Author Topic: Issue with Mame132 and X-Arcade Tankstick  (Read 4574 times)
slik50
  • Last login:January 29, 2016, 10:36:08 pm
« on: September 10, 2009, 11:17:57 am »
After talking with X-Arcade I did what they suggested by re-installing Mame132 from scratch again.  The issue I am having is with Mame not recognizing my Player 2 controls/inputs.  I have used the X-Arcade test utility and have tested via output to notepad and the player 2 controls are recognized yet when I open a game and review my mapping settings they are all accurate to the correct setting X-Arcade uses, however, "Player 2" is blackened or greyed out for some reason from within the gaming menu.  I've also switched the Numlock back and forth to make sure that was not the issue.  So, when attempting to play a 2 player game even though the game settings for the player 2 x-arcade are set to the defaults both the joystick and buttons have no response.  For some reason when player 2 comes up it is playing through the Player 1 defaults or Player 1 joystick/buttons.
Is there a file i need to edit so that Player 2 controls/defaults are recognized?
Thanks,
Justin
slik50
Re: Issue with Mame132 and X-Arcade Tankstick
« Reply #1 on: September 10, 2009, 11:42:55 am »
addtl info:
Mame132 actually includes the X-Arcade.cfg file and had the options pre-populated under Controls in Mame.
Epyx
  • "You're an oddity"
« Reply #2 on: September 10, 2009, 12:19:49 pm »
Can you post a screenshot of where it is grayed out? I would like to see it, might help.
Last Project
Epyx Tutorials:
Tutorials
slik50
« Reply #3 on: September 10, 2009, 12:25:57 pm »
I am thinking it has something to do with editing a particular file so Mame can recognize?
« Last Edit: September 10, 2009, 12:37:10 pm by slik50 »
slik50
« Reply #4 on: September 10, 2009, 12:34:22 pm »
Epyx, I will try and get a screenshot posted later tonight.  It has all the other players listed in "white" text but Player 2 is "grayed or darkened" out.  You can still select and edit the settings but Player 2 still remains darkened out.
example:
From using "TAB" and reviewing controls
Player 1
Player 2
Player 3
Player 4
Player 5
Player 6
kjbalto
  • Last login:January 20, 2018, 12:33:06 pm
« Reply #5 on: September 10, 2009, 02:43:11 pm »
I have the same setup and mine works.  Maybe the screenshots will let us see something that is wrong.  Show me your mame.ini file also.
slik50
« Reply #6 on: September 10, 2009, 03:40:12 pm »
kjbalto, I will post screenshots later tonight.  Thanks for the help guys!  I'm new to Mame and will soon be using MaLa once this little issue is out of the way.  It seems to me that I might have a condition to change in one of my files (possibly the mame.ini) so that Player 2 controls are recognized. Hopefully I'll have screenshots posted around 830pm cst.
Justin
Epyx
« Reply #7 on: September 10, 2009, 04:30:48 pm »
Slik50,
This may sound obvious...but have you tried turning off/on Numlock via your a keyboard?
« Last Edit: September 10, 2009, 04:45:19 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
slik50
« Reply #8 on: September 10, 2009, 05:02:03 pm »
Epyx, yes I've tried that several times.  Still no output from Player 2 controls.  I will provide screenshots later this evening.  I think i might try swapping keyboards as well being I have a spare and its another quick test. Yet, I am using a standard.
Thx!
slik50
« Reply #9 on: September 10, 2009, 09:21:58 pm »
mame.ini saved as a text file attached.  See other posting for valid mame.ini.  Attachment didn't post
« Last Edit: September 10, 2009, 10:53:43 pm by slik50 »
slik50
« Reply #10 on: September 10, 2009, 09:32:22 pm »
Below is the X-Arcade file thats part of Mame132.
