Author Topic: More Mamewah issues  (Read 1169 times)
Creeper
  • Last login:January 10, 2012, 11:55:07 pm
    • The Naked Robber
More Mamewah issues
« on: November 29, 2009, 11:04:20 pm »
So I have the latest Mame 32 and the latest Mamewah. Each is sharing the exact same rom directory. Problem is that I can run Marvel Super heroes vs. Street Fighter and also Marvel vs Capcom both on Mame32 no problem. I go to run the same roms from my Mamewah menu and they won't load. Has anyone else ever experienced this?
Ginsu Victim
  • Comanche, OK -- USA
Re: More Mamewah issues
« Reply #1 on: November 30, 2009, 12:06:37 am »
1. You shouldn't run MAMEUI 32 through Mamewah. Get a normal command line MAME version.
2. Have you set up Mamewah to point to your roms? (directory in the INI, generate list, etc)
Creeper
    • The Naked Robber
« Reply #2 on: November 30, 2009, 12:38:34 am »
Yes I do have Mame 135 command line which is what Mamewah is using. I also have Mame 32 but its completely separate from mamewah.
The roms are pointed to the right directory and most of them are working through Mamewah, but a handful of them aren't even though they work fine in Mame32.
EDIT: So I tried running Marvel vs Capcom with Mame 32 and then just the Mame command line. Mame 32 will run it but Mame command line won't, it says:
mvse.03a NOT FOUND
mvse.04a NOT FOUND
ERROR: required files are missing, the game cannot be run.
So I guess this isn't a mamewah issue at all. Does anyone know the difference between Mame .135 and Mameui132?
EDIT AGAIN:  After some monkeying around it turns out to just be missing clones, still seems kind of odd though.
« Last Edit: November 30, 2009, 01:55:14 am by Creeper »
Ginsu Victim
« Reply #3 on: November 30, 2009, 08:18:59 am »
You're running two different versions of MAME, so the roms don't match. Get the correct roms for your version.
