Author Topic: Problem with connecting tv to computer  (Read 1843 times)
Urk
  • Last login:March 07, 2010, 10:07:44 am
« on: December 26, 2009, 01:59:22 pm »
I have problem with connecting my tv to my computer.
There are now connected with a vga-scart from wolfsoft.
The problem is that windows doesn't show that well, all sides are missing.
for instance i can't see the windows start
is there someting i can do?
bkenobi
Re: Problem with connecting tv to computer
« Reply #1 on: December 26, 2009, 02:11:05 pm »
That's called overscan.  You need to adjust the display to reduce the amount of overscan being applied.  When you use the TV out on a video card, there are typically options for setting this up.  When outputting via the VGA I'm not sure what the most popular software to use is.  I used a software called "Power <something>" when I was setting this up way back when...I just can't remember what that <something> is anymore.
EUREKA!!!  It was called PowerStrip.  Here's a link:
http://entechtaiwan.com/util/ps.shtm
« Last Edit: December 26, 2009, 02:16:36 pm by bkenobi »
Urk
« Reply #2 on: December 26, 2009, 02:47:06 pm »
thx for your help :)
Blanka
« Reply #3 on: December 27, 2009, 05:53:48 am »
Oops!
« Last Edit: December 27, 2009, 05:55:30 am by Blanka »
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #4 on: December 28, 2009, 03:01:34 pm »
check ur tvs servicemode option : horizontal and vertikal size .
Urk
« Reply #5 on: December 29, 2009, 10:50:32 am »
got the overscan solved.
but now i got a blackscreen, omg :)
i had the latest catalyst driver installed, but because soft15 needs catalyst driver 6.5 i changed it.
so now i'm screwed and need to reinstall windows.  :angry:
bkenobi
« Reply #6 on: December 29, 2009, 02:37:43 pm »
Uninstall the drivers and go again.  You shouldn't need to reinstall windows because of this.  If something stays after uninstall, try safe mode.
