Author Topic: So I just bought a set of arcade twinsticks....  (Read 3773 times)
NeoTechni
  • Last login:October 15, 2009, 03:23:03 pm
« on: September 09, 2009, 11:25:21 pm »
It arrived June 18. It weighs a fricken ton. I kid you not when I say it weighs more than I do. It was not easy for me being a small girl to carry it home from the post office. If I didn't have a friend with me, I would not have made it back. My arms went numb after a few minutes of carrying it, and my back hurt.
It came complete in it's metal triangle casing.
The 2 connectors, are apparently where I need to connect everything to.
One is a 5x3 grid of pins, top left pin missing. One is a 3x2 grid of pins, top middle pin missing. (intentionally missing for orientation I mean) Anyone know which pin corresponds to which inputs?
It's MSB version 3.3
It looks like one of the ground wires with a =O on the end that you screw into the box, the O part broke off. Not a big deal, I'm sure I can fix that
http://sites.google.com/site/neotechni/Home/operation-moon-gate/IMG_0554.JPG
http://sites.google.com/site/neotechni/Home/operation-moon-gate/IMG_0555.JPG
Oki, so I can account for:
Big (Sticks) connector
Row A
1 <BLANK> = Empty
2 Brown + White = Right Stick, Right direction
3 Blue + White = Right Stick, one of the buttons
4 Pink = Left Stick, Left direction
5 Purple = Left Stick, Down direction
Row B
1 White
2 Green + White = Right Stick, Up direction
3 Fuchsia + White = Right Stick, one of the buttons
4 Light Orangy, brownish? = Left Stick, Right direction
5 Blue = Left Stick, one of the buttons
Row C
1 Pink + White = Right Stick, Left direction
2 Purple + Black = Right Stick, Down direction
3 White
4 Green = Left Stick, Up direction
5 Fuchsia = Left Stick, one of the buttons
Small (START) connector
Row D
1 White = I'd assume START
2 <BLANK>
3 Green = Thick Grounding Wire
Row E
1 Yellow = START
2 Blue + White = I'd assume START
3 Pink + Black = START
That accounts for everything
Though I need to find out which button is which
Is the white ground or voltage? I'd assume voltage, as ground doesn't work in my mind. Plus there is the green grounding wire already.
And what wire does what for the start button? Is there a light in there, so it needs another ground+voltage?
Of course I remember now that the sticks aren't analog, after I made the pic
I also need help finding the other gender of these molex connectors
Any thoughts/help/suggestions?
I intend to solder the other molex connectors onto a 360 controller so I'm not soldering to this artifact.
« Last Edit: September 09, 2009, 11:28:27 pm by NeoTechni »
Ummon
  • Trade Count: (+13)
Re: So I just bought a set of arcade twinsticks....
« Reply #1 on: September 12, 2009, 03:20:07 am »
What are you using this for?
Yo. Chocolate.
Stephen Hawking
NeoTechni
« Reply #2 on: September 12, 2009, 03:27:57 am »
You know, for Virtual On on 360...
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: September 13, 2009, 09:38:49 pm »
What game was this control panel from?  ("MSB" short for...?)
If the molex connectors have pins (hard to tell from the pics, but looks like it to me), they're the "male" half.
Not sure exactly how you're going to connect this to the xb360 controller.  In your picture you mention "analog sticks".  but your descriptions show them as digital (8way/4way) sticks.  With the number of wires, I'll assume they're digital, and you want to connect to the two analog thumbsticks?  If so, you'll probably need four resistors per stick.  Others who've actually hacked a a xb360 propably will have more info on which resistors to use.
With four wires coming out of the start button, I'll guess two are for lighting it, and two for input.
Robin
Knowledge is Power
NeoTechni
« Reply #4 on: September 13, 2009, 11:11:53 pm »
The game supports digital controls. I can attach the left stick to the solder points on the dpad and the right stick to the face buttons, 2 buttons to the shoulder/bumpers, and the the other 2 triggers to the analog triggers (though that one I'm unclear on)
Hopefully lizard lick will get back to me on the connectors, then I can use my breadboard to track down what each wire does hopefully
Ummon
« Reply #5 on: September 13, 2009, 11:39:21 pm »
Nope, don't know. I'm still wondering why you want to use these controls for anything on a late-model console system. ?
Yo. Chocolate.
Stephen Hawking
Kevin Mullins
    • Me on Myspace
« Reply #6 on: September 14, 2009, 12:18:43 am »
http://www.klov.com/game_detail.php?game_id=10341
Same reason they made these:
http://buttonmasher.co.nz/blog/2009/05/12/cyber-troopers-virtual-on-oratorio-tangram-review-xbla/
  • Last login:Today at 10:50:22 am
« Reply #7 on: September 14, 2009, 11:40:25 am »
Did you buy those on eBay?  I was trying to buy those, and got outbid at the last minute...   :'(
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: September 14, 2009, 02:20:10 pm »
Hmm, can that game play with the d-pad and buttons, or does it need to use the two thumbsticks?  If the d-pad & buttons, the sticks will be easy to hack.  If it needs the analog sticks, it'll be a little harder, and would be easier if your twinsticks switches to have NC and NO connections.
A good thread on hacking the analog sticks.
Robin
Knowledge is Power
DashRendar
« Reply #9 on: September 14, 2009, 03:08:54 pm »
Didn't Battlezone and T-Mek use dual sticks like that?
If so, could play those as well.
Ummon
« Reply #10 on: September 15, 2009, 11:45:34 pm »
Battlezone is dual two-ways. I use 8-way sticks, so yeah.
Yo. Chocolate.
Stephen Hawking
NeoTechni
« Reply #11 on: October 15, 2009, 01:06:53 am »
The dimensions of the molex connectors are:
The large connector is 3 cm by 1.9 cm
The small one is 1.9 cm by 1.5 cm
Anyone have any idea where I could get the female ends? Thanks for the assistance I've gotten so far.
NeoTechni
« Reply #12 on: October 15, 2009, 01:08:45 am »
By me?
« Reply #13 on: October 15, 2009, 07:37:51 am »
By me?
I guess so... lol
Ummon
« Reply #14 on: October 15, 2009, 10:09:15 pm »
Google. Also, people have posted molex vendors here, but good luck finding those threads.
Yo. Chocolate.
Stephen Hawking
KissMyWookie
  • Last login:September 18, 2014, 04:57:34 pm
« Reply #15 on: October 16, 2009, 01:41:20 am »
Just looked them up on the Mouser.com website. They both look like Molex Series 1375.
A socket for the first one appears to be Mouser Part# 538-03-09-1151 (Molex# 03-09-1151)
...and a socket for the second one appears to be Mouser Part# 538-03-09-1061 (Molex# 03-09-1061)
Steve
« Reply #16 on: October 16, 2009, 09:56:08 am »
Can you tell me who manufactured those joysticks?
pinballwizard79
« Reply #17 on: October 16, 2009, 02:43:28 pm »
wait.....did you say girl..... there are girls in BYOAC?
« Reply #18 on: October 16, 2009, 03:06:27 pm »
GTFO
