Author Topic: 2 BARTOP arcades Midway UPDATE...Bezel+Cp plexi installed...PICS inside  (Read 41877 times)
saleem
  • Last login:February 07, 2012, 08:03:39 am
its that sound coming from your video cameras mic or does your cab sound worse than my 360? only jk.
i dont know much about front ends but,it would be nice if you had no windows sounds,you know that sound you get when you boot windows and turn it off?dadadaduuun!the turncades unit i got is proper proper quiet and there are no windows sounds,you get the mame load screen where the line moves from left to right then it boots straight into mame emu.i will have to take a crappy vid when i finalize the build,i got my cp to sort now,marquee light and that led has me thinking now,then fit the pc.
thanks for the video share.
bigpete405
  • Last login:April 30, 2014, 07:48:03 pm
no problem Saleem. There is a slight wine from the speakers I mounted the power box(not sure what it's called) to close the the computer board or the speakers.. on the speaker shelf its a simple fix. :dizzy: the novamatrix led marquee light is a good one for bartops you will be happy with it if you decide to go that route.  :cheers:
bigpete405
Thanks Javier I didn't see the post until now for some reason.. will do.
bigpete405
Re: 2 BARTOP arcades Midway UPDATE...Bezel Painted...PICS inside
« Reply #83 on: March 14, 2010, 01:58:20 pm »
   Today, I got around to painting the bezel on the mini Mk cab for mysteriozone... Instead of taping and spraypainting, I decided to brush on paint instead, with execellent results none the less. Here is a couple of pics I will have more later when the paint is completely cured.
   The way I painted was light coats using a blow dryer to dry off each coat in about 10seconds, and then repeating approx 10times until it was completely black. Mysteriozone's cab is basically complete minus the artwork which he is going to print up at a later date.
   I am going to start on my personal cabinet with the blue t-molding hopefully within the next week.  :cheers:
bigpete405
« Reply #84 on: March 14, 2010, 08:45:23 pm »
more pics with bezel and cp overlay installed.  :cheers:
Mysteriozone
  • Last login:January 19, 2018, 04:38:40 pm
    • Dave Millican Belts
Re: 2 BARTOP arcades Midway UPDATE...Bezel+Cp plexi installed...PICS inside
« Reply #85 on: March 15, 2010, 02:58:20 pm »
Very impressive, at this point I'd say it's what... 95% done? Would be cool to see yours done side by side, one playing MK 1 and the other MKII. Great work! :applaud:
bigpete405
« Reply #86 on: March 15, 2010, 11:13:15 pm »
  I want to see it with at least a good marquee, and cpo... Sideart can wait, but try to get some artwork printed before you pick it up so we can take some good pictures. Mine isn't going to be done for at least a month, now that work and training is back to normal. 95% is right on the money.  :cheers:
SNAAKE
  • Trade Count: (+29)
« Reply #87 on: March 17, 2010, 10:26:35 am »
badass :cheers:
bigpete405
« Reply #88 on: March 17, 2010, 08:32:29 pm »
Thanks SNAAKE, still alot more pics and updates once I start on mine.  :cheers:
« Reply #89 on: March 18, 2010, 10:18:26 am »
any word on the guy?
bigpete405
« Reply #90 on: March 19, 2010, 10:00:19 pm »
  Whats up Malenko?, Sorry I've been so busy at my regular job I have zero free time for anything including the cnc shop. When I have that under control and make plans Ill post it up here.  :cheers:
Reptilz
  • Last login:May 01, 2011, 03:58:04 pm
« Reply #91 on: March 28, 2010, 05:29:57 pm »
Those Mini MKs are AWESOME!  Id love to get my hands on some blue prints.  GREAT JOB!
bigpete405
« Reply #92 on: March 29, 2010, 12:27:29 pm »
Thanks  :cheers: Eventually I will make plans, but I have no extra time right now.. work is crazy.
bigpete405
« Reply #93 on: April 25, 2010, 03:05:47 pm »
   Quick update.. I know its been a while, but to be honest with everyone I burnt myself out doing arcade work non stop when work was slow  :dunno. Javier (mysteriozone) picked up his cab today which I finished attaching the removeable control panel to the cabinet itself with some hardware, 7/16 nuts and bolts (2) and some brackets and phillips head screws. Javier will do the finishing touches such as speaker grills, fastening the marquee retainer (using velcro temporarly since I didnt want to drill any holes), and figuring how he wants to fasten the bezel. I hope all is good with everyone.  :cheers:
Mysteriozone
Here are some more updates:
bigpete405
Glad to see you enjoying/finishing it up :applaud: Once you get side art its going to look amazing.  :cheers:
