November 21, 2009, 06:39:21 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: ArcadeVGA2 Video Review/Informational  (Read 921 times)
Epyx
Trade Count: (0)
Full Member
Offline Offline
View Profile
« on: July 27, 2009, 10:34:23 PM »
Here is my look at the ArcadeVGA2 video card from www.ultimarc.com.  One of the things I wanted when buying all the components for my cab was a video to see the component before assembly and then in action but other than glimpses in youtube videos on other people's cabs or still photos there wasn't much (at least that I could find).
Hopefully these videos will give researchers/future buyers the opportunity to see the card, learn a bit about it in terms of configuration and see it in action and thereby assist them in making an informed decision.
Part 1 ->
Part 2 ->
Part 3 ->
« Last Edit: July 28, 2009, 12:03:03 AM by Epyx » Logged
Kman-Sweden
Trade Count: (0)
Full Member
Offline Offline
Up the Irons!
View Profile WWW
« Reply #1 on: July 28, 2009, 12:24:37 PM »
Again, great review.  Clap clap clap!
What would happen if you hookup a "normal" pc monitor to that card now using the card and the software installed? Would it run 800x600 max then also?
Does the screen your using have a vga-port or do you use somekind of special VGA->RGB cable?
Logged
See my hard work over here -----> http://www.koskimaki.se/MyArcadePC.htm
Epyx
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #2 on: July 28, 2009, 01:14:52 PM »
You can hook up a regular monitor to the card via the DVI port and would then get the maximum resolution the card is capable of 2048 x 1536 but of course you are limited to your monitors resolution 1680x1050, 1920x1080 etc
The monitor I am using WG D9800 http://www.xgaming.com/htm/wells-gardner-mame-arcade-cabinet-machine-monitor.shtml
has an RGB VGA connector so I just use a standard VGA cable to connect between it and the ArcadeVGA2 card.
Logged
Trade Count: (+1)
Full Member
Offline Offline
View Profile WWW
« Reply #3 on: August 04, 2009, 04:30:26 PM »
This is EXACTLY what I needed.  Great review and thanks for putting this up for everyone!   Cheers!
Logged
axewater
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #4 on: October 14, 2009, 08:38:44 AM »
have you tried running Hyperspin frontend on it ?
Logged
Epyx
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #5 on: October 14, 2009, 04:16:27 PM »
No, but I did have Maximus Arcade running and Mala. You shouldn't have any issues though...its still at its core an ATI card.  Hyperspin should be fine, its Hyperpin that would have issues if used with an arcade monitor as you typically want higher resolutions with Hyperpin, unlike Hyperspin.
Logged
Ummon
Trade Count: (+12)
Full Member
Offline Offline
View Profile
« Reply #6 on: October 15, 2009, 07:50:02 PM »
Hadn't seen that card close-up. Short board on it. Only 64-bit, too.
Logged
Yo. Chocolate.
Stephen Hawking
Epyx
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #7 on: October 16, 2009, 11:02:38 AM »
Ya it is. No issues up to about 2005 but beyond that for 3d anyways, the card is pretty crippled.  Best I have managed ST: IV for example with most gfx options turned off is about 28fps...hardly in the playable territory Sad
But for what it was designed for, the classics etc its a great card.
Logged
Mickelonis
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #8 on: November 19, 2009, 11:05:00 PM »
Sorry to bump an old post, but WOW, this is great!
Thanks for putting this up, it helps clear a lot up for me.
Pretty nice monitor isn't it? I own the same one =)
-Pete
Logged
Epyx
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #9 on: November 19, 2009, 11:11:49 PM »
Glad it helped, just let me know if you have additional questions. Also, use that utility I mentioned in your other thread, Trisync on the Ultimarc site...it will make your WGD9800 really shine in 640x480/800x600 for higher res Mame games and of course Maximus arcade.
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.237 seconds with 23 queries.
