Author Topic: Some dumb questions  (Read 1791 times)
welshmark
  • Last login:February 08, 2010, 02:21:16 pm
Some dumb questions
« on: December 29, 2009, 06:26:16 pm »
So I'm in the early stages of research and planning my cab build.  I've done a few jukes in the past, but this will be my first cab and I'm having a great time designing it (thanks to Sketchup and Inkscape).  I'm in no rush and am slowly collecting bits and pieces (and ideas) as I find them.  I've read Saint's book and perused these forums extensively, but I'm finding there are many things I'm not sure about and I'm hoping you guys can clarify.  Apologies in advance for any stupid questions, but as they say, the devil's in the details. >:D
Anyway, I just bought one of these pedal setups which have two 5k pots.  I was going to swap the pots for 100k and do a gamepad hack on them (or just get a few switches and make them digital) when I stumbled across the A-Pac version one. Would it be possible to hook these directly to it without swapping the pots out?  I'm hoping to pair them up with a 270 wheel (if I can find one, or I may have a go at making my own), but I also want to hook up digital joysticks and button sets for two players.  Can I do all this with one a-pac?  What if the wheel uses 100k pots - would I have to match them up to the pedals?
Oh, and any tips for the best way to clean the pedals up?
So I've saved the dumbest question for last, but I'm going to ask it anyway.  Can arcade locks like these be used directly in a cabinet, or are they built to interface with coin doors only?
SephYuyX
  • Last login:November 28, 2013, 11:40:04 am
  • I Am, Who I Am.
Re: Some dumb questions
« Reply #1 on: December 29, 2009, 11:21:30 pm »
Not quite sure I know what you mean. Do you just want to drill a hole in wood and plop one in? Or are you looking to make act as a 'key' where you can turn it and the system will come on?
Those locks can be used in a variety of things, not just arcade coin doors, but that one's main purpose in life would seem to be used as a lock for a coin door. If youre wanting to make it some sort of ignition key, you could plop a switch http://www.happcontrols.com/electrical_supplies/42107500.htm next to the lever and have it turn on the PC hooked up to a smart surge and in turn, turn everything else on.
welshmark
« Reply #2 on: December 29, 2009, 11:58:18 pm »
Thanks for the reply.  I meant can I just drill a round hole in the wood and pop one of those keys in to lock a door I cut out, or are they designed and shaped specifically for coin doors.  I can't tell from the pictures.
« Last Edit: December 30, 2009, 12:00:26 am by welshmark »
SephYuyX
  • I Am, Who I Am.
« Reply #3 on: December 30, 2009, 10:18:11 am »
Round hole would work as long as the nut is tight. The cylinder is flat on two sides to keep it from spinning when the key is turned. So something like (_) would be the profile.
