Author Topic: T-Molding Size??  (Read 11318 times)
OverRide
  • Last login:January 11, 2026, 04:25:09 pm
T-Molding Size??
« on: November 05, 2009, 03:56:18 pm »
I am using the Ultimate Arcade II instructions for building my new cab. The one thing that I'm not sure of is the size of t-molding vs the size of MDF.
The MDF they suggest is 5/8" and the molding is 3/4". I always thought the t-molding needs to be the same width as the wood? 3/4" wood and 3/4" t-molding.
Franco B
Re: T-Molding Size??
« Reply #1 on: November 05, 2009, 04:22:04 pm »
Generally you do want to use the same size t-moulding as the material thickness for the sides etc.
They may be refering to the CP and may be suggesting using 5/8" MDF + 1/8" acrylic/polycarb to give 3/4" to match the t-moulding.
« Last Edit: November 06, 2009, 11:43:44 pm by Franco B »
OverRide
« Reply #2 on: November 05, 2009, 04:58:11 pm »
Yes, that would make sense. The instructions call for acrylic on the sides.
Thanks for pointing out the obvious for me. lol :)
Epyx
  • "You're an oddity"
« Reply #3 on: November 06, 2009, 07:10:53 pm »
Here is an example of 5/8" MDF with 3/4" T-Molding with 1/16" laminate on both sides:
Using 5/8" T Molding with 5/8" or 3/4" T with 3/4" MDF would leave you with overhang of the laminate.  If you are just painting then no problem, go with a t molding that matches.
Last Project
Epyx Tutorials:
Tutorials
Franco B
« Reply #4 on: November 06, 2009, 11:44:24 pm »
Good thinking Epyx, I had not thought about 1/16" laminate on both sides to add up to an 1/8"  :)
edge10
  • Last login:August 20, 2014, 03:49:58 pm
« Reply #5 on: November 09, 2009, 04:46:34 pm »
Any thoughts on using 3/4" t-molding with 23/32" plywood?  ???
The size is soooo close but does it look good or is it a pain (looks bad or catches on clothes and stuff)?
Please remind me NOT to argue on the Internet!
Joel Robinson: People don't mean to be obnoxious, it's just that they're all screwed up inside.
Epyx
« Reply #6 on: November 17, 2009, 05:53:40 pm »
That won't be an issue...you can always trim some of the T-Molding using the sharp chisel technique, but the amount in your example would be pretty minuscule.
Last Project
Epyx Tutorials:
Tutorials
« Reply #7 on: November 17, 2009, 07:41:33 pm »
Here ya go... works great!
edge10
« Reply #8 on: November 17, 2009, 10:13:42 pm »
Thanks for the answers!    :applaud:
I was afraid this thread was dead.
