Author Topic: Coin door locks  (Read 4071 times)
crashdmj
  • Last login:August 26, 2003, 08:55:42 pm
  • Hulk smash!
    • Best webpage in the Universe!!
Coin door locks
« on: July 23, 2003, 01:23:19 pm »
Where can I get the coin door cylinder locks cheap? I have a 4 player cab so I need two for coin reject parts and two for the coin box part...can i get 4 of the same or are the two different some how?
Derek
EDIT* I See Bob Roberts has some but which ones do I need?
7/8" Cam locks keyed alike 641 $3.00
1 1/8" Cam locks keyed alike 641 $3.00
Lock set keyed alike 641 (1)1 1/8" & (2) 7/8"  $7.00
« Last Edit: July 23, 2003, 01:34:38 pm by crashdmj »
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
Re:Coin door locks
« Reply #1 on: July 23, 2003, 01:55:35 pm »
I got a couple of coin door locks cheap at the local Home Depot.
Just look in their locks section -- they've got lots of different locks, and I found one that fit perfectly in my coin door for less than $5.
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
Re:Coin door locks
« Reply #2 on: July 23, 2003, 02:24:09 pm »
On the happ coin doors, i'm pretty sure the locks are of the 7/8" variety.  I know the happ over/under coin door is for sure, i just checked the schematics and looked up the lock by its part #.  I imagine its gonna be the same for most coin doors.  Am i understanding correctly that your coin door uses 4 locks?  Or do you have 2 coin doors using 2 locks each?
-Kevin
crashdmj
  • Hulk smash!
Re:Coin door locks
« Reply #3 on: July 23, 2003, 02:26:51 pm »
I'll take a pic gimme a min.  ;D
Ok here it is!
« Last Edit: July 23, 2003, 02:47:07 pm by crashdmj »
Ken Layton
  • Guru
  • Technician
Re:Coin door locks
« Reply #4 on: November 04, 2003, 01:24:35 am »
All coin doors manufactured since 1994 conform to JAMMA standards and they use 7/8" locks.
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
Re:Coin door locks
« Reply #5 on: November 04, 2003, 01:21:49 pm »
Peale has been trying to stir up some interest for a large order of locks:
http://www.arcadecontrols.org/yabbse/index.php?board=2;action=display;threadid=12518
Next I'll be on fries, and that's when the big money starts rolling in.
william1983
  • Last login:December 17, 2003, 05:19:25 pm
Re:Coin door locks
« Reply #6 on: November 04, 2003, 08:52:04 pm »
i had the same problem then i called LOWES store i aske if they had UTITLITY CAM LOCKS.
and they said yes we.........so i went up there and i bought 2 of them 1 for the coin door and another for the change bucket.
they are SOLID STEEL.
the price on the is 2.57 cents all in all i got like 5 dollars in on BRAND NEW COIN DOOR LOCKS.
use your brain dont buy them from HAPPS or anyone on the net you will be ripped off..
just thought i would share this with you.
heres who makes them
FIRST WATCH
1-1/8' (29 mm) utility cam lock
thats exatly what it says on the box the box is white and BLUE.
SirPeale
  • Green Mountain Man
Re:Coin door locks
« Reply #7 on: November 04, 2003, 09:27:55 pm »
$2.57 is a good price.  I looked at Home Depot, and they wanted $3 + for one.  Not bad, but I was looking for cheaper.  I found it online, but only in quantity.
Tailgunner
Re:Coin door locks
« Reply #8 on: November 05, 2003, 01:24:44 am »
I went with the Lowes/Home Depot locks at first, then turned around and bought a sack full of proper arcade locks while I was at the amusement distributor's parts counter. The price difference ended up being about 25 cents a lock, though the difference in quality was well worth that extra quarter.
Ken Layton
  • Guru
  • Technician
Re:Coin door locks
« Reply #9 on: November 05, 2003, 11:01:19 am »
I've found that the typical locks at Home Depot and Lowe's are crap. They don't fit the lock hole and you've got to file the hole. Half the time they're out of stock of the 7/8" locks anyway.
 Many amusement parts companies like Competitive Products, Mazzco, Betson-Imperial, Happ, and Wico have real amusement machine locks on sale all the time.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
Re:Coin door locks
« Reply #10 on: November 05, 2003, 09:33:50 pm »
I got one that fit my Defender cab perfectly at Home Depot.  It's fine.
