Author Topic: X- Arcade trackball help PLEASE  (Read 2332 times)
skyblast
  • Last login:June 14, 2020, 10:11:01 am
« on: July 23, 2009, 06:34:15 pm »
I'm trying to figure out how to get my trackball to work on my xarcade.  It works fine as a mouse but not with Centipede or any other trackball games.
Any ideas
Vista
Maximus
mame32 0.106.0.0
korbitz
  • Last login:June 30, 2017, 01:09:54 pm
Re: X- Arcade trackball help PLEASE
« Reply #1 on: July 23, 2009, 06:38:26 pm »
you need to alter your mame.ini file
trackball_device          keyboard               'change this to mouse'
skyblast
« Reply #2 on: July 23, 2009, 06:53:24 pm »
ok, sorry to ask for more detail but I'm still a bit confused.
When I open up the ini I see lists like this
mouse           1
joystick          0
etc.
Should I add the word       trackball_device        1
....like this?
It doesn't look like I even have the word keyboard in my list?
Thanks for all of your help
korbitz
« Reply #3 on: July 23, 2009, 07:00:18 pm »
ahh my apologies i failed to spot you were using mame32, and i'm afraid i've never used that version (i used the cmd line version) so have no idea what the ini looks like, maybe something in the options when mame is runiing can be changed, sorry i cant be any more help on this
skyblast
« Reply #4 on: July 23, 2009, 07:02:59 pm »
No problem.  Thanks anyway though
korbitz
« Reply #5 on: July 23, 2009, 07:06:18 pm »
okay quickly downloaded mame32 and if you select properties in a game and goto controller mapping you can change the devices there, i have no idea how to change all trackbalkl games at once though, well not yet anyways  :dizzy:
meh, if you goto options and then default game options, then controller mapping you can assign the default mapping for that device, in the case of trackball select mouse
« Last Edit: July 23, 2009, 07:09:05 pm by korbitz »
skyblast
« Reply #6 on: July 23, 2009, 07:23:06 pm »
by selecting properties in a game is that the same as hitting TAB and going into the map of the rom itself?
Or are you talking about going into mame32?
korbitz
« Reply #7 on: July 23, 2009, 07:25:55 pm »
sorry kinda screwed up my response, when you go into mame32 you can select the properties of a specific game or set some dafult game options in mame32 both do the same except the dafult option should hopefully change all trackball games to work with the trackball, sorry i cant test this as my cab is in bits at the moment
skyblast
« Reply #8 on: July 23, 2009, 07:59:35 pm »
Yeah, I tried messing with that but no luck.
What's weird is that the trackball works for Marble Madness but not Centipede???
« Last Edit: July 23, 2009, 08:05:15 pm by skyblast »
korbitz
« Reply #9 on: July 23, 2009, 08:19:21 pm »
okay quickly knoced together my cab and am having the same problems with centipede, though it works perfectly with the command line version of mame
So i'm all out of ideas at the moment sorry
skyblast
« Reply #10 on: July 23, 2009, 09:21:32 pm »
Weird.  I'll bet MArble Madness works though
broth9640
  • Last login:November 01, 2009, 02:34:46 am
« Reply #11 on: October 22, 2009, 10:55:54 pm »
I am having the same trouble with Mame 32. I have a happ trackball.  Any ideas, someone please help.
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
« Reply #12 on: October 24, 2009, 11:34:11 am »
I can't remember the exact settings menus but I think there are 2 different places where you select "Mouse" as a controller. Also check the tab settings to make sure it's looking for Mouse and not keystrokes for the trackball controller.
mytymaus007
« Reply #13 on: October 24, 2009, 05:44:09 pm »
plug it in  :puke Damm mushroom's
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #14 on: October 26, 2009, 02:55:58 pm »
Which mame version?  (0.134, 0.106, etc)
Mame32 was renamed to mameUI a while back, and older versions of mame/mame32/mameUI had some different issues than current mame.
Robin
Knowledge is Power
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #15 on: October 26, 2009, 03:12:08 pm »
I use Mame32 and have never had any issues with the Happ USB ball or the XArcade.
Maybe try out a different USB port? And double check your game settings within Mame to make sure you have the controls assigned to trackball.
By default, I believe it allows you to use a mouse-- unless you changed something within Mame32- the trackball should be 100% plug/play.
