Author Topic: Happ to stop using Cherry switches  (Read 36252 times)
RandyT
    • GroovyGameGear.com
Re: Happ to stop using Cherry switches
« Reply #40 on: July 09, 2009, 02:56:11 pm »
These new switches don't bother me at all.  Oh and do you think you'll supply some convex happs buttons in the future?  I made a stick for someone that wanted these and was going to order from you and noticed you didn't have any.  I got them elsewhere but I did find that I really liked them.
I will look into keeping some of these on hand.  We should also have another option for convex buttons soon as well.
RandyT
evitagen
  • Last login:April 15, 2016, 10:43:40 am
« Reply #41 on: July 09, 2009, 07:07:36 pm »
Thanks.  I'll be ordering from you again soon once I start my new build, and I want to order all of my stuff from the same place.  You guys were really good to me last time I ordered so expect more business from me.
Oh yeah, speaking of happs and new parts, is the new black acuator happs uses now still sometimes randomly different?  I have a black one and a white one installed in my cab and I can't tell a difference.  But I have another black one that's pretty horrible.  Just curious about this, I know you were in touch with happs about it at one point I think.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #42 on: July 10, 2009, 09:12:23 am »
[quote author=MonMotha link=topic=93809.msg988366#msg988366 Within a week or two, two out of the 10 switches had failed.  They'd "stick" - that is, they'd hold for a period of time after you released them, often making and breaking contact rapidly during that "sticking" time.  It's not hard to debounce a switch (though one could argue all day as to preferred methods of doing it), but it's basically impossible to deal with behavior like that.
[/quote]
I cant explain this at all. A rough calculation shows we have sold around 43,000 of these switches, mostly on J-Stik joysticks (Sanwa UM-8), and not one report of failure until the ones you mention here. Will remain one of lifes great mysteries I suppose...
Falkentyne
  • Last login:July 11, 2013, 11:20:50 am
« Reply #43 on: July 15, 2009, 06:10:04 am »
Best durability micro is old FREEPORT.ILL (now honeywell but new is not good as old). Black casing and green or grey plunger, terminals never have mildew or patina. looks like new after 15 years and work.
it is truee is blamee mini spring on micro, but meny micro unused spring: KWJ and FREEPORT.IL. They act longer, and has same push and sound
How are we supposed to buy these?
Google was completely useless.....
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #44 on: July 15, 2009, 10:01:53 am »
not produced
NOS only, very hard too find
kowal
  • Suzo 4ever
« Reply #45 on: August 21, 2009, 08:14:05 am »
I get new stuff from my local SUZO and I get this "new" micro on all HAPP concave pushbuttons and HAPP Ultimate, on Competion I stiil get iL (PSL-L-CV) and 80% KWJ and 20% e-switch. I buy too 50pcs KWJ, I think to buy next 50pcs price is good 0,75$ for one switch.
and E-switch
 :bat terminal look badly this is not copper (Cu) or silver (Ag), this look how normal aluminium (Al).
 :bat case have weaker and uglier plastic hard too see on photo because it is white but difference is huge.
 :bat have different point of activation on 10pcs: 5 have 1,5mm, 2 have - 1mm and 3 have - 2mm, on KWJ a get on 10psc: 4 -1,5mm, 6 - 1mm. e-swicth work how D44 not KWJ for me.
 :bat e-switch is little harder but only 5g but meny switch have larger differences on copies larger than on KWJ series.
 :bat "klik" is differ on copies, larger than on KWJ series
E-switch is not better from KWJ, it is not analog nor equivalents KWJ, true is they are worse than KWJ and other Cherry model like D-series
 :police: E-switch is more similar to switchy Zippy (with white case and red plunger - Cherry imitation) than Cherry KWJ. This model Zippy come with Ultimate knockoff from coinopexpress http://www.coinopexpress.com/products/parts/joysticks/
goldznnz
  • Last login:June 10, 2014, 03:28:04 pm
« Reply #46 on: September 27, 2010, 03:49:07 pm »
now HAPP look only on price not on quality (China Competion (for You work identical like original), Chinese factories)
crisis xD
"Have you even seen one of the new ones yet to try them?"
no, I will not buy them
Anything here of use ?
http://www.cherrycorp.com/english/switches/pdf/D4_Series.pdf
I have D41,D42, D44.
