It looks like this:
Crap picture of mine running in the cab:
CRTSize: 20"/ 19" Viewable
Gun: In line XF Gun
Deflection angle: 90 degrees
Dot trio pitch: 0.31 mm
face plate: Silica Coated non-glare
Input Signalcomposite video: 1.0Vp-p RGB analog
composite sync: 1.5 - 5 Vp-p TTL Negative
Video: 0.7p-p analog RGB negative
separate sync: 1.5 - 5Vp-p TTL positive/negative
InterfaceInput Connector: 15 pin shrinked D-sub/BNC Receptacle 5 pcs
Input Impedance: 75 ohms
Scanning FrequencyHorizontal: 15.7-38khz
Vertical: 45-90hz
higher refresh rates result in the screen shrinking in from the sides. At 90hz it's impossible to fill the entire screen.Resolution1280x768
(I've never been able to get it to go past 800x600)
Warm up time 30 minutes
Brightness: 90cd/m squared with STD CRT; standard white window video signal
Video Amplifier 50Hz-50Mhz plus or minus 3db
Blanking TimeHorizontal: 5.1 usec
Vertical: 600 usec
Linearity Better than 7%
(mine seems even better than this, it's almost perfect)Raster Distortion less than 2.5%
Raster size regulation less than 1%
MisconvergenceCenter: .35mm
Elsewhere: .5 mm
Display Size 350x265mm
Power Source 100-120VAC/220-240VAC plus or minus 10% 50/60hz 140w max
Operating EnvironmentTemperature: 0-40 degrees Celsius
Humidity: 10-95% RH without condensation
Cabinet Dimension (W)495 x 9H) 496 x (D) 543mm (19.5 x 19.5 x 21.4")
Weight 32kg (70.6 lbs)
A seriously heavy monitor.Tilt Swivel StandTilt Angle -5 - +10 degrees
Swivel angle: plus or minus 45 degrees
I'm interested in how these specs compare to a typical arcade monitor.
