Author Topic: mala favourites list.  (Read 3176 times)
liquidsins
  • Last login:May 27, 2010, 03:44:25 pm
« on: June 28, 2009, 01:29:04 pm »
ive just completed my first 3/4 size cab and altho it was a long and frustrating struggle it was worth every hissy fit, the small fortune and all the blood sweat and tears!!! everyones going mad for ladybug at the mo!
my question is, is, is there a favourites section on the mala front end as i cant seem to find it, and as ive over 5000 games its taking a while to get from game to game
thanks liquid.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: mala favourites list.
« Reply #1 on: June 28, 2009, 03:05:26 pm »
Yeah, you make game list(s) with your favorites.  Personally I decided upon about 10 categories and put my favorites into these.  Thus I have about 10 game lists and cycle through these with my joystick.  I have the main game list disabled so only my custom game lists show up.
Ummon
  • Trade Count: (+13)
« Reply #2 on: June 28, 2009, 06:39:29 pm »
Me, too, though I imported my mame32 lists.
Yo. Chocolate.
Stephen Hawking
TheNewGuy
  • Last login:September 06, 2009, 02:56:56 pm
« Reply #3 on: July 29, 2009, 03:45:53 pm »
Is there a way to dynamically add to and remove from a favorites list? Mala can do that with a single button push, can't it? Can it do that if I'm using trees?
« Reply #4 on: July 29, 2009, 03:51:32 pm »
The way I've got MALA setup (and I believe this is standard), Player 2 start will pop up a menu in mala that allows you to add or remove games from any of the lists you've already defined.
You have to use the mouse menus to actually create new lists though, i believe.
TheNewGuy
« Reply #5 on: July 29, 2009, 08:39:00 pm »
Which means I can create a blank list called "favorites" and then just add to and from it. I'll have to test that out when I plug my controls back in, they're out right now so I can do some decorative work on the cabinet.
vanschlong
  • Last login:August 17, 2009, 04:48:38 pm
« Reply #6 on: August 01, 2009, 11:38:27 am »
Thats how i did it, right click mouse on mala frontpage and select options, go to gamelists and create one called favourites. Then all you do is press player 2 start button-game list- add selected game-favourites.
