Author Topic: Vewlix Slim cab - still stuff to do ...  (Read 135989 times)
SpaceHedgehog
  • Almost done ...
Re: Vewlix style cab. Slim version (Working on side trim)
« Reply #160 on: March 20, 2010, 05:11:08 am »
@BurgerKingDiamond If I make another, I'll convert this into a vertcal shooter. I'd really like to build 3 of these and have them in a row in my games room.
@Kangum, I'm not a skilled woodworker by any means. I did invest in some good tools though, so that helped a lot.
Hopefully I'll have the top strip on by the end of the weekend. I need to build the back out a little as well as the black panels protrude in certain places.
Click a pic for a video tour
  • Last login:Yesterday at 03:57:36 pm
« Reply #161 on: March 20, 2010, 09:07:18 am »
If you build more cabinets, have you considered making variations, such as the L or the one that has pink/red marquee?
It would indeed be a very nice shmup cabinet, especially with nice Japanese 360 games now available in the west such as Mushihimesama Futari and ESPGALUDA II. I I were to build one of these though, I'l prefer having the rotation mechanism made, especially since the LCD screen is pretty lightweight.
SpaceHedgehog
  • Almost done ...
« Reply #162 on: March 20, 2010, 10:35:56 am »
Yes! The blue one looks great but I'm not that keen on the red. Finished the side and top pieces and built the back out.
A few minor things to finish off, the art to apply and the back panels to do.
SpaceHedgehog
  • Almost done ...
« Reply #163 on: March 21, 2010, 07:59:04 am »
Already thinking about some additional enhancements. As I play SFIV on the PC a lot, I was thinking about how to integrate a trackball without it ruining the appearance. I've decided to get a mini version.
I'm going to hide it when not in use by making some of the 'enclosures' like to original. I may even try and mount a keyboard and a couple of USB ports in one of them.
Just ordered an acrylic A4 poster holder for the top as well.
SpaceHedgehog
  • Almost done ...
Re: Vewlix style cab. Slim version Working on SideArt and CP
« Reply #164 on: March 26, 2010, 02:25:32 pm »
Added the artwork holder to the top of the cab:
Sideart vinyl should be back from the printers soon.
SpaceHedgehog
  • Almost done ...
Re: Vewlix style cab. Slim version. Artwork Holder Added.
« Reply #165 on: March 27, 2010, 05:10:52 am »
Vinyl arrived this morning. First piece applied:
It was tricky to get the angles lined up and to apply it.
Here's a "Tournament Edition" logo I made for the front section. It's a 24" monitor so has a bit more space underneath the monitor so I needed to get a better balance. The logo helps to break up the black section below the monitor:
« Last Edit: March 27, 2010, 05:12:26 am by SpaceHedgehog »
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab: Side Art/TE Logo/Artwork Holder complete
« Reply #166 on: August 23, 2010, 06:40:59 am »
Too busy using this to finish it off properly but managed to get some photo paper and print out the artwork for the top. May make the images slightly bigger to fill the space more.
XNIF
  • Last login:January 18, 2017, 04:40:32 pm
Re: Vewlix Slim cab: Top artwork added - finally.
« Reply #167 on: August 23, 2010, 11:10:08 am »
Man this thing look so nice.... i am going to build one of these when i finished mine !
DCsegaDH
« Reply #168 on: August 25, 2010, 05:42:44 pm »
 :cheers: Great job on the cabinet. I can't wait for some new pictures  :applaud:
R1V3R5
  • Last login:February 19, 2012, 03:10:25 pm
« Reply #169 on: September 07, 2010, 02:50:56 pm »
You may have mentioned it and I may have overlooked it, but what are you using for the bottom and top of the monitor for trim?
jikkjack
  • Last login:May 06, 2014, 03:02:58 pm
« Reply #170 on: September 07, 2010, 07:13:29 pm »
Space - that cab looks sweet!  Excellent work. :cheers:
Jason
SpaceHedgehog
  • Almost done ...
« Reply #171 on: September 08, 2010, 01:31:22 pm »
Thanks jikkjack.
@R1V3R5, the trim is a piece of shaped wood (flat on the back and rounded edges on the front) that I got from the hardware store that's covered in vinyl. I was originally going to look for a metal or plastic piece but saw the wood and knew it was exactly the shape I was looking for. I am still thinking about skinning all the vinyl sections in metal but will need to invest in a metal sheet bender first ... something for later.
thatitalian
  • The Revolution Is Coming...
« Reply #172 on: September 09, 2010, 10:51:41 am »
 :o
SpaceHedgehog
  • Almost done ...
« Reply #173 on: June 24, 2012, 04:50:39 pm »
Hope you're all welll. Been a while since I did anything with the cab. Just re-covered it this weekend and made it more vewlix-like by changing the speakers.
Will redo the artwork to make it darker, at some point .....
