Author Topic: Wiring DB25 into ym CP... need more pins?  (Read 1393 times)
xxkodemanxx
  • Last login:August 18, 2012, 12:50:47 pm
« on: July 28, 2009, 06:10:57 pm »
a DB25 has 25 pins..obv..
what if my CP has 26 buttons?
2 joys = 8
7 buttons each = 14
and a start+coin for each side = 4
= 26
I wanted to setup a DB25 switchbox for switching between PC and console..
but with 26 inputs..how could i do so?
its really only a problem with PC as I dont need so many inputs for DC or PS..
any ideaS?
Epyx
  • "You're an oddity"
Re: Wiring DB25 into ym CP... need more pins?
« Reply #1 on: July 28, 2009, 07:23:03 pm »
With that many buttons you will have to compromise...also don't forget you will require an additional for ground...so really 27 in total.
I had a total of 29 required.  I went the Cat5e route and ended up with 2 cat 5 cables per player with 1 cat 5 for ground.  So I have P1-1/P1-2/P2-1/P2-2 and GND.
Your could do either 2 DB25 cables or use an IDE ribbon which would involve some hacking on the male side as you would need to strip a connector from an old motherboard/hard drive etc. or purchase something like this:
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=usb&ModuleNo=1449&C=SO&U=Strat15
Last Project
Epyx Tutorials:
Tutorials
