I realize that this largely depends on the type of wood you're using which is half the reason I'm asking this. (I want to try and decide what type of wood to get.)
I'm going to be installing a couple of U360s for my control panel but I realize that the sticks are very short. I don't want any knuckle scrapping action going on but I also would like to avoid using the long handles if at all possible.
I won't be covering the cp with plexi, only vinyl so I'd like to bottom mount the joysticks to make sure everything stays flush and nice. (It also keeps things simpler.)
This means that I have no choice but to route out the underside of the CP before bottom mounting the joysticks. How thin will I need to route the wood to get the u360s up to an acceptable height and what's the maximum amount I can remove without sacrificing much in the way of sturdiness?
