Author Topic: Question on MAME resolutions....  (Read 1636 times)
Mickelonis
  • Last login:November 24, 2017, 06:23:25 pm
« on: November 18, 2009, 09:30:52 pm »
So I own a Wells Garnder D9800. I do NOT own an arcadeVGA, however I'm running soft15hz.
My problem is I think MAME is "stretching" a lot of games and I want to ensure that I am viewing games in the proper resolution, but I don't know how to verify this.
Long story short, can I use this arcade resolution tool http://www.ultimarc.com/avgainst.html if I'm using maximus arcade as my frontend?
-Pete
Epyx
  • "You're an oddity"
Re: Question on MAME resolutions....
« Reply #1 on: November 19, 2009, 04:50:27 pm »
Short Answer: Yes
I have a video review/evaluation of the Arcade VGA and this same monitor in the Review section that deals with what you need to do.  Essentially you need the following for maximum functionality:
-AVRES from Ultimarc link
-Trisynch utility so that the 640x480/800x600 modes are non-interlaced and flicker free (For Maximus running in front end mode and other pc games or higher resolution Mame games)
But have a look at the video it describes each one, am at work now so likely missing something.
http://forum.arcadecontrols.com/index.php?topic=94757.0
Also make sure you have the settings in MAME set correctly. Here are the settings for MAMEUI32:
Display Tab:
VideoMode: DirectDraw
Stretch Using Hardware = OFF (if this is greyed out you have notswitched Windows to 16 or 32-bit colour mode)
Screen Tab:
Screennumber = 0
Screen = \\.\DISPLAY1
Resolution, Size = Auto (or select from drop-down list in game asrequired)
Switch Resolutions to fit = ON
« Last Edit: November 19, 2009, 04:52:48 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Mickelonis
« Reply #2 on: November 19, 2009, 10:51:42 pm »
Thanks for your reply man, I'll check it out and post back with any questions I may have =)
-Pete
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
« Reply #3 on: November 25, 2009, 09:39:38 am »
Cool, I been looking for this answer myself. Thanks Epyx
Best of the Best of the Best. Sir!