D41 and D43/D44 use CoinControl, and Wico
D42 use iL and SUZO, Ultimarc
D41/D42/D43 (all is similar) - have different movement, fell - after engagement they place resistance, it is matter of taste. I prefer KWJ in buttons, but I love D42 in Eurojoystick
D44 is very similar fell how KWJ but the point of activation is lower, for buttons KWJ is still more better, on stick it depends - on Wico Conical Joystick they do not work correctly, less diagonal than on KWJ, on other stick work OK and all is fine (iL-Eurojoystick, SUZO)
I know this is an old thread an topic but an IMPORTANT one for those interested!  :angel:
I also 100% agree with KOWAL on this subject
I have tried the new E-switch and compared it to the KWJA0017's.
point of engagements are very different
e-switch:  must be pressed almost all the way down to activate
kwja0017:  almost immediately activated when pressed
resistant/grams of force
E-SWITCH:  rated at 50 grams, but feels heavier/more effort to activate vs the KWJA series
KWJA0017: rated at 75 grams, requires less effort to press down vs the e-switch
I know this may seem odd that the e-switch is rated at a "softer" 50 grams of force but it
actually requires more effort to activate! Your fingers will get tired much faster esp with
fighting games using the E-SWITCH
quietness of switches
E-SWITCH: is louder more clicky than the KWJA0017
KWJA0017: is much quiter than the E-SWITCH brand, almost whisper quiet
I know this is a minor area of preference but this actually relates to the
required force to activate switches.
longevity/ mechanical cycles
have not used E-SWITCH brand long enough to "kill" one yet
but specs rated it at 1 million cycles vs the 10 million for KWJA0017.
for the average joe, they will not really notice any difference between the two. but for gamer/medium to hardcore gamer they will definitely feel the difference right off the bat. Its like the average person buy a home pc vs an enthusiast/knowledgeable shopper looking for that quality product.
I personally just don't like how the E-SWITCH engages near the "bottom" of the switch length vs immediate response from the KWJA0017's. Also the fact that the E-SWITCH requires more force to press down and activate vs the KWJA0017 can really make your fingers tired quickly especially with fighting games. I guess you may get use to this extra force on the E-SWITCHES. I guess you could compare it to a "hard" spring competition joystick vs a "soft" spring comeptition joystick.
*** side note i've also tested the D41C and the D44L
for some reason these are suppose to near identical to the KWJA0017's but there are some differences users should be aware of.
even though the D41C and D44L are both rated at 75 grams in their respective versions, The D41C feel much stiffer to activate vs the D44L. Since both of these use that spring mechanism for engagement, it  requires a bit more of travel to activate when comparing to the KWJA0017, but this difference is just a tiny bit more. And it is still much LESS when comparing to the E-SWITCH brand.
SO QUICK OVERVIEW:
best microswitch for buttons: KWJA0017
next best microswitch: D44LR1AA
I have been a long time gamer and do not mind spending more $$$ for quality parts in my setups
and again totally agree with Kowal on this microswitch topic
sorry if this post is mumble jumbled, but i thought i'd share my experiences for those interested
and now off to shopping for the hard to find KWJA0017 cherry microswitch... ... anybody know where i can
still purchase these???
I live in the USA and its been tough to get a hold of these KWJA0017. I have purchase a few hundred here and there, but still on the look out for more! I guess next best bet would be overseas/EUROPE
anybody???
« Last Edit: September 27, 2010, 05:52:42 pm by goldznnz »
goldznnz
« Reply #47 on: September 27, 2010, 04:05:02 pm »
Also does anybody know the exact model# of the new happ/E-SWITCH microswitch.
I know what the happ# is: 95-0733-90
but specifically looking for the E-swith model #
i went to the e-switch site and used their snap switch model "builder" and came
up with this part#:  LS 085 15 00 F050 C1 A
can anyone else verify if this is correct?
too bad happ no longer includes the "oem" part # on their e-switch microswitch
out of the bag of 50 i have not one has the e-switch part# or happ part # on it.
guess they save some cents here with no part # labels
« Last Edit: September 27, 2010, 05:51:07 pm by goldznnz »
MonMotha
« Reply #48 on: September 27, 2010, 05:12:36 pm »
Quote from: MonMotha link=topic=93809.msg988366#msg988366
Since this got bumped, I noticed I never replied, and you deserve some sort of closure on it.
