Author Topic: Large Volume Knob  (Read 4699 times)
volno
  • Last login:November 23, 2012, 12:39:28 pm
Large Volume Knob
« on: October 23, 2009, 01:08:44 pm »
looking for a large volume knob for a jukebox project
has to be 50mm + diameter , black if possible
Anyone know of where i can pick one up?
many thanks
btw. i'm in the UK
hattrick10
  • Last login:November 13, 2020, 01:46:27 pm
Re: Large Volume Knob
« Reply #1 on: October 26, 2009, 08:39:15 am »
You could always build your own by using an old mouse...
http://www.instructables.com/id/Desktop_Scroll_Wheel_and_Volume_Control/
I considered making my own but ended up buying a griffin powermate due to time constaints.  (Need to finish up my juke by this weekend for the annual halloween bash).
I hope to get some pics up soon for you all to see...
Paladin
  • Mmmm llamaburgers!
« Reply #2 on: October 26, 2009, 12:02:33 pm »
A little searching brought me to the program 'VolumeTray' that will let you control Windows volume with keys.  I guess it doesn't work in Vista, but my jukebox is running on XP so I'll give it a try.  A round volume knob would look nicer than 2 buttons, but I've got an IPac sitting around so I could use any type of button.
Paladin
« Reply #3 on: October 26, 2009, 07:11:06 pm »
If anyone's interested, the VolumeTray program works great in XP!  I'm running E-Touch/Freebox jukebox software in fullscreen mode with the mouse pointer turned off.  I loaded VolumeTray and set it so the up arrow and down arrow adjust the volume.  I hooked a couple Radio Shack buttons to the IPac P1 UP and DOWN.  Now when I launch the jukebox I can adjust the volume with the built in touchscreen volume control and/or the 2 buttons.  The buttons work as the master volume control in Windows, so I can use it when switching between the jukebox and other programs without needing to open the cabinet to get to the speaker volume control.
Chris
    • Chris's MAME Cabinet
« Reply #4 on: October 27, 2009, 11:51:44 pm »
--Chris
Chris
« Reply #5 on: October 27, 2009, 11:56:18 pm »
Specifically, try http://www.mouser.com/ProductDetail/Davies-Molding/1940BE/?qs=O7pb%252bE5gJ7Q3%2folPh3XiHA%3d%3d which is black phenolic and should be just over 50mm in diameter, fitting a 1/4" shaft.  Note that this is a skirted knob, and the diameter is of the skirt.
--Chris