« Last Edit: June 24, 2012, 05:21:41 pm by SpaceHedgehog »
Re: Vewlix Slim cab: Updated
« Reply #174 on: June 25, 2012, 03:20:29 am »
 :applaud: Welcome back!
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab: Vewlix Desk mod
« Reply #175 on: September 16, 2012, 10:49:23 am »
Not a cab I know but it may give someone some ideas if nothing else.
I'm updating my games room to Vewlix everything. The desk was my next project.
It started life as one of these .... pretty uninspiring but, importantly, sturdy and compact.
The first things done were to cover it in blackboard vinyl, make an angled front piece and a monitor shelf.
I wanted to retain the original height adjusting pole from the monitor, so I embedded it in the shelf.
Then I made some side pieces.
Next was to wrap the frontpiece in vinyl and attach it:
Then a lot of spraying and sanding over a 6 week period to give a decent finish.
Then I gave it some wings.
I made some corner pieces to fit with the style...
... and then added some LED lighting powered by an RF remote.
I also made an accessory tidy using some coat hangers (still adding things to this ...).
Hopefully it may give someone some ideas.
« Last Edit: September 16, 2012, 10:53:15 am by SpaceHedgehog »
Saicho
  • Last login:February 27, 2014, 03:20:24 pm
Re: Vewlix Slim cab: Desk update
« Reply #176 on: September 16, 2012, 01:23:10 pm »
Wow! That looks totally awesome! :D
Azure
  • Last login:November 12, 2013, 08:27:35 pm
  • I want a candy cab:p
« Reply #177 on: September 16, 2012, 03:14:55 pm »
Been following your thread on SRK:) I'm enjoying your build, as I've gone in the same direction (Vewlix-type, choice of materials).  :burgerking:  Gets even better that you're tying things into it:) Suscribed/faved/waiting for more!!
Wishlist: Sega Swing (really want), Sanwa/Seimitsu sticks and buttons, MVS carts, IREM PCBs
SpaceHedgehog
  • Almost done ...
« Reply #178 on: September 17, 2012, 04:46:32 am »
Thanks for the comments  ;D
I have a few plans in my head atm. I'm planning to build the XBOX/console unit next, update my r-pod racing rig, make a stand for my games and consoles and am thinking about building a video pinball machine - just waiting for ZEN studios to release their fantastic Pinball FX2 on PC. That should keep me busy for at least a year I think.
SpaceHedgehog
  • Almost done ...
« Reply #179 on: April 13, 2013, 05:07:26 am »
Having gone through the convoluted process of getting a new job and now having my new fitness regime established, I'm finding I have some time on my hands again .... and I also appear to be suffering from 'forum posting withdrawal'. I'll be getting the remaining aspects of the Vewlix cab which I'm not happy with redone Mainly artwork related), endeavoring to complete my pedestal Cab and generally sorting out my games room. I will still need to rebuild my racing cabinet as well. I can't let this thread go without posting a picture so here's a pic of my new Audioengine A2 speakers in place on my Vewlix inspired gaming desk.
As a reminder, this is the current state of affairs of my Console arcade cabinet (part 1 of a showcase/pedestal cab)
... and my r-pod which will be completely re-styled.
I also need to build a console cabinet rack but will wait for the new PS4 / XBOX to appear before starting that.
mgb
  • North East, US
« Reply #180 on: December 04, 2013, 09:18:14 pm »
Well, I'm in a "comment on an old thread" kinda mood tonight.
Somehow I think I missed this build, probably because I didn't have much fondness for vewlixes then.
But I gotta say, Great job.
This may be the nicest vewlix I've seen. Great lines and the colors are perfect.
SpaceHedgehog
  • Almost done ...
« Reply #181 on: December 05, 2013, 03:28:56 pm »
Thanks mgb. Now there's a few decent fighting games for the PC, I'm thinking about putting one in it ... it's fed from an XBOX at the moment. As with all these ideas, it's no good unless the work's actually done.
My 'room with a Vewlix' will be complete once I've Vewlix'ed my racing pit.
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #182 on: August 09, 2014, 04:17:05 pm »
See that statement under my avatar? It's true; It's still not finished yet ... Well, I've neglected this for far too long. Now the R-Pod MkII is out of the way and Ultra Street Fighter IV has arrived, I'm going to get this thing finished off. There's a few things to do before I can finally call it complete:
Add coin slot:
Have the following printed on Vinyl:
Re-do the control panel / marquee artwork using good quality gloss / satin photo paper. It's not black enough tbh. You can see here:
Update the topper - the artwork is singularly uninspiring:
I also want to try and improve the sound a little. I have some rockwool left over from some acoustic panels I made - I'll use some of that behind the front speakers. Not sure it'll make too much difference but I'll give it a go. I've already used some isolation blocks under the subwoofer in the base and it has made a significant difference.
I'll be printing and laminating instruction strips for the front panel and the illuminated strip on the CP.
I'll update the lighting and add some behind the marquee.
I also need to make a proper back for it. I only started this project in 2009...