I gather you've moved away from those switches at this point, so it's something of a moot point now.  Maybe my friend just had bad luck.  I seem to recall those switches felt a little "mushy" from the get-go.  We both keep lots of those Omron switches laying around since they're stock on many of the machines we have, so replacing them wasn't a big deal.
RandyT
« Reply #49 on: September 27, 2010, 06:33:00 pm »
Where to start :)... I'm afraid you have your work cut out for you if you want to stay with those Cherry switches.  I suggest you move on to something like our "Groovy Standard Soft-Touch", which sounds like just what you are looking for.  But let me go though your points and let you know what you are facing.
Let me start off by saying that I have three switches here that I tested, 2 of the kwja0017 Cherry and 1 E-Switch.  I would be hard pressed to say that the actuation point was "very" different between one of the Cherry Switches and the E-Switch.  It's hard to see a difference, but if there is one, I would have to say it was maybe .010" or 10 thousandths of an inch lower on the E-Switch.  Not something that's really even perceivable on a button press.
But on the other Cherry switch (same "Mexico" HAPP model number), there is no doubt something is very different, and this discrepancy may very well be the reason I could not convince them something was amiss.
This is akin to stating that a 12lb bowling ball is easier to pick up than an 8lb one.  In other words, something is wrong.  I'm not sure where you are getting the specs for those particular Cherry switches, but I can assure you that they aren't rated at "75grams".  HAPP specified the E-Switch to have the same ratings as the KWJA0017 Cherry they used to use.  I just tested the actuation force on my lab scale and found that the E-Switch actuates right at about 50 grams of force, while the KWJA0017 Cherry actuates at about 47 grams.  In other words, not a big difference....Well, at least on one of them.  The other measured almost exactly 20grams of force.  Again, same model number.
One more time.  The one Cherry is pretty much exactly the same volume, just a little higher frequency that the E-Switch.  The other Cherry, same model number, is half as loud.
Don't go overboard on manufacturer reliability specs.  They can pretty much put whatever they want on there because they know that the most it will ever cost them is a replacement switch when it doesn't happen to perform as well as they claim.  And how many folks really know how many times a switch was actuated?  (damned few ;) )
anybody???
As I stated at the top of this post the numbers don't seem to jive across the board.  Somewhere along the line, there were a bunch of Cherry switches that were made like you describe, and had an actuation force of 20grams.  These are the switches I had in my hand while unsuccessfully attempting to persuade HAPP and E-Switch that something was not right.  But all it looks like they knew was the printed spec, not what was actually being made and shipped.  So the E-Switches were made to the exact specifications of the earlier Cherry, and it is very, very close (again, same model number).
So this is why we had some made to our specifications.  The Groovy "Standard Soft Touch" switch was made to go the Cherry switch (the one you like) even one better.  It's smoother, quieter, has a high actuation point, and actuates at around 15grams.  And, they are now the standard switch we ship with all of our buttons.  I think you will prefer these, even over the Cherry switches you like.
One more thing to consider; the new HAPP buttons (with the Suzo/HAPP logo) have a pre-engagement throw that is greater than they used to be.  Some like it that way, and some don't.   If you buy buttons and feel like they need to be pressed down too far to engage, then check this aspect.  I like them a little sharper myself, which is why we will be adding some standard buttons in the next day or so which behave more closely like the older design.
RandyT
goldznnz
« Reply #50 on: September 27, 2010, 06:47:29 pm »
RandyT, thanks for your input! I'm on lunch now and will get back to you.
RandyT in the meantime can you let me know how to go about on getting ahold of those
"groovy" microswitches you mentioned? thanks bro
RandyT
« Reply #51 on: September 27, 2010, 06:56:05 pm »
I'll get them on the site this evening.
bkenobi
« Reply #52 on: September 27, 2010, 08:26:38 pm »
Looking at the buttons on your site, it appears that there are 4 switch options.  Which switch are you saying is the "good" Cherry replacement?
Standard Soft Touch™
Premium Groovy-Micro™ Soft-Touch
Versa-Micro™ User Adjustable Switch
Micro-Leaf™
I'm assuming one of the first two, but it's not really clear.  I bought my buttons from you a few years ago and they have Cherry's in them.  Are the switches you are talking about better quality than those, or basically the same with a slight improvement (as mentioned)?
