Author Topic: Rotating Ads  (Read 4361 times)
DashRendar
Rotating Ads
« on: November 19, 2009, 01:24:59 pm »
There's an issue with the height of the rotating ads at the top of the forum.  One ad is shorter than the other, so it moves everything below it (all the forums) up and down a bit as it cycles.
It's not a huge deal, but it's a little pesky.  Would be great to specify the height of that area rather than having it morph based on the ad banners.  Should be easy to do.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:December 16, 2025, 07:43:13 am
Re: Rotating Ads
« Reply #1 on: November 19, 2009, 02:07:19 pm »
Hm. Happening to anyone else? I make the ad banners the same size to avoid that. Will check.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Re: Rotating Ads
« Reply #2 on: November 19, 2009, 02:20:46 pm »
Yes, happening in Firefox.
DashRendar
Re: Rotating Ads
« Reply #3 on: November 19, 2009, 03:05:58 pm »
Yep- forgot to mention I'm using Firefox.
Hoopz
  • Last login:December 14, 2025, 08:50:02 am
  • Intellivision Rocks!
Re: Rotating Ads
« Reply #4 on: November 19, 2009, 03:35:18 pm »
I'm using Firefox 3.5.5 with Adblock Plus 1.1.1 and haven't had any issues.  Often, I don't even see the ads.
saint
Re: Rotating Ads
« Reply #5 on: November 19, 2009, 04:35:02 pm »
Adblockers on BYOAC make baby saint cry :)
Mmmm What theme are you guys using?
--- John St.Clair
     Project Arcade 2!
Re: Rotating Ads
« Reply #6 on: November 19, 2009, 04:43:56 pm »
Default.
Hoopz
Re: Rotating Ads
« Reply #7 on: November 19, 2009, 05:13:50 pm »
I allow them on BYOAC though.   ;)
That's why I said that they looked fine for me.
DashRendar
Re: Rotating Ads
« Reply #8 on: November 19, 2009, 05:22:07 pm »
I had a custom theme, but switched to the default and getting the same results.
Re: Rotating Ads
« Reply #9 on: November 20, 2009, 09:38:29 am »
It used to be worse before the first time you fixed it.  Then it was so bad you'd go to click on one subforum and end up in another because they were jumping around.  Now it only moves maybe 1-2 rows at a time and not with every ad change like it used to.
saint
Re: Rotating Ads
« Reply #10 on: November 20, 2009, 10:23:08 am »
OK, think it's fixed now.
--- John St.Clair
     Project Arcade 2!
DashRendar
Re: Rotating Ads
« Reply #11 on: November 20, 2009, 10:27:54 am »
I think it had something to do with one of the ads- the red X-Arcade ad specifically- which made it jump a couple lines.
Looks good now.
saint
Re: Rotating Ads
« Reply #12 on: November 20, 2009, 11:15:54 am »
Yeah - the X-Arcade adds were adding an extra CR/LF sequence on their ads. Actually couldn't figure out why (it links to their site so they have some code going on) so I just added an extra CR/LF to the other ads. :)
--- John St.Clair
     Project Arcade 2!
Re: Rotating Ads
« Reply #13 on: November 20, 2009, 11:32:36 am »
Yeah, definitely isn't bouncing now.
