Author Topic: MAME Compile Issue  (Read 860 times)
Avenger257
  • Last login:March 15, 2023, 07:11:46 pm
MAME Compile Issue
« on: September 27, 2009, 10:25:06 pm »
This is my first time compiling MAME (using the hi_score diff).  It appears that everything has turned out wonderfully except for one thing.  When I hit tab to pull up the menu, it comes up and I can read everything but as soon as I select Player 1 (or 2 or 3 etc) I can't read anything.  It just looks like a bunch of white boxes.  Any help would be appreciated...
Ginsu Victim
  • Comanche, OK -- USA
Re: MAME Compile Issue
« Reply #1 on: September 27, 2009, 10:56:35 pm »
Is the MAME.INI set to DirectDraw? If so, try Direct3D. Also, what is your resolution set at? (Both in MAME and your desktop)
Avenger257
« Reply #2 on: September 28, 2009, 06:59:42 pm »
I changed it and now it works fine!  Thank you!