<mameconfig version="10">
   <system name="default">
      <!-- X-Arcade Version 2.0 input configuration file -->
      <input>
         <remap origcode="KEYCODE_UP" newcode="KEYCODE_8PAD" />
         <remap origcode="KEYCODE_DOWN" newcode="KEYCODE_2PAD" />
         <remap origcode="KEYCODE_LEFT" newcode="KEYCODE_4PAD" />
         <remap origcode="KEYCODE_RIGHT" newcode="KEYCODE_6PAD" />
         <port type="UI_UP">
            <newseq type="standard">KEYCODE_UP OR KEYCODE_8PAD</newseq>
         </port>
         <port type="UI_DOWN">
            <newseq type="standard">KEYCODE_DOWN OR KEYCODE_2PAD</newseq>
         </port>
         <port type="UI_LEFT">
            <newseq type="standard">KEYCODE_LEFT OR KEYCODE_4PAD</newseq>
         </port>
         <port type="UI_RIGHT">
            <newseq type="standard">KEYCODE_RIGHT OR KEYCODE_6PAD</newseq>
         </port>
         <port type="UI_SELECT">
            <newseq type="standard">KEYCODE_ENTER OR KEYCODE_LCONTROL</newseq>
         </port>
         <port type="UI_CONFIGURE">
            <newseq type="standard">KEYCODE_TAB OR KEYCODE_1 KEYCODE_3</newseq>
         </port>
         <port type="UI_CANCEL">
            <newseq type="standard">KEYCODE_ESC OR KEYCODE_2 KEYCODE_4</newseq>
         </port>
         <port type="START1">
            <newseq type="standard">KEYCODE_1</newseq>
         </port>
         <port type="START2">
            <newseq type="standard">KEYCODE_2</newseq>
         </port>
         <port type="COIN1">
            <newseq type="standard">KEYCODE_3</newseq>
         </port>
         <port type="COIN2">
            <newseq type="standard">KEYCODE_4</newseq>
         </port>
         <port type="START3">
            <newseq type="standard">NONE</newseq>
         </port>
         <port type="START4">
         </port>
         <port type="P1_JOYSTICK_UP">
         </port>
         <port type="P1_JOYSTICK_DOWN">
         </port>
         <port type="P1_JOYSTICK_LEFT">
         </port>
         <port type="P1_JOYSTICK_RIGHT">
         </port>
         <port type="P1_JOYSTICKRIGHT_UP">
            <newseq type="standard">KEYCODE_R</newseq>
         </port>
         <port type="P1_JOYSTICKRIGHT_DOWN">
            <newseq type="standard">KEYCODE_F</newseq>
         </port>
         <port type="P1_JOYSTICKRIGHT_LEFT">
            <newseq type="standard">KEYCODE_D</newseq>
         </port>
         <port type="P1_JOYSTICKRIGHT_RIGHT">
            <newseq type="standard">KEYCODE_G</newseq>
         </port>
         <port type="P1_JOYSTICKLEFT_UP">
            <newseq type="standard">KEYCODE_8PAD</newseq>
         </port>
         <port type="P1_JOYSTICKLEFT_DOWN">
            <newseq type="standard">KEYCODE_2PAD</newseq>
         </port>
         <port type="P1_JOYSTICKLEFT_LEFT">
            <newseq type="standard">KEYCODE_4PAD</newseq>
         </port>
         <port type="P1_JOYSTICKLEFT_RIGHT">
            <newseq type="standard">KEYCODE_6PAD</newseq>
         </port>
         <port type="P1_BUTTON1">
            <newseq type="standard">KEYCODE_LCONTROL OR JOYCODE_1_BUTTON1 OR MOUSECODE_1_BUTTON1</newseq>
         </port>
         <port type="P1_BUTTON2">
            <newseq type="standard">KEYCODE_LALT       OR JOYCODE_1_BUTTON2 OR MOUSECODE_1_BUTTON3</newseq>
         </port>
         <port type="P1_BUTTON3">
