do you use to power a solenoid?  I've read about constructing solenoid driver circuits.  Can you power a DC solenoid off of a simple DC power supply (such as a laptop charger you might have lying around)?
This opinion was created from 100% post consumed information.
SirPoonga
  • Puck'em Up
« Reply #14 on: July 24, 2003, 02:04:02 pm »
there is a 5v and 12v line from your computer :)
If the current is off will the pin go out then, even under gravity?  I think most solenoids gravity will still pull the pin down without the solenoid being on for a pull solenoid.
« Last Edit: July 24, 2003, 02:06:46 pm by SirPoonga »
unclet
« Reply #15 on: July 24, 2003, 02:20:48 pm »
SirPoonga:  I will look into the solenoid route.  My air hockey table uses solenoids to release the puck, funny I never thought of using one here.   Anyway, if the plunger is long enough, this might work.
Also, this is a sitdown driving Mame cabinet which will complement my already existing/finshed 4-player Mame cabinet (see pic below).  I wanted something to play driving games in Mame as well as the Xbox driving games (ie: one of the six sides will have an XBox steering wheel attached). Also, the seat is an adjustable arcade seat from an Indy 500 cab (I think) and the 27" TV will be placed on the square of wood which you see on top.
I do not have a site with progress.  Barely find time to keep working on this cabinet.   My wife has been out of the garage for 4 months now.  Anyway, I am currently makiung the marquee and speaker housing.  I will post pics when I am done though.....probably be another 2 months
Frostillicus:    OK, this idea sounds cool, but I am not sure whether there would be enough room to mount a magnet on the underside of the rotating control panel.  I would also need to get six of them for mounting one each to the bottom of each of the six sides.  Where would you even get magnets which would resist the force of someone playing a game and trying to make sure it does not move.
hyiu:  Yes the rotating control panel is in the middle.  There is probably about a 1" clearance from the bottom and about a 2" clearance on the top.  The top clearance is more since I had to allow room for some of the assemblies which stick out above the control panel lid (ie: see how the motorcycle assembly sticks out over the top in the picture above.......also the Spy Hunter steering assembly sticks out some as well but this is not seen in the picture since it is on the other side).
« Last Edit: July 24, 2003, 02:24:54 pm by unclet »
SirPoonga
  • Puck'em Up
« Reply #16 on: July 24, 2003, 02:23:05 pm »
If it isn;t lon enough find a local welder and extend it :)
AlanS17
    • AlanS17
« Reply #17 on: July 24, 2003, 02:29:55 pm »
Why not use a latch like the type used to hold down control panels? Attach the latch underneath in front and attach a loop/ring/thingamajig to each rotating portion to lock it into place. I can't see what kind of clearance you have underneath each control, but this may be a viable option.
Another solution may be a lock like the type used in public restrooms - not the newer bar-shaped ones that just slide over, but the round ones that slide over and lock in place.
unclet
« Reply #18 on: July 24, 2003, 02:39:59 pm »
How about a picture of this latch thingamajig and a picture of the restroom thinger.   Do not know what you mean....can anyone help out here?
Also, if you know there technical "real" name, that would help if I decide to buy some.
Chris
    • Chris's MAME Cabinet
« Reply #19 on: July 24, 2003, 04:26:49 pm »
Simple.  If a door bolt is too small, use a gate bolt.
--Chris
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #20 on: July 24, 2003, 04:33:55 pm »
I was thinking of one of these (see pic below...)
You could mount this pointing up and have it go through holes in your rotating CP...
You could even spring load it if you wanted too (it would take a little ingenuity [sp?])...
Just get the biggest 1 you can and that should do the trick.
This particular 1 is at HomeDepot.com...
Home > Online Store > Hardware > Builders Hardware > Barrel Bolts & Hasps
(I'd put up a link, but HD's site doesn't play nice...)
Have fun!
By the way, WOW!!! :o
« Last Edit: July 24, 2003, 04:40:41 pm by tmasman »
I'm not a freak!...
Oh wait...
Yes I am...
tmasman
  • Hello...
« Reply #21 on: July 24, 2003, 05:03:02 pm »
You could even build your own "lock" like the pic below...
You could round off the tip of the dowel to make it easier for
it to find the holes.
With the proper handle, this could look right at home on a cabinet.
If you had problems keeping the spring in place you could mount
a piece of PVC around the lower half of the dowel.
Or you could always try & play with the solenoid idea...
a button would definately be less invasive.
I'm not a freak!...
Oh wait...
Yes I am...
