Author Topic: Can't load layouts???  (Read 2799 times)
06attaker
  • Last login:January 11, 2016, 03:39:39 pm
« on: August 22, 2009, 07:39:57 pm »
Tryed several different times to load layouts and they just aren't coming up in Mala.
I go to the GUI under layout folder and put the folder in where I have downloaded the layout from the internet.  They are usually zipped but I unzip them and mala just doesn't see the layout.  Under available layouts, there is nothing. What am I doing wrong??
Thanks for any info!!
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Can't load layouts???
« Reply #1 on: August 22, 2009, 07:52:31 pm »
After you unzipped those files, there should be files in your layout folder with the file name extension of mll.  Do you have any there?  You may want to post a screenshot of this screen:
06attaker
« Reply #2 on: August 22, 2009, 09:38:23 pm »
Seems like it takes the layout but its only changing the colors of the original layout.  It does nothing else???
SGT
« Reply #3 on: August 22, 2009, 10:01:28 pm »
We need a lot more information to help.
