Author Topic: Startcom V5.3.2 is now posted on malafe.net (Important update)  (Read 9837 times)
You can download it here:
Malafe.net
« Last Edit: October 04, 2009, 07:08:32 pm by DaOld Man »
Re: Startcom V5.3.2 is now posted on malafe.net (Important update)
« Reply #1 on: October 04, 2009, 07:13:39 pm »
I ran an older version of Mala recently and found that it does not have the button on the plugins section that allows you to setup the plugin.
So if anyone is using startcom with an older version of Mala, the only way you can set up startcom is to create the ini file and manually edit it, which we all know can be a PITA.
So I wrote a program called Startcom Configurator that will allow you to set up startcom from outside of Mala.
It closely resembles the startcom setup screen.
It is written in Vb6 so you may need teh MS VB6 runtime files, available free from microsoft.
The program has been submitted to the malafe.net plugins section, and should be available for download soon.
It will need to be placed in the same folder as startcom (Mala\plugins).
Here is a screen shot of the program:
« Reply #2 on: October 09, 2009, 06:21:19 pm »
Loadman, I uploaded this app a few days ago, was just wondering if it got lost on the electronic highway??
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #3 on: October 09, 2009, 09:38:46 pm »
I'm thinking you may should PM him on this in case he doesn't get by here in a while.
« Reply #4 on: October 11, 2009, 12:26:04 am »
OK, thanks SGT!
adam_763
  • Last login:February 24, 2025, 05:41:41 am
« Reply #5 on: October 22, 2022, 05:53:24 pm »
@DaOld Man
Is there anywhere else to download v5.3.2? Obvs malafe.net is no longer available.
Cheers..!  :)
  • Last login:Today at 04:39:10 am
« Reply #6 on: October 22, 2022, 06:10:14 pm »
Here's an archive.org backup of the plugins page.
https://web.archive.org/web/20171124212454/http://malafe.net/index.php?page=plugins
Direct download link for StartCom v5.3.2.
https://web.archive.org/web/20160322073636/http://malafe.net/files/plugins/startcom.zip
