Author Topic: Set stick to continue scrolling list?  (Read 3602 times)
Ummon
  • Trade Count: (+13)
« on: May 24, 2009, 05:12:58 am »
Here's something else I can't remember how to set up for digital sticks: continue to scroll when held up or down. ??
Yo. Chocolate.
Stephen Hawking
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Set stick to continue scrolling list?
« Reply #1 on: May 24, 2009, 08:44:20 pm »
bit more info
digital stick? is this just a joystick or something else.
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
« Reply #2 on: May 25, 2009, 01:49:14 pm »
Not sure about the digital stick, but If I'm not mistaken what you want if for the gamelist to cicle.  In other words, if you're at the top of the list and you press UP, you'll be positioned on the last game of the list; and if you're at the end of the list and press DOWN, you'll get position on the first game of the list.
If that's the case, then under the GUI tab, under the OPTIONS tab, there's a tab called  "Gamelists"; check  the "Wrap games and gamelists" option and you're good to go.  I'd post a pic, but there seems to be a problem right now that doesn't let you attach fles.
Hope this helps.
Cheers, :cheers:
Congui
Ummon
« Reply #3 on: May 25, 2009, 04:00:48 pm »
List wrap is selected, but what I mean is that if I have a U360 connected, it's treated like a gamepad, so holding it up or down will continually poll and the list will scroll till I let off. On my main rig my digital sticks do this, too. But the sticks (seimitsu, I think) on this recent MaLa installation on my candy don't. As far as I can tell, except for the mame directories, and no U360 on the candy, the configurations are the same.
« Last Edit: May 25, 2009, 04:03:40 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
dungbeetle46
« Reply #4 on: May 25, 2009, 07:40:26 pm »
what encoder are you using, if your using an ipac connected by ps/2 cable some wont scroll, they need to be plugged into usb for scrolling to work
Ummon
« Reply #5 on: May 27, 2009, 04:37:15 pm »
Ohh. It's an old, old model JPAC. I guess I'll have to ask Andy. Thanks.
Yo. Chocolate.
Stephen Hawking
loadman
  • Moderator
    • MaLa
« Reply #6 on: May 28, 2009, 06:36:27 am »
I have one of those myself. Only auto scrolls on Player 1 inputs.
On the 'to do'list is to provide a solution in MaLa to get around this
Hoagie_one
  • Um....whats a cabinet
« Reply #7 on: May 29, 2009, 11:58:13 pm »
I have a script that will allow it to work.  It's a work around, but it's basically solved the problem for me.
http://dl.getdropbox.com/u/32069/mrepeat.zip
Details here
And Here
Mike
« Last Edit: May 30, 2009, 12:02:43 am by Hoagie_one »
Ummon
« Reply #8 on: May 31, 2009, 07:34:21 pm »
Wow, I wouldna thunk it was a common issue, cos of the other odd behvavior of my unit. Thanks. I'll let you know how it works.
Yo. Chocolate.
Stephen Hawking
loadman
  • Moderator
    • MaLa
« Reply #9 on: July 03, 2009, 10:20:50 pm »
How did it go?
Ummon
« Reply #10 on: July 05, 2009, 04:08:16 pm »
How did it go?
I've been having general functioning issues with the unit, and forgot to get back on this. Yeah, it works. Thanks for checking.
Yo. Chocolate.
Stephen Hawking
