January 30, 2026, 03:22:35 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Front End Support
MaLa Frontend
(Moderator:
loadman
Background Music not Working Correctly???
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Background Music not Working Correctly??? (Read 4479 times)
06attaker
Trade Count:
0
Full Member
Offline
Last login:January 11, 2016, 03:39:39 pm
on:
August 25, 2009, 01:39:20 pm »
When I put wave files into the background music it will work for the first time. Its a simply 2 files that makes up the space invaders march. If I close Mala and then reopen it, the music will not play. The files are still there but I cannot even play them from the menu screen. I have to delete them and then add them again in order for it to work. Any thoughts???
Logged
SGT
Trade Count:
0
Full Member
Offline
Last login:May 31, 2025, 10:10:32 pm
Re: Background Music not Working Correctly???
Reply #1 on:
August 25, 2009, 06:42:52 pm »
Are you using the beta? If not, you probably want to use it because its more stable than older versions for me.
Logged
dungbeetle46
Trade Count:
0
Full Member
Offline
Last login:June 25, 2016, 07:27:47 pm
Reply #2 on:
August 25, 2009, 08:30:40 pm »
you could also try converting them to mp3 and see if they work then
Logged
06attaker
Trade Count:
0
Full Member
Offline
Reply #3 on:
August 25, 2009, 10:42:48 pm »
When I exit the music files are still there but they won't play when I restart Mala. I tryed a mp3 file and it does the samething. I have to go into the menu every time and hit play to start the music back up. I want it to start by itself when mala is loaded. Am I missing something?
Logged
SGT
Trade Count:
0
Full Member
Offline
Reply #4 on:
August 25, 2009, 11:20:52 pm »
What version of Mala are you using? Are you using the beta?
Logged
dungbeetle46
Trade Count:
0
Full Member
Offline
Reply #5 on:
August 26, 2009, 12:59:05 am »
put a tick in save last position on exit and see if that helps
Logged
06attaker
Trade Count:
0
Full Member
Offline
Reply #6 on:
August 29, 2009, 09:07:58 am »
I figured it out!!!
I had to go into the mala configuration file and change the "last song" and "last song position" to a 1 under the background music section. Now the background music starts again after I have closed it out and restarted it. Thanks for all the help
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Front End Support
MaLa Frontend
(Moderator:
loadman
