Author Topic: Arcade cabinet, Golden Tee '99 running on 60" projection TV - Chicago  (Read 4988 times)
ninjazx71
  • Last login:December 31, 2009, 02:13:28 pm
Price dropped to $350!
Hey guys, I used to be a member of the site about 5 years ago where I learned everything I needed to know about building my own cabinet. I've now moved into a new home and don't have anywhere to put this, so the wife wants it out of the garage.  :hissy:  Anyhow, I've got a cabinet that I built out of MDF board that fits a 27" TV. It has Golden Tee '99 PCB's, all Happ (?) buttons, switches, joysticks, and a neon blue rollerball, power supply, and S-Video converter. After I got it up and running I happened into a 60" projection TV that I then hooked up and man, was it great! Anyhow, the cabinet is fully built, but the outside is unfinished, which means you can decorate it however you want it to look.  :cheers:
I'm located in Plainfield, IL, and don't have a way to deliver, so it will have to be pickup only...
Also included will be user manual for Golden Tee '99, marquis for Golden Tee '99 to install on the cabinet, light attachment to install under rollerball to make it "glow", any extra switches that I have, and the 60" Projection TV.
Asking $350 for everything...
« Last Edit: November 20, 2009, 02:01:25 pm by ninjazx71 »
ninjazx71
Re: Arcade cabinet, Golden Tee '99, MK3 Ultimate, 60" and 27" TV's - Chicago
« Reply #1 on: October 20, 2009, 08:36:12 am »
Should have mentioned in original post, but will also consider reasonable offers...
ninjazx71
« Reply #2 on: October 21, 2009, 11:11:19 pm »
Price dropped to $550! Come take it out of the garage this weekend!  :burgerking:
Ummon
  • Trade Count: (+13)
« Reply #3 on: October 23, 2009, 02:59:57 pm »
While there's some kudos for attempting to build your own cab, it's perhaps necessary to point out that all that 'square-ness' of the cab will likely non-plus most folks.
The projection TV, on the other hand, especially if it has component input (and even more so if it happens to have a VGA input) simply needs a base and CP attached to or placed in front of it, and ya have yerself a 'showcase' cab!
« Last Edit: October 23, 2009, 10:50:42 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
ninjazx71
« Reply #4 on: October 23, 2009, 05:54:35 pm »
The 27" TV that I have DOES take VGA input (used to be a display monitor outside of the office w/ powerpoint running on it from a PC) but the projection TV doesn't. It does take component in via BNC (is that right? not regular RGB like on the back of components now, but the thinner wire w/ the locks on the cables), RCA, and S-Video. Currently I use it w/ the RGB --> S-Video converter that I bought so you can take a standard JAMMA cable and plug it into anything w/ S-Video. Between that, the buttons, joysticks, rollerball and PCB's, someone could gut the cabinet, burn the wood for warmth and put all the components into their own cabinet to make a supercab!
Any takers?
Ummon
« Reply #5 on: October 23, 2009, 10:53:51 pm »
Dude, BNC IS RGB. It's the original 'component' video. Component NTSC is for TVs. I'd maybe think about it if you were local. Really curious what scan range both monitors (as essentially that's what they are) are capable of. What models are they?  You got any specs, manuals?  Etc....
Yo. Chocolate.
Stephen Hawking
ninjazx71
« Reply #6 on: October 23, 2009, 11:29:39 pm »
I don't have any docs on the 27" but if I remember right there was a model number on the video card in the back of the monitor where the VGA input is. I'll have to try and check it out tomorrow. I've got the manuals (Installation and User... so all functions to tweak every aspect available) for the projector. It's a Sony RVP-6010Q. Regarding the scan range... not exactly sure if this is it, but for RGB INput - Horizontal frequency: 15kHz - 93kHz and Vertical frequency: 38Hz - 150Hz. Resolution: 1400 x 1120 pixels (RGB input at fH: 69kHz, fV:60Hz). That the kinda info you were wondering?
ninjazx71
« Reply #7 on: October 25, 2009, 12:08:10 am »
Alright... $500.... need it out of the garage to make room for my in-laws stuff since they're moving in until their new house is ready.... Anyone?
ninjazx71
« Reply #8 on: October 26, 2009, 10:31:59 pm »
$450... any takers? Between the 60" projection TV that takes component and S-Video and the 27" TV that accepts VGA, and all the components from the machine (power supply, joysticks, PCB's, S-Video converter, JAMMA cables, buttons, rollerball, etc.) this is a steal...
ninjazx71
« Reply #9 on: November 02, 2009, 12:48:02 am »
Still looking for a buyer... $400 anyone? Come on... take it outta my garage this weekend!
Ummon
« Reply #10 on: November 03, 2009, 02:56:07 pm »
These are the specs for the 60" projection TV?
Yo. Chocolate.
Stephen Hawking
ninjazx71
« Reply #11 on: November 04, 2009, 10:57:29 am »
Yup, those are what I was able to find in the user manual that came w/ the unit. It used to be used for presentation purposes at a company...
Ummon
« Reply #12 on: November 05, 2009, 04:09:54 pm »
Damn. If you were local, and if I could handle the screen size, I'd be all over it. I'd get rid of a prospective cab set-up or two for it, given that scan range. Probly a lot of money for many right now, but so worth it for a MAME cab.
Yo. Chocolate.
Stephen Hawking
Hoopz
  • Last login:January 24, 2026, 09:24:43 am
  • Intellivision Rocks!
« Reply #13 on: November 12, 2009, 02:59:32 pm »
PMs sent.
ninjazx71
« Reply #14 on: November 18, 2009, 03:16:57 pm »
Sale fell through... new price... $375 for the 60" Projection TV, arcade cabinet, and Golden Tee '99... Completely plug and play... move it to your house, basement, whatever... plug it in and start playing...
ninjazx71
Re: Arcade cabinet, Golden Tee '99 running on 60" projection TV - Chicago
« Reply #15 on: November 20, 2009, 02:01:02 pm »
$350... want it gone this weekend... anyone?
ninjazx71
« Reply #16 on: November 23, 2009, 05:51:54 pm »
Last attempt... $325... who wants?
northerngames
  • Trade Count: (+18)
« Reply #17 on: November 25, 2009, 11:22:44 am »
I dont think your price is the issue you just have to find someone local that is interested with some extra cash to spend.
try listing it on craigslist & Klov if you have not done so already.
death69inc
  • Last login:February 29, 2016, 05:54:33 pm
« Reply #18 on: November 26, 2009, 12:04:10 pm »
yeah I woudl take it in a instant but chicgo to far of a drive cost gets much larger st louis to chicago is no the longest but its long enough
Always looking for nintendo and capcom arcade pcbs and marquees etc
ninjazx71
« Reply #19 on: November 28, 2009, 09:34:37 am »
Yeah, I agree that the price should be killer for just about anyone. Unfortunately it doesn't seem like anyone local is that interested in it, so I was hoping an even lower price would entice someone to take a roadtrip to get it...
death69inc
« Reply #20 on: November 28, 2009, 11:18:32 am »
2 years ago i took a round trip out to chicago to get faring set for my bike
about killed me and i woudl need ot rent a truck to get that thing home lol