I'm looking to replace the switches on my joysticks to get quicker acting and softer actuation.  From the sounds of it, the ones you are describing might fit the bill perfectly!
RandyT
« Reply #53 on: September 27, 2010, 08:43:24 pm »
Micro-Leaf™
The difference between the "Standard"and "Premium" are the contact specifications.  The "Premium" has industrial grade contacts, and is just a little lighter.  The Standard has a more consumer-friendly price, and a very high performance to cost ratio.  Both would be a fine choice for a joystick you want to quiet down, but not if the joystick relies on the tension in the switch to help it center.  For sticks with a weak return, or where even quieter actuation is desired, the Versa-Micros are a good choice.  Micro-Leafs surpass all of the other varieties in that they virtually disappear as far as tactile feedback is concerned, but they cannot be used with joysticks.
Hmmmm....probably should put that on the site somewhere.  ;D  But if that didn't answer the question, the Standard Soft Touch are, IMHO, better than the Cherry, and the Premiums are better yet, but at a cost.  I am referring primarily to their use in buttons, as joysticks will have a different dynamic based on the stick.
RandyT
« Last Edit: September 27, 2010, 08:54:57 pm by RandyT »
goldznnz
« Reply #54 on: September 27, 2010, 09:06:45 pm »
Ok RandyT going to dissect your reply earlier, my goal is only to make this a productive discussion
no pun intended dawg  :angel:
ACTIVATION/ENGAGEMENT POINTS:
I have some old stock of KWJA, a few days back got an order of 100 KWJA from
aracade emulator.net So i have roughly about 400 KWJA's. I also have order of
50 E-switches from happ that came in over the weekend.
I didn't test every single one, but i sure tested ALOT of microswitch comparisons
between the cherry KWJA and the E-switch brand. The activation point differences was
very obvious, as in night and day my friend.
Take the E-switch micro and push the red actuator down until it clicks. It does not click
until it is almost "flesh" with the white plastic on the micro itself! This simple test
repeated same results over and over with little variances.
Now take a KWJA (cherry micro) push the red actuator down until it clicks. It barely even goes
a mm and it clicks away. Again simple test repeated with same results from old and new batches
of KWJA. If you try this with the D44L and D41C they activate jus a teeny bit lower than the KWJA's.
Conclusion: To me if the activation/engagement difference is as much as the "head" of the red
actuator itself, Thats a huge difference, infact enough where it can degrade my gameplay.  I play hardcore
fighting games like Marvel vs Capcom2 and precision is a must.
GRAMS OF FORCE:
RandyT, All the invoices i have from previous Happ orders all show the KWJA / 95-0733-01 happ part#
to be rated at 75 grams. Even from cherrycorp site, look at their chart of the breakdown of the
KWJA0017 model# and it'll show KWJ + A = 75 grams.
link right here: http://www.cherrycorp.com/english/switches/miniature/k.htm
RandyT, you say that "HAPP specified the E-Switch to have the same ratings as the KWJA0017 Cherry they used to use"
I find that quite hard to fully believe. I think Happ took the closest E-switch avail to "closely match"
the KWJA0017. Let me explain why. The E-switch LS model is rated at 15 amps while th KWJA is rated at
10 amps. The KWJA is rated at 75 grams of force, while the E-switch brand is rated at 50 grams. The differences plus the fact that the terminals on the e-switch are copper alloy plated vs the KWJA terminals being brass copper(not plated).  So to say E-switch has the same ratings as the KWJA is misleading by the least    :-[
Conclusion: There is E-switch is a "close" match to KWJA specs but not exact. They may be using a different
method in calculating grams of force between the KWJA and the e-switch causing this discrepency. KWJA is
definitely softer of the two micros.
VOLUME LEVEL OF MICROSWITCH:
You mention the E-switch has a higher frequency. This could quite possbily be why is sounds "louder". I would consider this but going back and testing volume levels, The E-switch is noticeably louder vs KWJA. There could be
"different makes" of the KWJA causing this difference. I know cherry has their stuff made in mexico, china, and
even india i think. So it could be one's guess on quality control from those regions
Conclusion: The KWJA is the quiter of the two. KWJA has a "softer" click noise vs the E-switch. Also this volume
level difference is a very minor concern, just something to be mentioned.