            <newseq type="standard">KEYCODE_SPACE      OR JOYCODE_1_BUTTON3 OR MOUSECODE_1_BUTTON2</newseq>
         </port>
         <port type="P1_BUTTON4">
            <newseq type="standard">KEYCODE_LSHIFT     OR JOYCODE_1_BUTTON4</newseq>
         </port>
         <port type="P1_BUTTON5">
            <newseq type="standard">KEYCODE_Z          OR JOYCODE_1_BUTTON5</newseq>
         </port>
         <port type="P1_BUTTON6">
            <newseq type="standard">KEYCODE_X          OR JOYCODE_1_BUTTON6</newseq>
         </port>
         <port type="P2_BUTTON1">
            <newseq type="standard">KEYCODE_A          OR JOYCODE_2_BUTTON1</newseq>
         </port>
         <port type="P2_BUTTON2">
            <newseq type="standard">KEYCODE_S          OR JOYCODE_2_BUTTON2</newseq>
         </port>
         <port type="P2_BUTTON3">
            <newseq type="standard">KEYCODE_Q          OR JOYCODE_2_BUTTON3</newseq>
         </port>
         <port type="P2_BUTTON4">
            <newseq type="standard">KEYCODE_W          OR JOYCODE_2_BUTTON4</newseq>
         </port>
         <port type="P2_BUTTON5">
            <newseq type="standard">KEYCODE_E          OR JOYCODE_2_BUTTON5</newseq>
         </port>
         <port type="P2_BUTTON6">
            <newseq type="standard">KEYCODE_OPENBRACE  OR JOYCODE_2_BUTTON6</newseq>
         </port>
                        <port type="P1_TRACKBALL_X">
                                MOUSECODE_1_ANALOG_X
                                </newseq>
                        </port>
                        <port type="P1_TRACKBALL_Y">
                                MOUSECODE_1_ANALOG_Y
                                </newseq>
                        </port>
                        <port type="P2_TRACKBALL_X">
                                MOUSECODE_2_ANALOG_X
                                </newseq>
                        </port>
                                <port type="P2_TRACKBALL_Y">
                                MOUSECODE_2_ANALOG_Y
                                </newseq>
                        </port>
      </input>
   </system>
   <system name="neogeo">
      <input>
            <newseq type="standard">KEYCODE_C          OR JOYCODE_1_BUTTON1</newseq>
         </port>
            <newseq type="standard">KEYCODE_LSHIFT     OR JOYCODE_1_BUTTON2</newseq>
         </port>
            <newseq type="standard">KEYCODE_Z          OR JOYCODE_1_BUTTON3</newseq>
         </port>
            <newseq type="standard">KEYCODE_X          OR JOYCODE_1_BUTTON4</newseq>
         </port>
         </port>
         </port>
         <port type="P1_BUTTON7">
         </port>
         <port type="P1_BUTTON8">
         </port>
            <newseq type="standard">KEYCODE_CLOSEBRACE OR JOYCODE_2_BUTTON1</newseq>
         </port>
            <newseq type="standard">KEYCODE_W          OR JOYCODE_2_BUTTON2</newseq>
         </port>
            <newseq type="standard">KEYCODE_E          OR JOYCODE_2_BUTTON3</newseq>
         </port>
            <newseq type="standard">KEYCODE_OPENBRACE  OR JOYCODE_2_BUTTON4</newseq>
         </port>
         </port>
         </port>
         <port type="P2_BUTTON7">
         </port>
         <port type="P2_BUTTON8">
         </port>
      </input>
   </system>
</mameconfig>
slik50
« Reply #11 on: September 10, 2009, 09:34:15 pm »
Pulled from my mame.ini file.
