Author Topic: Linux Based JukeBox Software  (Read 7063 times)
SpAwN
  • Last login:August 09, 2006, 01:41:48 pm
  • Mame Cab done, working on restoring a Wurlitzer
« on: July 11, 2003, 05:24:18 pm »
Does anyone know of  Linux Based JukeBox Software? I'd really like one I can run with SVGALIB (i.e. not using X).
I'd like to run AdvanceMenu.
Thanks.
« Last Edit: July 11, 2003, 05:27:32 pm by SpAwN »
Chris
    • Chris's MAME Cabinet
Re:Linux Based JukeBox Software
« Reply #1 on: July 14, 2003, 04:53:11 pm »
Theoretically, I can recompile DOSCab/WinCab to run on Linux with SVGALib.... (What would it be then?  TuxCab?)  I would need to set up a Linux environment, though, as I currently don't have one...
What version of Linux are you running?
--Chris
--Chris
SpAwN
« Reply #2 on: July 14, 2003, 10:04:44 pm »
--Chris
That would be great! I'm running RedHat 9. I could try to compile it and see what I come up with. If you want to setup Redhat 9 you can download the iso's for free from Redhat.com
Let me know if I can help you in porting it to SVGALIB
Chris
« Reply #3 on: July 15, 2003, 08:24:49 am »
RedHat is up to 9?  <sigh>  I'm SO glad I have a full T1 available....
Porting is a no-brainer, as all graphics and sound are handled by Allegro, which is cross-platform.  The only changes I'll have to make is that the program assumes you're in a short-filename environment if you're not in Windows.  My problem is knowing only a smidge of Linux....
--Chris
--Chris
SpAwN
« Reply #4 on: July 15, 2003, 08:55:36 am »
This will be great for the Linux Cabinet Community. I'm really excited you are going to port this. Like I said I'd be glad to help out anyway I can. Testing, coding, etc.
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #5 on: July 18, 2003, 08:46:20 pm »
try to make it work with as many distrobutions as possible... theyre all for d/l at linuxiso.com anyway. oh, and if ya need it, mandrake user to test it out right here... ;D
It's all about the Pentiums
Chris
« Reply #6 on: July 18, 2003, 11:19:58 pm »
Well, I am not a Linux user, and can barely get around Red Hat, let alone make it work on a variety of distros.... I guess what I'll have to do is just make it Open Source and let people compile it themselves...
Are many people even using Linux in their cabs?
--Chris
--Chris
Veeb0rg
  • Last login:May 31, 2017, 07:34:27 pm
« Reply #7 on: July 30, 2003, 05:44:46 am »
i've been plannin on building a juke for a while and a linux os would be a cheap alternative to windows..
i know i'd prolly use it if there was a linux port..
johnc
  • Last login:September 19, 2003, 04:32:41 pm
« Reply #8 on: August 01, 2003, 11:37:55 am »
Guys,
check out 'Globecom Jukebox' (a.k.a. 'gjukebox') - available at www.sourceforge.net. ;D
Loads of dependencies, but definitely worth it!
I'd use it myself, if it weren't for Cyberpunk's VMJB already configurable for coin/credit inputs.
John
Madam, I may be drunk ... but you are ugly ... and in the morning I will be sober again!