LONGEVITY/ MECHANICAL CYCLES:
I agree with you on this topic. I remember Happ site when they sold KWJA's to "reliably tested over 10 million
cycles". This was specifically on their site describing their cherry micro's. Even other sites have this same claim with the cherry micro's. I wonder if Happ did this 10 million cycle test or who did it? I don't know for sure if the KWJA really last 10 million cycles, but i know  those bad boyz can go for a long time!!!  :cheers:
HAPP, E-SWITCH, GROOVY SST
I really give you credit stepping up to Happ about the microswitch differences, really I do! I had done the
same thing when Happ bought up Wico/Perfect 360 joysticks. When Happ took over, quality control fell apart like
a sand house on a rainy day. I went to TRI-STAR plastics to have custom replacement parts made especially
for the P360. There were frictional/grinding issue with the ciruclar hubplate and the spring bearing washer. I
spent a few thousand dollars on prototypes and got it right. Still can't beleive Happ took a great product and
used sub-optimal materials and almost ruin one of the best joysticks ever.
You mentioned, let me paraphrase it, "all it looks like they knew was the printed spec, not what was actually being
made and shipped." Man i wouldn't be surprised if that was the case, seriously i wouldn't!
The Groovy SST sounds like a wonderful micro. If you don't mind me asking who/company made it?
Does it have the snap mechanism or the spring mechanism?
RandyT, right now I am so hyped up to purchase and test out the Groovy SST's , will be checking your site tonight!
So please get them listed or let me know how to get them!  :notworthy:
CONCLUSION: It can be possible that specs listed by happ/cherry/e-switch may only be whats printed and not the
"real specs" themselves. So it may be necessary to do a simple test on batches of micros to be sure they are
what you wanted.
PERSONALLY: You would think a any micro would do, I means its just a switch closing a circuit, but the reality
is there is more to it than that for an enthusiast. I may be bold in saying this but i think this is what most people
are looking for in a good microswitch:
1)responsiveness, quick engagement (as you said a "sharp" feel)
2)light pressure to activate, ~50-75 grams of force, maybe even less after i test out Groovy SST!
3)mechanical cycle longevity, if its true the cherry can go 10 million cycles, this fits me superbly
minor qualities:
a)micro click loudness
b)terminal & blade composition materials
Last quick point: COST
I know that cost is an issue with most so a product like the E-switch not a bad alternative to get a cheap micro. But for a little more bling you can get a solid micro. Too bad good things like the KWJA don't last forever, damned economy and business practices. lol
I hope this topic to be helpful and productive for those seeking this info.
Thanks agains for everyone's input
« Last Edit: September 27, 2010, 09:41:58 pm by goldznnz »
RandyT
« Reply #55 on: September 27, 2010, 10:30:53 pm »
I think what you will find is that the tension after actuation is higher on the Cherry's than it is on the E-Switch.  It's difficult to stop the travel on the E-Switch, because the bottom drops out.  It makes you think the actuation point is lower than it is.  But if you are comparing it to a "20-25 gram switch" with the same model number, like the one I told you I tested, I'm not surprised at your conclusion.  It's the same one I came to with that switch.
Well, there is really only one method to calculate it.  It's standardized, and I'm not responsible for any misleading here.  The parts are, what the parts are.  I guess the only thing I can tell you is that the supposed "75 gram" switch is no such thing.  If it were, you would absolutely hate it and you obviously don't :).  And to further complicate the issue, HAPP doesn't actually connect a model number to the part number (online catalog), but it does say 75gram.  The Cherry documentation also states "75gram", but even the stiffer parts are not 75 gram, rather closer to 50.
The only thing that can be extrapolated from this mess is that the Cherry switch everyone liked was likely a mistake, and when the price was jacked up on the Cherry's, HAPP probably used stock on hand as a reference.  I'll give you 2 guesses what that stock most likely measured for actuation force. ;)  BTW, I'm using a little inside info here, having spoken to both companies about this.
I'm thinking you are still trying to extrapolate data from the "good" (mistake) Cherry switch, not the one with the specifications that are the closest to that on the Cherry Website.  Like I wrote earlier, I have 2 of them here with that exact same model number, but are almost identical to the E-Switch.  And I think I stated that the Cherry switch was higher frequency.  ;)
If it ain't in the Cherry documentation, then it ain't true.  And it ain't in the Cherry documentation. :)  Of course anyone can test a few switches and make any claim they want.  But I wouldn't expect Cherry to warranty a cheap switch for more than a million actuations.  It's a pretty fantastic thing that a mechanism that costs so little could even approach that longevity.
