Author Topic: Pinball emulation in my cabinet... how ?  (Read 3318 times)
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« on: December 21, 2009, 09:50:01 pm »
I have been trying tu run Virtual Pinball or Visual PinMAME for the past 2 hours without success. I dont understand why since that the included instructions are simple. The closest I have been to playing a table is to launch vpinball.exe, open a table (not a ROM) from the File menu, then go to Table menu and Play. But then again keystroke doesnt do a thing (5 for credit doesnt work for exemple). All in all its a nightmare!
What am I doing wrong ?
And most importantly, I want to play pins in my cab so that vpinball.exe is not viable solution. How do you guys do it ? How do you launch the emu from your frontend ?
Thank you
Hoopz
  • Intellivision Rocks!
Re: Pinball emulation in my cabinet... how ?
« Reply #1 on: December 21, 2009, 10:35:20 pm »
First, check the Wiki.  It walks through what you need and the differences between different ways to do it:
http://wiki.arcadecontrols.com/wiki/Pinball
And this next part is "borrowed" from another site.   :angel:
Four components of pinball:
VPinMAME roms
VPinMAME Tables
Visual Pinball Tables (Original & Recreated)
Future Pinball Tables (Origina & Recreated)
VPinMAME roms
This contains the actual roms out of the original pinball machines that are required for the VPinMAME program that emulate those machines.
It also contains rollback roms (to go back to a previous version of the VPinMAME emulator) and other roms (test drivers etc).
VPinMAME Table
Contains the graphical overlays as used by the Visual Pinball program. This program hooks into VPinMAME to give you an accurate simulation of actual pinball tables. If you want to play a table you've seen in real life you need these 2 things and get the Visual Install Pack that contains all the required programs in an easy to use setup.
These are the tables for use with the aformentioned Visual Pinball program. The difference is that these do not hook into the VPinMAME emulator, so no roms are involved. The torrent contains 4 sections
Recreated Tables
Recreations of other pinball tables, for example, tables from the 50's that didn't use any roms, computer game remakes, tables whose roms are not available yet.
Recreated Tables Other
Flipperless recreations, for example bagatelle tables.
Original Tables
Brand new pinball table creations for your gaming pleasure
Original Tables Other
Have a guess! Flipperless original table creations.
Future Pinball Tables (Original & Recreated)
This means tables for use with the new pinball simulator Future Pinball This is a much more modern program, allowing for fancier graphics and much more accurate physics than Visual Pinball - this is reflected in the table size! It is still very much a work in progress, with the original release only being made a couple of months ago so several key features are still missing. It does not hook into VPinMAME but there are still some great playable tables to be had.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: December 22, 2009, 08:32:18 am »
That line is a bit outdated now.
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
« Reply #3 on: December 30, 2009, 06:34:20 pm »
If you want to run MAME and Visual Pinball (I'd also suggest Future Pinball, but it takes a little more horsepower and and relatively good Video Card), I'd strongly suggest running MALA.
Much cooler on a Cab than mousing around a Windows desktop!
MPTech
   Better living thru technology!   ;-)