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #22 on: July 24, 2003, 05:05:45 pm »
First off... Unclet - that is sweet looking.  I hope you have a large room in your house to put that thing in.  Very unique!!!!
SirPoonga - have you had experience with these solenoids?  How strong are they?  I imagine this sit down cab will get some good beatings, will the solenoid be strong enough to keep the panels from moving a bit?  I'd be interested in added these to my rotating CP, but would be afraid they wouldn't keep them locked down and steady.  It's a great idea, don't get me wrong - I'd put these in my cab in a second if someone knows if they are strong enough.  On my CP's I have a threaded pin that I screw in a bit to keep them steady - and they are so steady you would think they were permanently in that position.  Do you think a solenoid pin into a tight fitting hole would keep it as steady?  I'm thinking they might work better for me than for Unclet - I'm thinking his right to left pressure that will be on whatever anchors this down will be fairly intense during some hard driving games.
Anyway, great idea though.  I'm excited about the possibilities!!!!
:) Rotate or die! :)
Frostillicus
  • Arcade Artist
« Reply #23 on: July 24, 2003, 05:17:45 pm »
I was thinking no mechanical parts at all.  Just some plates of iron/metal under the rotating part and a strong electromagnet situated at one spot on the base.  Push a button and it stops the current so you can rotate it...let go and it activates again and latches onto the metal plate on the CP.  Hmmm..I may look into this for my panels...
SirPoonga
  • Puck'em Up
« Reply #24 on: July 24, 2003, 05:20:27 pm »
would that strong of a magnet be good near a computer?
Chris
« Reply #25 on: July 24, 2003, 05:21:44 pm »
When playing with electromagnets, remember that you have things in that cabinet that won't like strong magnetic fields: monitors, hard drives, speakers, etc.
--Chris
--Chris
REBIRTH
  • What is that?
« Reply #26 on: July 24, 2003, 05:25:06 pm »
Or ones testes? ???
SirPoonga
  • Puck'em Up
« Reply #27 on: July 24, 2003, 05:25:41 pm »
The latch, yeah.
http://free.hostdepartment.com/S/SirPoonga/images/y_cab17.jpg
Copy and paste the link in a fresh browse, stupid free sites.
Smack dab in the middle of the pic. It's how I hold my CP down.  It came from the double dragon II cabinet too.
http://www.happcontrols.com/amusement/acesor/49005900.htm
You can get it cheaper at home depot though.
« Last Edit: July 24, 2003, 05:27:01 pm by SirPoonga »
unclet
« Reply #28 on: July 24, 2003, 05:31:25 pm »
tmasman:  This was the exact bolt thing I got from Home Depot.   If only the metal rod extended past 1-1/2" long it would be perfect.   Since it does not, the actual metal casing/mount of the bolt interferes with the control panel assemblies while spinning.   If I mount it on the right side (next to where the player's right knee would be when sitting) the metal rod would not entend far enough into the rotating control panel.
You other picture seems quite involved, although I appreciate you spending the time to explain your idea.  Let me go and have another look....
AlanS17
    • AlanS17
« Reply #29 on: July 24, 2003, 05:39:14 pm »
Well tmasman basically posted the same idea I was trying to explain...
If it's not long enough you can try cutting the casing of the barrel to allow it to travel farther. Break out the Dremel!
Another idea might be a swinging hook. If you can't find one in the right size you may be able to fabricate one yourself.
I still think the control panel latches are a good idea, though. The picture I'm posting is of a newer style for wodden panels. I think the kind found with metal control panels might work better since they have a longer reach. This one seems a bit short.
Frostillicus
  • Arcade Artist
« Reply #30 on: July 24, 2003, 09:49:09 pm »
SirPoonga, Chris, Rebirth: Yeah I thought of that...yet if you think of the force being applied as attraction vs the force needed to break such a connection, they are going in perpendicular directions.  Think a 2" x 2" steel plate on the CP stuck to a magnet on the inside part of the cab.  Now you aren't going to pull the plate directly away from it, the tendency would be to slide it off as the CP rotates- which would be much harder to do.  More surface area would mean better protection against slippage and thus less necessary magnetic power (and fields).  This thing wouldn't be directly next the CPU or monitor anyways.
Well it made sense 4 beers ago...  :)
AlanS17
    • AlanS17
« Reply #31 on: July 24, 2003, 11:03:28 pm »
Well think of it this way? Which is easier: sliding a magnet across the refridgerator or pulling off? Sliding it is easier. You would need a MORE powerful magnet to hold it securely in place. Magnets scare me.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #32 on: July 25, 2003, 01:10:30 am »
I'm liking this idea!  Another unique rotating panel to add to my links...  Certainly an idea I'd never thought of!  :D
Here's another possibility--make your own plunger!
