Author Topic: CP feedback and some wiring Q's  (Read 1535 times)
Out4Bl00d1
  • Newbie
  • Last login:September 07, 2009, 09:58:37 pm
« on: September 07, 2009, 09:58:37 pm »
Since I don't have any tools to build my own cabinet I have decided to buy an Ultimate Arcade II with a 4 player CP from mameroom. My CP will have 32 buttons so I figured I could drop 4x U360 joysticks in there and wire all my buttons through them. Then I realized I wanted a spinner, trackball and a 4 way joystick as well. Would I be able to drop an optipac in my CP on its own or does it require an ipac to function? Would I be better off just getting 2x U360'S, 2x 8 ways, ipac 4 and optipac? Also looking for opinions on the CP layout. Seems a lot of guys on this board aren't too crazy about them but its a must have for me. My concerns are that I put the trackball, spinner, and 4 way too close to each other. Will I have any problems mounting them underneath the CP with my current layout?
Here's my CP
http://img199.imageshack.us/img199/9371/4playercp.png
Haterot
  • Last login:November 09, 2012, 09:27:41 am
Re: CP feedback and some wiring Q's
« Reply #1 on: September 08, 2009, 09:24:22 am »
You shouldn't. The Trackball plate encompasses the whole of the unit and the typical spinner is not that large underneath (at least my turbo twister is no larger than a pushbutton) So as far as space below you should be ok.
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
Epyx
  • "You're an oddity"
« Reply #2 on: September 08, 2009, 06:37:52 pm »
I would strongly consider the X-Arcade Trackball as well...of all their parts I think its the only one worth considering...its not expensive...easy to install and feels great (clone of the Betson imperial) and is USB.
You basically just cut out a 2 7/8" hole (no mounting plates on top as its bottom mounted) then route a space for the pack to just below 1/4" wood remaining. Drill 4 holes and done.
Last Project
Epyx Tutorials:
Tutorials
Endaar
  • Last login:December 31, 2024, 05:51:19 pm
« Reply #3 on: September 19, 2009, 10:05:14 pm »
Especially with such a big panel, you've GOT to move the 4-Way and spinner further away from the trackball. You simply don't have enough clear space around the trackball and will find yourself hitting the other controls all the time.
Endaar