Edit: and one more small thing, I want to make some metal retainers for the moves list strips which will sit either side of the opal acrylic on the CP.
« Last Edit: August 09, 2014, 04:19:34 pm by SpaceHedgehog »
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #183 on: April 16, 2015, 04:29:29 pm »
After a really terrible launch day, MK X is now up and running nicely. Tremendous fun with plenty to do ... if you like blood, guts and fighting games, that is:
Installed and running in the cabinet:
Must get around to updating the panel to include 2 extra buttons and redo the artwork.
Electronuclear
  • Last login:May 25, 2017, 10:32:29 pm
Re: Vewlix Slim cab
« Reply #184 on: April 27, 2015, 10:12:12 pm »
This is basically the reason, I am also building a vewlix.
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #185 on: May 10, 2015, 03:21:11 am »
Yes, it's a great game Electronuclear  :cheers:
Finally got off my behind to get this updated.
I've done the artwork for the topper to replace the sad and bland SF4 artwork:
Dull ...
I have also sent the control panel, marquee and insert coin artwork off to the printers - glossy print this time with a lighter gray colour:
... and a Madcatz fightpad to hack so I can include an 8 button layout:
Acrylic sheet for the CP also ordered:
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #186 on: May 12, 2015, 02:58:39 pm »
The artwork has arrived so I made the 'Insert Coin' sticker. This was cut out, covered with a matte tablet screen protector, backed with thin double  sided tape, corners rounded and stuck on to the CP:
I'll be adding a coin slot next to it.
I also cut out the new artwork for the topper - I'll need to find some thick card to use as backing as it's not laying completely flat:
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #187 on: May 16, 2015, 07:24:52 am »
New marquee artwork cut and fitted:
The black and grey are much better.
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #188 on: May 16, 2015, 01:12:38 pm »
Cut the acrylic with the base panel still in progress. New 8 button layout:
Made a complete shambles of the first one but that's why I ordered 2 pieces of acrylic ....
« Last Edit: May 16, 2015, 01:26:33 pm by SpaceHedgehog »
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #189 on: May 17, 2015, 06:41:27 am »
The base for the CP has been cut apart from the joystick section. I will be attaching 1mm aluminium strip to the front and back sections to provide a little more interest and hopefully professional looking finish. This is anodised, I may polish this up:
I still need to tidy the acrylic up a little and obviously it needs dusting ...
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #190 on: May 17, 2015, 08:01:22 am »
Trim cut to size with a test fit on the CP:
MAy not seem much but I like extra detailing.
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #191 on: May 17, 2015, 09:36:34 am »
I've been meaning to make these for a while. Retainers for the light bar:
Gunk needs cleaning off them. May also polish them up  ...
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #192 on: May 17, 2015, 12:44:18 pm »
Completed most of the panel. I still need to hack the fight pad but it's getting there now. I will also replace the right 2 buttons with black ones - they've been re-used from an old stick and are yellower than the others:
Done for the weekend and until the new buttons arrive ...
« Last Edit: May 17, 2015, 01:45:27 pm by SpaceHedgehog »
Re: Vewlix Slim cab
« Reply #193 on: May 17, 2015, 05:51:11 pm »
Nice retainers. Nice everything. :cheers:
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #194 on: May 18, 2015, 05:12:26 am »
Cheers emphatic  :cheers:
What you said some time ago (read years) concerning the choice of paper for the artwork really stuck in my mind. That and looking at the awesome Blip machine (my favourite cab here - simple black and white colour scheme superbly executed) made me realise the importance of a good print.
« Last Edit: May 18, 2015, 05:29:38 am by SpaceHedgehog »
two40
  • Last login:December 28, 2020, 01:33:38 am
  • What does this button do?
Re: Vewlix Slim cab
« Reply #195 on: May 18, 2015, 07:57:55 am »
It's little things like this that makes the result special. Nice one.
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #196 on: May 18, 2015, 09:12:31 am »
Cheers for that two40  :cheers: I'm always striving for improvements to the designs of my builds.
Putting together a design for the Arcade Frontend. Here's the opening screen:
I want something simple, plain and modern looking.
Edit: Picture updated
« Last Edit: May 19, 2015, 11:44:55 am by SpaceHedgehog »
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #197 on: May 19, 2015, 06:49:36 am »
Game selection design for Maximus Arcade:
Just a few minor tweaks needed. Some games need renaming.
Edit: Picture updated.
« Last Edit: May 19, 2015, 11:45:51 am by SpaceHedgehog »
firedance
  • Last login:February 02, 2026, 07:28:15 am
Re: Vewlix Slim cab
« Reply #198 on: May 19, 2015, 12:46:45 pm »
Very smart, should fit in well with the rest of the design  8) ;D
SpaceHedgehog
  • Almost done ...
Re: Vewlix Slim cab
« Reply #199 on: May 19, 2015, 03:55:00 pm »
Thanks very much firedance.
I'm quite pleased with it considering my extremely basic Photoshop skills.
