Author Topic: Background Music not Working Correctly???  (Read 4350 times)
06attaker
  • Last login:January 11, 2016, 03:39:39 pm
« on: August 25, 2009, 01:39:20 pm »
When I put wave files into the background music it will work for the first time.  Its a simply 2 files that makes up the space invaders march.  If I close Mala and then reopen it, the music will not play.  The files are still there but I cannot even play them from the menu screen.  I have to delete them and then add them again in order for it to work.  Any thoughts???
 :dunno
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Background Music not Working Correctly???
« Reply #1 on: August 25, 2009, 06:42:52 pm »
Are you using the beta?  If not, you probably want to use it because its more stable than older versions for me.
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« Reply #2 on: August 25, 2009, 08:30:40 pm »
you could also try converting them to mp3 and see if they work then
06attaker
« Reply #3 on: August 25, 2009, 10:42:48 pm »
When I exit the music files are still there but they won't play when I restart Mala.  I tryed a mp3 file and it does the samething.  I have to go into the menu every time and hit play to start the music back up.  I want it to start by itself when mala is loaded.  Am I missing something????
 :dunno
SGT
« Reply #4 on: August 25, 2009, 11:20:52 pm »
What version of Mala are you using?  Are you using the beta?
dungbeetle46
« Reply #5 on: August 26, 2009, 12:59:05 am »
put a tick in save last position on exit and see if that helps
06attaker
« Reply #6 on: August 29, 2009, 09:07:58 am »
I figured it out!!!
I had to go into the mala configuration file and change the "last song" and "last song position" to a 1 under the background music section.   Now the background music starts again after I have closed it out and restarted it.  Thanks for all the help
