Author Topic: Sega CD on Mame  (Read 4811 times)
acidblue0
  • Last login:January 11, 2020, 11:50:52 pm
Sega CD on Mame
« on: October 20, 2009, 10:12:07 pm »
I own tons of Sega CD games. How do I play them on Mame without using a CD? I want to be able to have all of them on Hard Drive and be able to have a list on Maximus Arcade. Can this be done?
Ginsu Victim
  • Comanche, OK -- USA
Re: Sega CD on Mame
« Reply #1 on: October 20, 2009, 10:13:07 pm »
You can't play them in MAME (Multiple Arcade Machine Emulator). You can use a Genesis/Megadrive emulator that supports loading ISOs, though. I use Kega Fusion. I don't know if there's anything more modern, though.
« Last Edit: October 20, 2009, 10:14:53 pm by Ginsu Victim »
acidblue0
Re: Sega CD on Mame
« Reply #2 on: October 20, 2009, 10:14:40 pm »
So I will have to a CD drive setup up on mame cabinet to run them?
Ginsu Victim
Re: Sega CD on Mame
« Reply #3 on: October 20, 2009, 10:15:39 pm »
No. You have them on your hard drive, so they are already in a disc image format.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Sega CD on Mame
« Reply #4 on: October 20, 2009, 10:21:09 pm »
If you rip the games to .bin you can convert them to .iso and .mp3 files to play in most emulators without the CD. By far the best and most cabinet-friendly I've found is Kega Fusion. ensure you have the appropriate bios files, test them in the emulator from Windows first, then set your front-end up to identify the .iso files to create your game list.
acidblue0
Re: Sega CD on Mame
« Reply #5 on: October 20, 2009, 11:51:44 pm »
Thanks. I will try it
acidblue0
Re: Sega CD on Mame
« Reply #6 on: October 21, 2009, 12:12:14 am »
Test run worked. All I need now is a BIG drive to put these Sega CD games on
