Author Topic: 44 pin edge connector, Which system uses it?  (Read 1295 times)
Avinitlarge
  • Last login:February 01, 2020, 04:39:08 pm
    • iPhone For Free
« on: September 02, 2009, 05:20:51 pm »
I may have dropped a bit of a klanger. I sold my Shinobi PCB on ebay. It was sold with what I thought was a JAMMA adaptor. The person that bought it said its not a JAMMA connector. I never actually checked if it was a JAMMA or not. The connector has 44 pins, The end 4 pins on each end are GND and I dont know what the rest are as I butchered the wiring? Any Ideas what it was??
« Last Edit: September 02, 2009, 06:06:45 pm by Avinitlarge »
Kevin Mullins
    • Me on Myspace
Re: 44 pin edje connector, Which system uses it?
« Reply #1 on: September 02, 2009, 05:52:42 pm »
So what you're describing is an adapter that goes from the 56 pin Shinobi TO a 44 pin wiring harness ?
Shinobi is 56 pin LIKE a JAMMA pinout...... but it is definitely NOT JAMMA.
http://www.crazykong.com/pins/Shinobi.pin.txt
Lots of older systems used a 44 pin edge connector, so without knowing the exact wiring pinout that was used it would be hard to say.
