Author Topic: joytokey, mame compatible?  (Read 4915 times)
danfman
  • Last login:November 14, 2009, 10:26:45 pm
« on: May 27, 2009, 01:35:28 pm »
The default to save or load a game in mame is F7 and Shift F7.  I changed this so I could use my joystick/buttons.  But after you initiate a save or load you then have to "select position to load/save from" but then I have to use a number key from the keyboard, which kind of defeats the purpose of using the joystick/buttons to save/load.
To "select position to load/save from" using the joystick/buttons I tried to use Joytokey.  I tested Joytokey with notepad and it works well, but when I use Mame it has no effect.  Also tried Xpadder with the same result.
Is it incompatible?  Is there another way to save/load using the joystick/buttons?
"It depends on how you define alone…" –Bill Clinton
gonzo90017
Re: joytokey, mame compatible?
« Reply #1 on: May 27, 2009, 01:50:59 pm »
Joytokey and xpadder hasn't been working for a while. There is a compiled version of mame that is compatible with xpadder.
You can find it here. http://blackhole.ipbfree.com/index.php?showtopic=269&hl=mame
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: May 28, 2009, 07:57:04 am »
An easier way is to compile Mame with DirectInput turned on. To do it open src\osd\windows\input.c and change
Code: [Select]
// For testing purposes: force DirectInput
#define FORCE_DIRECTINPUT 0
to
Code: [Select]
#define FORCE_DIRECTINPUT 1