Here's the bolt I use to attach my yoke to my cab.  Basically a reverse plunger; the plunger gets pushed DOWN into a hole and then screwed in.  You could possibly use this, but better for your setup would be to put the spring on the bottom, rather than up top.  That would pull the plunger down, so the bolt engages with a hole in the TOP of your rotating assembly.  Then you pull up on the knob, spin the panels, then let the plunger go.  In that case, you don't need anything to screw it into, just a hole it drops into (you could even get a longer bolt and cut off the threaded end.)  Also, you'd probably want to use pipe solder to join the washer to the bolt, rather than the hot glue I used...
Or you could mount the same thing underneath, where it's not as easily seen.
« Last Edit: July 25, 2003, 01:12:26 am by 1UP »
My other job...
Frostillicus
  • Arcade Artist
« Reply #33 on: July 25, 2003, 07:53:52 am »
That's a refrigerator and a super-weak magnet - usually the only reason people slide them off is because they can't get a grip on it.  Not quite the same comparison.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #34 on: July 25, 2003, 09:55:14 am »
How about a "Slide Action Gate Bolt" by Stanley.
Go to Http://www.homedepot.com
Type Slide Bolt in the search box.
Click on "Gate Hardware(1)".
American Laser Games Wrapper
O2em Rom Utility
unclet
« Reply #35 on: July 25, 2003, 01:13:44 pm »
Just purchased one of those today ..... I think this might work since the bolt seems to protrude farther out than a normal door bolt lock.
thanks
AlanS17
    • AlanS17
« Reply #36 on: July 25, 2003, 01:56:36 pm »
Well even if you have a stronger magnet I'm pretty sure the same rules would apply. It's easier to slide a magnet than to remove it.
Back on topic, though, make sure that gate bolt isn't too loose.
REBIRTH
  • What is that?
« Reply #37 on: July 25, 2003, 04:21:00 pm »
I still think the only way to get it incredibly sturdy is using something that either clamps down tight or screwes in tight.  A bolt sliding into a hole just won't be as tight as a clamp/screw - unless you had something in the hole gripping the bolt somehow.  The magnet thing sounds interesting, but I am guessing that if the magnet is strong enough to hold that thing in place, it will be strong enough to wreak havok on the electrical parts of the PC/Monitor.
If you don't mind the things being visible, I sort of like the latch idea suggested above (like the one Happs sells).  You could have a fixed latch on either side of the individual control panel "spokes" (fixed on the non-moving bottom part), and on either side of every "spoke" have the metal strips the latches clamp onto.  Just unlatch, spin, re-latch.
1Up's idea is good too, I like the screw-in theory - just thinking the latch thing might be easier to install?
Frostillicus
  • Arcade Artist
« Reply #38 on: July 25, 2003, 04:32:29 pm »
I've never seen a refrigerator with a perfectly smooth surface such as a flat bar of iron, they always have a slippery painted texture to them.  Hence less actual surface area to make contact with.  I think it would be easier to just pry them apart then to slide one across the surface of another.  But it's all just conjecture, the only way to settle this is to try it  and I don't see that happening...
"We've tried nothin' and we're all outta ideas!"  -Flanders' 'D-mn Beatniks!" Parents  ;D
Xiaou2
  • Last login:Today at 12:36:46 am
  • NOM NOM NOM
« Reply #39 on: July 25, 2003, 05:09:55 pm »
 Just a note...  I once tried using 'Locking-pin'  bolts to stop my control panels from spinning... but there were some major probs with it...
 The holes have to be Perfect!  If the holes are too loose... there will be play.. and too tight will make it very hard to push in/out.   Also... if the angles are a bit off... youll have a hard time with lining up more than one pin... and again being too tight or too loose... that and finally... if you are using straight up wood - if will eventually compress and become loose over time.
 My suggestion is to use something that is much stronger... like the panel clamps that happs sells to hold control panels down.  THe extra spring tentioner that they use provides the tightest hold ever and is easy to operate.   The other methods that can be used are a custom disc-brake system... or something using a hacked locking vicegrip.
 You could possibly do the spring pin - if - you used a metal actuator and a strong precise metal brushing(? i think thats what it would be called?)  for the recieving end.   The pin itself should be fairly thick to avoid being bent from the forces... and the pin needs to have nearly no play at all inside the metal recieving end.
 As for screw-in bolt stops... I think they are too slow and painfull.
 www.xiaou2.homestead.com