Still can't beleive Happ took a great product and used sub-optimal materials and almost ruin one of the best joysticks ever.
While I can't comment on that situation, ask me about 49-ways sometime (but not now, please...)
what you wanted.
Absolutely.  I have switches here to prove it.  75 to 50 is a heck of a drop, but nothing like the drop from 75 to the 20-25 gram switches everyone liked.  I honestly can't imagine using a 75gram switch in a pushbutton, and can only imagine that it was a legacy figure that had little semblance to the real parts.
I may be bold in saying this...
It's a little bold, but not terribly.  For some, a decent switch that gets rid of the dreaded "click" and dropaway feeling is the holy grail.  Each individual will put those things in a different order, based on what they were used to, or what they are trying to achieve.  Lots of folks play their cabs often, but they seldom get the abuse that a cab out "on route" will see, so even sick longevity isn't the issue for most that you might think.
RandyT
« Last Edit: September 27, 2010, 10:39:39 pm by RandyT »
goldznnz
« Reply #56 on: September 28, 2010, 01:02:49 am »
Right on RandyT! I see you put the Groovy Standards up for individual sale.
Just waiting on you to also put the Premium Groovy-Micros up for sale too, please let us know.  :notworthy:
Also would it be okay to tell others about your custom microswitches?
If so I'm afraid your stock might get depleted quickly, I'll wait for your okay on this first.
bkenobi
« Reply #57 on: September 28, 2010, 12:31:08 pm »
Thanks for the info.  I'll have to get some Soft Touch switches to play with then!
goldznnz
« Reply #58 on: September 28, 2010, 02:56:28 pm »
I hope I'm not being a "pest" but RandyT when are you going to add the Premium Groovy-Micros to the site for individual purchase?
thanks!  :angel:
RandyT
« Reply #59 on: September 28, 2010, 03:13:27 pm »
Sorry, I had to get some more pushbuttons added first.  Yes, I will be adding them tonight.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #60 on: September 28, 2010, 03:49:08 pm »
It does not click
The word you were looking for is "flush".
NO MORE!!
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #61 on: September 30, 2010, 08:48:10 am »
yep, multiple pages regarding MS's.
Dang, crappy switches make it more arcade like. I never had a choice when going to the laundry mat and that total carnage had the one direction that sucked but I delt with it and it made me a better gamer ;)
goldznnz
« Reply #62 on: September 30, 2010, 03:44:04 pm »
I finally placed an order with you RandyT under the name: Steven Kim  :angel:
I waited and waited for those premiums to go online for sale but to no avial. I finally decided to just order some
pushbuttons with the premiums, just to get the premiums groovy micros  ;D
anyways taking your advice, just ordered a small batch out and checking them out first. hopefully their "good as" or even better than the KWJA's!  I got lucky and was able to come across a few hundred more KWJA's the other day too!
now just gotta wait for USPS  :applaud:
EDIT:
Hey RandyT, you never answered my questions on what type of mechanism is in your GROOVY microswitches
is it a snap mechanism?
or
is it the spring mechanism?
I'd hate to crack open a good microswitch just to find out! thanks RandyT
« Last Edit: September 30, 2010, 07:47:46 pm by goldznnz »
RandyT
« Reply #63 on: October 01, 2010, 02:42:03 am »
Both varieties use coil spring based mechanisms.  I think you will be pleased.
RandyT
bkenobi
« Reply #64 on: October 01, 2010, 01:07:00 pm »
Awe crap!  I just realized that none of these switches will work for me cause I need ones with levers.   :banghead:
RandyT
« Reply #65 on: October 01, 2010, 04:27:04 pm »
If you have switches you are replacing, it's not terribly difficult to transplant the levers into the SST or Versa-Micro.  You just need to separate the casing just enough to free the lever and do the same to install it.  As long as you don't open them all of the way, you don't have to worry about the guts of the switch falling out.
bkenobi
« Reply #66 on: October 01, 2010, 05:09:38 pm »
I had wondered about trat in the past, but never worked up the courage to pull my switches apart to check.  Good to know!
