Author Topic: T-Molding tip  (Read 1568 times)
tbombaci
  • Last login:October 31, 2024, 01:32:56 pm
T-Molding tip
« on: July 20, 2003, 12:36:54 am »
I drove all over the county today looking for a 3/32 nd router bit to make the groove for the t-moulding. No-one has them in stock. I glanced down at my table-saw and it dawned on me....the blade...how thick is the blade? Wouldn't you know, the blade is 3/32 nds!!!
A quick pass on all of the control panel sides, voil
« Last Edit: July 21, 2003, 11:52:39 am by tbombaci »
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re:T-Molding tip
« Reply #1 on: July 20, 2003, 12:51:50 am »
That is a good tip.... if one has a table saw.
FWIW I thought most t-molding has/wants a 1/16th inch channel...er.. slot ...
*shrug*  But I can definitelly see where it would be difficult to find that particular bit unless you went to a real wood working type place...
(although I got mine for 16 beans including arbor with free shipping from mlcs ... (damn, i wonder if they have an affiliate program -- all the time I've dropped there name/url))
Also t-molding.com also sells the bit... *shrug*
Just thought i'd pile on with that info... I wish I had a table saw... and a router...and a good drill... and a workshop to use them in... =(
Rampy
tbombaci
Re:T-Molding tip
« Reply #2 on: July 20, 2003, 01:06:35 am »
Rampy,
On the t-moulding site,  all of the sample images measure out the width of the cut to 3/32nds. I could have ordered On-Line....but I had the time today to kill on the MAME project and I simply couldn't wait!
I also learned a valuable lesson about contact cement.
I wanted to finish my control panel today. I had the artwork printed and used 3 mil laminate on the bottom with "Floor Guard" laminate on the top (gives it that textured Video Game feel :)"
As for the contact cement, don't wait too long to apply the pieces together!!!  ARGH!!!  I had to laboriously peel off the dried contact cement and re-apply to the art and plywood.
All in all, the control panel turned out pretty well! There is a small vertical bubble where I didn't get all of the dried contact cement off the wood. Hardly noticeable though. Just waiting for the t-moulding and I am basically done.**
** I am in the process of converting a trashed Data East Jamma cabinet to a MAME cabinet.
-Tom
traknfieldSUPAstar
  • Last login:March 18, 2011, 07:34:52 pm
Re:T-Molding tip
« Reply #3 on: July 20, 2003, 01:22:22 am »
pictures!!! pictures damnit!!!...  ;D c'mon.. you know you wanna share
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
Re:T-Molding tip
« Reply #4 on: July 20, 2003, 01:30:16 am »
*shrug*
steve_pss
Re:T-Molding tip
« Reply #5 on: July 20, 2003, 01:30:44 am »
*shrug*
Tailgunner
Re:T-Molding tip
« Reply #6 on: July 20, 2003, 01:38:35 am »
Bosch makes T-molding slotting bits in 1/16" and 5/32" and two styles of arbors for them.  Lowes doesn't stock them, but they will special order them for you. I haven't checked Home Depot, but if they carry Bosch router bits they can order the slotting bits as well.
FWIW, the t-molding slots in my sitdown RoadBlasters cabinet are all 5/32".
AlanS17
    • AlanS17
Re:T-Molding tip
« Reply #7 on: July 20, 2003, 02:13:26 am »
Rampy
I've got a table saw: my jigsaw up on the bar.
I've got a workshop: my living room. (You can always vacuum the sawdust.)
