Author Topic: Direct X Error (8007000E)  (Read 8710 times)
BRIK
  • Last login:December 09, 2009, 10:29:21 pm
« on: November 29, 2009, 09:45:17 pm »
Please Help. When I try to run games through Mala Frontend (Version 1.05) a MS DOS box comes up and says;
'Warning: Device may not preform well for Direct 3D renderering
Unable to create the Direct 3D device (8007000E)
Unable to initialise Direct 3D
Unable to complete window creation.'
And then it just goes back to the main Mala Menu. I tried just running the games with MAME (version 0132) and the same message appears. I figured this was a Direct X problem so I went into the DirectX Diagnostic Tool. In the Display tab I ran the Direct 3D tests and it did version 7 and 8 alright but when it got to 9 a message came up which said 'Hardware accelerated Direct3D 9+ is not available because the display driver does not support it.  You may be able to get a newer driver from the hardware manufacturer.'
I tried just simply installing Direct X 9 but the same messages keep coming up. I've looked everywhere for drivers but I was unsuccessful.
The computer I'm using isn't that great but its only for games from the 80's, so you would presume it wouldn't need to be that good. The specs for computer are as follow;
IBM Corporation
Aptiva
Microsoft Windows 98 (4.10, Build 2222)
AuthenticAMD
AMD-K6(tm) 3D Processor,  MMX,  3D Now,  500MHz
120.0 MB of RAM
Direct X Version: Direct X 8.1 (4.08.0001.0881)
Thanks in advance.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Direct X Error (8007000E)
« Reply #1 on: November 29, 2009, 10:10:27 pm »
Many applications today require DirectX 9 at a minimum.  Not trying to be a smartass, but I'm not sure what games from the 80s have to do with it.
Mala wasn't written in the 80s or 90s and most here are not actually running games from that era, but emulating them which requires more horse power.  Do you have another video card you can stick into it?  I am not sure you will find a Windows 98 driver that supports DirectX 9.
BRIK
« Reply #2 on: November 29, 2009, 10:20:40 pm »
afraid not. would older versions of mala and mame just run on direct x 8?
Bobulus
  • Last login:July 11, 2014, 10:42:28 am
« Reply #3 on: November 29, 2009, 10:27:58 pm »
Did you change your mame.ini file at all? I've run MAME on non-directx9-capable computers before, so I don't think that's the problem.
BRIK
« Reply #4 on: November 29, 2009, 10:30:07 pm »
nah i haven't been anywhere near the mame.ini file at all
Bobulus
« Reply #5 on: November 30, 2009, 01:46:15 am »
What graphic card are you running?
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« Reply #6 on: November 30, 2009, 02:55:11 am »
in mame.ini
under Windows Video Options
change
video           d3d
to
video           ddraw
should help
BRIK
« Reply #7 on: November 30, 2009, 03:57:58 am »
cheers i'll give it a try
BRIK
« Reply #8 on: November 30, 2009, 04:17:47 am »
it worked. thanks a lot dungbeetle46 you've made my day :cheers:. I can finally get on with making my cabinet now as i didn't see a point until i had a working computer
dungbeetle46
« Reply #9 on: November 30, 2009, 07:17:47 am »
great to hear, good luck with the cab
BRIK
« Reply #10 on: November 30, 2009, 11:11:57 pm »
thanks
jcterzin
  • Last login:May 08, 2012, 02:02:15 am
« Reply #11 on: February 19, 2010, 10:50:03 pm »
i just wanna add that this totally helped me out with my problem too. Thanks alot guys.