# CORE CONFIGURATION OPTIONS
driver_config             mame,plus,console
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .;lang
cheatpath                 cheat
crsshairpath              crsshair
langpath                  lang
ipspath                   ips
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE FILENAME OPTIONS
command_file              command.dat
hiscore_file              hiscore.dat
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
scale_effect              none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
volume_adjust             0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr                     X-Arcade
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
# CORE MISC OPTIONS
bios
cheat                     0
skip_gameinfo             0
confirm_quit              1
ips
auto_pause                0
ui_transparency           224
# CORE PALETTE OPTIONS
main_background           16,16,48
cursor_sel_text           255,255,255
cursor_sel_background     60,120,240
cursor_hov_text           120,180,240
cursor_hov_background     32,32,0
button_red                255,64,64
button_yellow             255,238,0
button_green              0,255,64
button_blue               0,170,255
button_purple             170,0,255
button_pink               255,0,170
button_aqua               0,255,204
button_silver             255,0,255
button_navy               255,160,0
button_lime               190,190,190
# CORE LANGUAGE OPTIONS
use_lang_list             1
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
audio_sync                0
# INPUT DEVICE OPTIONS
dual_lightgun             0
joyid1                    0
joyid2                    1
joyid3                    2
joyid4                    3
joyid5                    4
joyid6                    5
joyid7                    6
joyid8                    7
# MESS SPECIFIC OPTIONS
ramsize
writeconfig               0
skip_warnings             0
natural                   0
# WINDOWS MESS SPECIFIC OPTIONS
newui                     0
slik50
« Reply #12 on: September 10, 2009, 10:15:03 pm »
Player 2 General Input Screen.
slik50
« Reply #13 on: September 10, 2009, 10:24:01 pm »
General Input Player Selection Screen attached. This has the darkened out text for Player 2.
Epyx
« Reply #14 on: September 10, 2009, 11:06:21 pm »
Are you playing games that in the arcade only had 1 joystick? For example, Frogger, Ms. Pacman etc had 2 player play but you had to share player 1 joystick. The X-arcade player 2 joystick by default will only work with games that had a "separate" player 2 joystick (Gauntlet, Raiden etc).
What happens when you play a game like Raiden in 2 player mode?
Last Project
Epyx Tutorials:
Tutorials
slik50
« Reply #15 on: September 10, 2009, 11:33:29 pm »
Ok, I was thinking that could be a possibility, however, my JAMMA cocktail table 37 game setup allows for a 2 player, 2 joystick, etc setup with my Pacman, Frogger, etc...so why would I not be able to do that via Mame?
I did just test Raiden and yes Player 2 does work.
So, am I stuck with this or can I modify a file so that it acts like my JAMMA cocktail table machine?
thx!
Epyx
« Reply #16 on: September 10, 2009, 11:47:57 pm »
Hehe you should have mentioned that in the first place :)
Load the game and go Tab->Dip Switches-> change it to cocktail mode...
Presto you now have player 2 on player 2 joystick.
Last Project
Epyx Tutorials:
Tutorials
slik50
« Reply #17 on: September 10, 2009, 11:56:52 pm »
Perfect!  I figured the cocktail option would flip the screen.  Just tested with frogger and all good thanks!!  Much appreciated.
1 other question with playing a game that requires the track ball such as Golden Tee are there any config changes I need to make?
Epyx
« Reply #18 on: September 11, 2009, 12:04:36 am »
Np.
As for your question most likely yes...it may be fine default or you may feel like tweaking it.
To tweak it same as before...Tab->but then go into Analogue controls and you will see settings like digital speed/sensitivity etc.
Last Project
Epyx Tutorials:
Tutorials
slik50
« Reply #19 on: September 11, 2009, 12:10:14 am »
Thanks for the support!
You wouldn't happen to be MaLa knowledgable too would ya?  :)  I might have some questions down the road there too.  I seen loadman is working on some new features and fixes.
I've been playing with MaLa105 for my front end thus far.
Epyx
« Reply #20 on: September 11, 2009, 12:12:09 am »
Don't use Mala (I will in the future though). I would suggest reading the Mala forum though...lots of questions have been answered there ;)
Last Project
Epyx Tutorials:
Tutorials
slik50
« Reply #21 on: September 11, 2009, 12:22:16 am »
Thanks for all the help!  Now I just need my Arcade Video VGA card.  :)
