Author Topic: Fusion and Mala not working  (Read 2884 times)
memphis
  • Last login:September 17, 2009, 02:43:27 pm
« on: September 17, 2009, 09:49:20 am »
Seems that I'm having nothing but bad luck trying to get this to work.
Ive read FAQ, how-to articles,  did searching but didn't find anything that would help. Maybe someone can chime in help me out.
I have made the lists and all the games show up.
My directory listing is a follows:
Fusion is located in              c:\sms
SMS roms are located in      c:\sms\roms
Depending on how I try, I'm either getting an error or I'm getting a blank screen in fusion.
I have also verified that it works via command line as show in a screenshot.
I have also moved directories around thinking it may be the length of my folder names and how thy contained spaces, but I have shortened them down and I get the same result.
BTW, all my roms are unzipped and in .sms format.
I'm attaching pictures of my config and errors.
Any help is appreciated
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Fusion and Mala not working
« Reply #1 on: September 17, 2009, 10:01:45 am »
paste this in your command line and put a tick in hidden instead of minimized
"%path%\%rom%.%ext%" -sms -auto -fulls
memphis
« Reply #2 on: September 17, 2009, 10:09:51 am »
Thanks, but that was a preset, tried that first. All I get is a black screen.
The reason it was ticked that way ..  slip of the mouse when I was taking a screenshot.
dungbeetle46
« Reply #3 on: September 17, 2009, 10:15:48 am »
strange works fine for me
memphis
« Reply #4 on: September 17, 2009, 10:38:08 am »
Very!.
It works via command line, but when ran through MaLa, it doesnt..
Any other ideas?
memphis
« Reply #5 on: September 17, 2009, 02:43:27 pm »
I found the issue..
If I use the RomDir2XML.exe tool to create my list, it will not work.
If I use MaLa to create the list, it works.
Henrik68000
  • Last login:December 12, 2010, 01:54:23 pm
« Reply #6 on: September 17, 2009, 04:17:21 pm »
I was just about to reply. Fusion works very well for me in Mala . I run all the systems. Also the disc based ones. the only one i run with another emu i Mastersystem. I dont know why but it wont run in fusion. But It runs perfectly in Mess (Vesion 1.31 to 1.34)
