Author Topic: Flexible drafting ruler that holds shape in Canada?  (Read 4285 times)
Epyx
  • "You're an oddity"
« on: September 03, 2009, 05:31:52 pm »
Anyone know of an online supplier that sells flexible drafting rulers that hold their shape? I am looking for a 40" to draw the curved lines on my cab prior to jigsawing them.
Similar to this:
http://patsythompsondesigns2.danemcoweb.com/shop/product/40-inch-truflex-flexible-curve-ruler/
EDIT: Found one:
http://www.westerntechnical.com
They carry 32" and 40" for anyone else in Canada that might be interested.
« Last Edit: September 03, 2009, 05:55:44 pm by Epyx »
Last Project
Epyx Tutorials:
Tutorials
Franco B
Re: Flexible drafting ruler that holds shape in Canada?
« Reply #1 on: September 03, 2009, 06:20:49 pm »
There is a similar flexible product that is basically the same thing but it has holes in it that you can screw though and then use as a guide to template route the profile.
I saw it a while a go but I can't for the life of me seem to find it. If I do find it I'll post it.
Franco B
« Reply #2 on: September 03, 2009, 06:48:14 pm »
Finally found it :)
[Fisch Flexi Curve]
Epyx
« Reply #3 on: September 03, 2009, 06:51:44 pm »
Thanks Franco B...that one isn't bad either. I will see if that is local here too and compare...I can get the 32" pretty cheap and it looks like it will do the job.
Last Project
Epyx Tutorials:
Tutorials
Haterot
  • Last login:November 09, 2012, 09:27:41 am
« Reply #4 on: September 04, 2009, 09:02:36 am »
50 pounds for a 1 meter piece of plastic??? holy cow.
I need to find a cheaper solution to scallop the edge of my cp.
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
